My lg WD80291NUP washing machine is not picking soap from the dispenser drawer. What should I do?
dutchman05
  • 487 Answers
SOURCE: soap won't dispense
the problem is quite easy. There are 2 valves on top of the dispenser box. When disconnected from power source please check whether the connections are secured. Sometimes the valve connections shake lose during transport or opperation. Also check the dispens drawer for clogging . This should be fixed easily. If you leave the top cover off and plug the machine in and start opperation there should be 120V on the valve connectors. If there is and water stil does not come out the valve is faulty and you have to order a new one.
  • Part for Model# WM2277HW
  • Part# 5221ER1003A
( ) indicates recommended quantity Valve assy, inlet
Posted on Apr 17, 2008
SOURCE: Ariston A1635 Washing Machine
Soap drawer clips in. Make sure you open fully then pull straight out. to replace make sure you slibe in to runner on door and push in until it locks. Problem may be in the syphon tube. may be clogged or in the unit we had the tube was not open at the bottom.
Posted on Apr 20, 2008
dutchman05
  • 487 Answers
SOURCE: Soap dispenser stuck on LG WM2277HW
here is your SERVICE MANUAL
Posted on Jun 23, 2008
abhishek33
  • 1239 Answers
SOURCE: Removal of washing machine soap dispenser - Indesit
hi
When you wash very linty materials, remove lint from the tub after removing the laundry. Soap deposits may cause laundry to smell bad. To solve this problem, fill the tub with water and add 1 pound of water softener or 1 gallon of white vinegar; then run the machine through the complete wash cycle. If the deposits are really bad, wash the inside of the tub with a solution of household ammonia and mild detergent. Rinse thoroughly and wipe the tub with liquid bleach. Caution: Rinse the tub thoroughly before wiping it out with bleach. Ammonia and bleach can combine to form a very dangerous gas. Finally, run the machine through a complete wash cycle before you put any more laundry in.
Posted on Sep 13, 2008
Dissolu
  • 221 Answers
SOURCE: Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Posted on Jul 25, 2009
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
How do i get the soap dispenser unclogged?
Open the soap dispenser drawer and press the green drawer retainer (in the middle compartment) down while pulling the drawer outwards, this will release the catch on the drawer.
Sep 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
Mar 14, 2011 | LG WM2277HSW XL Front Load Stackable...
My new LG washer always has water in the soap dispenser, bleach dispenser, and fabric softener dispenser after the cycle has finished. Is this normal?
Mine too!! Very annoying, especially since the water then drains down onto to floor and has actually made the door hinges stiff! I just use powdered bleach now.
Aug 22, 2010 | LG Washing Machines
HOW TO CLEAN SOAP DISPENSER DRAWER ON LG WASHER
On the very back top of the drawer is a lock lever that you depress to relase the drawer. Push it down and pull drawer out. Clean and replace.
Jan 27, 2010 | LG Washing Machines
Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
May 23, 2009 | LG WM1814CW Front Load Washer
Dispenser wont open
The dispenser has jammed against the drawer and will need to be checked out by a qualified LG technician.  They will have to remove the top of the machine to gain access to the dispenser.  The dispenser has a top section that can be unsnapped to gain access to the drawer for removal.
Jul 19, 2008 | LG WM-2277HW Front Load Washer
Soap dispenser drip
Normally you shut off the wall valve when you are thru with your washing. If there is a leak in the front area (important: first take the plug off the wall) open up the top of the machine and check whether the three rubber tubes are in place at the soap dispenser - one of them may have come off. Refit or replace if rubber tube is damaged; would be good to check all the tubes. Another thing would be to check that your soap dispenser is not clogged. :)
Sep 21, 2007 | LG WM1815CS Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
