Question about ASUS Computers & Internet
I have a 3 week old Asus EAH 5870 v2 1Gb graphics card that just stopped showing up on any monitor in the dvi , hdmi or vga. no signal . But the fan spins at probably full speed. that is what i noticed first when I booted. I could see the hdd lights but the monitor did not see any signal. I put a 4670 in the slot and no problem. I had no problem before. It was virtually new as are all the other components. PSU is new and ample power and a top brand. I am wondering how to get it resolved?
  • johnniedoo Jul 28, 2010
    I did that first thing. still no signal from the 5870. On my gigabyte board 890FXA UD5, I can do that from the board. I am unable to get in so the button on the board is supposed to be for this type of situation. Unfortunately, it did not make any difference. I took a couple of hours trying different monitors with the different ports on the 5870 so tested the hdmi, dvi and vga to 2 monitors, new as well. samsung 2430 and samsung T260HD and neither got a signal from the 5870 board but did ,no problem with my 4670. it had no problem on either monitor and using the same pcie slot. only thing is i cant test the PSU because the 4670 doesnt need the power and the antec 750 only has the built in 6+2 and 6 plug ; the mod plugs are both only 6. so dont know what else to do. i wish the cmos fix worked. I only get a fast fan from the card, the hdd lights and keyboard lights as to other usb things like wifi adapter starts to send , the leds blink anyway.
    thanks anyway
  • 808 Answers
Reset ur CMOS will fix ur problem
Posted on Jul 28, 2010
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
OR;
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector; http://en.wikipedia.org/wiki/VGA_Connector
http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
2) DVI; http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://en.wikipedia.org/wiki/File:Dvi-cable.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface#Connector
3) HDMI; http://en.wikipedia.org/wiki/HDMI
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
http://www.directron.com/dvi.html
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
Feb 18, 2013 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
Cannot get monitor to hook up with the new asus computer
? VGA or DVI ? Make sure monitor is set to correct input type, including HDMI.
You may have to log in Safe Mode and lower screen resolution if you have an old monitor that does not support high graphics.
Nov 24, 2012 | ASUS Essentio CM1740-02 Desktop 2.4GHz 4GB...
Monitor does not connect with computer . dvi no signal
Could be a bad monitor and if not, then the graphics card if it has one, if not the motherboard connection. Try it with another monitor to rule out the monitor, then if you ave a graphics card, remove it and reseat it.
Jul 24, 2012 | ASUS P5GC-MX/1333 Motherboard
Hi there, i was just wondering that, my hdmi monitor which is goodmans GTVL19W17HD monitor and it has a HDMI slot, but my graphics card doesnt, instead my graphics card has a vga and dvi slot, and if i...
Hi hassy786,
Regarding your question if you will use a converter from VGA to HDMI will it provid High Defenition video?
I believe that it will provdie video converting the signal from VGA to an HDMI connection but I do not think that the video will be High Definition since the VGA is just being converted to HDMI signal and not an actual HDMI but just a converted signal, and it is possible that it may not work properly or the LCD TV may have difficulties recognizing the signal from VGA converted to HDMI.
Thanks for chosing Fixya,
avf110686
Mar 27, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
I cannot seem to connect my new Asus VE247H 23.6 Inch Monitor with my New HP Pavilion Elite 460a Computer
Click here to see your screen specifications.
Your screen Supports DVI, HDMI 1.3 and VGA inputs.
Your Computer should have at least one of these connectors. The cables should have come with the screen.
Match them up, I would use either HDMI or DVI as these are digital signals.
VGA is analog, but if you can only use this one then go for it.
I do not see a reason to purchase an adapter.
Simply plug in at the wall and into the Graphics card of your computer.
You might have a card or onboard Graphics.
Thumbs up!
Let me know how it goes!
damnor01
Jan 20, 2011 | ASUS LCD Monitor
If i connect the DVI cable to my Video card (9200 family)and to my monitor an Asus VH222H i get a dialogue box saying no DVI signal. if i use the VGA cable everything works fine.Does this mean the card...
Make sure your monitor is set up to recieve what ever signal you are wanting via the monitor's menu. There should be an input button on the monitor to select the signal type. The connection really doesn't matter as long as you are able to use the monitor. There could be something wrong with the connector on the video card. Also make sure you are using the card and are not using the onboard graphics connection by mistake. If the problem persists it is more than likely the card.
Oct 27, 2010 | ATI RADEON 9200 Graphic Card
When powering on get no input to monitor board nu a7n8x-e
Make sure you have connected into the correct video port. DVI should be used for LCD monitors and VGA should be used for CRT monitors. Since both ports look the same people often get confused. Try it and let me know.
Sai.
Jan 02, 2010 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
My Acer P205H shows up for 1-3 seconds before showing a black screen. Connected DVI Cable but is there a need to connect vga too?
Depending upon the video port/s you have on the graphics card, you need to connector one video cable, either the DVI or the 15pin DSub to the monitor.
Sep 12, 2009 | Acer AL1916W 19" LCD Monitor
Cannot get second monitor output to work on ATI Radeon X1200
A DVI-D signal is digital (whereas DVi-I is digital AND analogue) and can never be converted into a VGA signal without using expensive hardware boxes that convert the signal. These though tend to lose quite a bit of the signal quality. If I were you I'd look for a monitor with a digital connection, because I'm afraid this isn't going to work.
I'm sorry your problem can't be fixed...
Yannick.
@DickcanFixit: Catalyst 9.4 is the most recent.
May 30, 2009 | ATI RADEON Graphic Card
Computers & Internet Logo
237 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
