Question about Dell 962 Photo All-In-One InkJet Printer
Keep getting error message 'left hand catridge misaligned'
  • Dell Master
  • 12,061 Answers
Support.dell.com/support/edocs/.../962/.../962_English.pdf - United States
Manual above, and below is your support site to help.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=147310
Below is a thread about your printer and fixes.
http://www.fixyourownprinter.com/forums/inkjet/27922
http://www.fixyourownprinter.com/forums/printer/29793
These posts and infor will help you sort it out.
Posted on Jul 28, 2010
Carriage slams into left side
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 22, 2013 | Lexmark Z600 InkJet Printer
How to fix a sysytem error message on a epson photo r320 printer. my printer is displaying a system error message and tells me to hold the stop and power button for 7 seconds. But, after I do this and...
The Solution is simple: Unplug your printer then remove all the catridges then turn it on. Then the printer will display error indicating no catridges then put back the catridges then it will automatically reset your printer thats all folks...Please comment if it works for u...
Jul 17, 2010 | Epson Stylus Photo R320 InkJet Printer
Ink catridge error after replacing my ink catrigdes
you need hp 22 and not hp 57
you can still refill the old one
check here how
Jul 14, 2010 | HP Officejet 5610 All-In-One InkJet...
My BJC-85 give an error message that need it to change the black cartidige and I did but keep the power and error light flashing
if the catridge has to click in make sure it`s in properly or take out the catridge and look for a mini green electronic chip if there is damage to that it might not recognize the catridge
May 16, 2010 | Canon BJC-85 InkJet Printer
My lexmark 7170 printer has error message : right cartridge incorrect. I pulled the brick. Waited a few minutes, replaced but error still appears. Turned off and on etc. Lexmark quide was not helpful. any...
You are trying to put the wrong catridge into right hand side,. the catridge you have put is incorrect. try removing the catridge and put the right catridge back
Jan 09, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer won't print error message remove and check right cartridg
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Sep 16, 2009 | HP Officejet 7210 All-In-One InkJet...
Keep getting message to replace cartridge after doing so
remove the catridge, and wipe clean the printer with clen damp cloth and also catridge head a bit and replace be careful not to touch the sensor with your hand and wipe it clean with the cloth. good luck
Aug 19, 2009 | HP Color LaserJet 2600n Printer
Cartridge
Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel..........Now Move the Catridge carrier which holds the Catridges manually with ur Hand from right to the Left and from Left to right for about 20 Times............. Now Insert both the catridges inside the Printer............. Turn the Printer On............ If still the same Error Message.... Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM..... Now as soon as the Printer is Restarted....... Still if it doesnt work call: 1-800-LEXMARK (539-6275)
Get the Printer Replaced... Good Luck
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ink catridges want work
Try this to reset the unit:-
1) Disconnect power cable
2) Press # and 6
3) While holding buttons connect power cable
4) After you see a message on the screen release the buttons.
5) If you still get the error message, powercycle the unit.
6) You should get a message to select your country and language settings, when you see this reset should be completed.
You might have to try this a couple of times, others seemed to.
HP website link here for ref:-
http://h10025.www1.hp.com/ewfrf/wc/product?product=79477&lc=en&cc=us&dlc=en〈=en&cc=us
Jan 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have a carrier Jam!? It a lexmark x5320 I have tryed everything nothing works.
In this case unplug the Power Supply from the Printer...............
Take Out both the catridges from the Printer.................
Move the Catridge Carrier which holds the Catridges inside the Printer from left to right and from right to left for about 20 Times.......................
now insert both the catridges inside the Printer and Plug in the Power Supply and see whether you get the error message again.................
If u still have that error message please Call lexmark:
Just call this number because the Enchoder strip has to be replaced........
Good Luck
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
