Question about Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot
Wired up a 240V 2HP sta-rite duraglass. I turned it on it ran for about 5 seconds and then blew the yellow wire off of the ***. Why?
  • 8,404 Answers
Was the motor set up for 220 or 110? double check your work.
Posted on Jul 28, 2010
Installed new pump unit starts and runs for 15 minutes then trips breaker what should I check
When the pump nears the 15 minute mark, check the housing to determine whether it is running hot. Also listen for changes in pumping sounds as something may be causing restriction.
Nov 22, 2013 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Replaced old Sta-Rite pool motor with new 1.5 hp Emerson 1081 pool motor. Used exiting 240V wiring. Wired L1 to 120V (black wire), L2 to 120V (red wire), Ground to green ground Screw (green wire). Turned...
Get qualified electricrian to help. I've had the same problems with my pool pump. If you make one little mistake, it could be your last.
Oct 05, 2011 | Pool & Spa
I turn my pump on, it starts pumping then about 10-15 sec it shuts off. Doesn't seem as loud or pulling pressure either.
Check the label and then the wiring on the motor to see if you are wired 120 or 240 first. If you are supposed to get 240 and are getting 120, the motor will run @ 1/2 speed for a little while and then shut off. If this continues, your motor will short out. If your motor is getting 240 volts while running, you have a bad motor.
Oct 09, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Pool in off mode but pump keeps running.
Replace filter pump relay if you have an automated system.if you have a timer it is not wired correctly
Sep 16, 2009 | Sta Rite Sta - Rite 2hp Max - E Pro...
When i turn the pump on it gets hot and shuts off. i am having trouble with the wiring i believe.please help i am trying to wire it to a 110 connection
If the motor is getting hot enough to shut down it's time for a new motor. Many of the new motors need to be ordered in as 110v or 220v and are no longer able to be wired eather way. You will need to take the pump apart and take it in to a motor shop and have them get you a new one or a reconditioned one and they can tell you how to wire it as every brand is different.
Jul 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
2 hp vertical sta-rite well pump
Did you prime the pump? To prime: Before turning pump on, unscrew plug cap from top of pump (usually on pump impeller housing,) and with a pitcher or garden hose, fill pump full of water, and replace plug. Then turn pump on and see if problem is solved. If leaking: Are all fittings tight, O-rings and seals new, and is there any pipe thread tape on all threads w/o seals?
Nov 02, 2008 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot Logo
113 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
