Question about Garmin GPS
Can you replace or remove the plastic 'sheet' on the screen of the garmin gps? there's a tear on my gps screen.
  • 1,514 Answers
There's a protective plastic sheet on them when new. This peels off. If yuo're talking about the scren itself it's not user replaceable. You may be able to get it replaced by garmin. Contact details for Garmin are available at http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Posted on Jul 28, 2010
My Garmin has lost much of its "touch response" especially the lower lines where the Spell, go-back arrow, and go-down to next options are. Basically useless for all but Map viewing
Take you GPS to a repair service and get recalibrated or repaired the touch-screen. Or do it yourself?
https://support.garmin.com/support/searchSupport/case.faces?caseId={31446910-c3a3-11e4-cd20-000000000000}
Garmin Nuvi LCD Screen Removal Replacement Pt 7 Garmin Nuvi 2460 LCD Screen Replacement Disassembly instructions
have cracked Gps screen where can find replacement screen
Garmin digitizer replacement GPS
Look for more tips with Google: searching for
REPAIR TOUCHSCREEN GARMIN
Sep 22, 2015 | Garmin GPS
No signal how do I fix it
You have not said what model garmin nuvi ?
The touchscreen on a Garmin nuvi GPS usually loses sensitivity or stops responding if it's lost calibration.
This usually happens after prolonged usage.
Touchscreen problems are also caused by dirt, smudges and improper care.
If your Garmin nuvi's screen isn't performing as expected, Garmin provides solutions and tips to not only improve the device's performance, but prevent premature wear and tear.
Calibrating the Screen
If the Garmin nuvi's touchscreen isn't working, you need to calibrate the screen.
Calibration resets and repositions the screen for optimal performance without deleting saved settings.
Before calibrating the screen, press and hold the "Power" button to turn off the device.
Pressing and holding the "Power" button again for about 30 seconds automatically displays the calibration screen.
Pressing the dot on the white screen calibrates the touchscreen automatically.
Updating Software.
If The Garmin nuvi's touchscreen is still unresponsive, updating the device's firmware to the latest version can solve operating system problems that lead to touchscreen problems.
Before updating the device's firmware, connect the GPS to the computer using the USB cable. When the computer detects the GPS, the "AutoPlay" menu appears on the screen.
Tapping the arrow on the menu automatically opens the "myGarmin Agent" download page.
From there, follow the prompts to update your Garmin nuvi's software quickly and safely.
Cleaning. In some cases, the Garmin nuvi's touchscreen won't respond to touch if the screen is dirty. Touchscreens are sensitive to dirt and smudges that decrease sensitivity.
If the screen is dirty, cleaning it with a soft, clean, lint-free cloth improves performance.
If the screen is severely dirty, using water, isopropyl alcohol or eyeglass cleaner removes tough stains.
To avoid damaging the screen, apply liquid to a cloth instead of directly to the touchscreen before cleaning it.
Tips.
Refer to your Garmin nuvi's maintenance and storage information found on the device's manual prevents premature wear and tear.
If the screen stopped working after prolonged exposure to extreme temperatures or water, the device's hardware is most likely damaged.
In such a case, you need to contact Garmin for additional troubleshooting and possible repairs.
Attempting to disassemble and repair the GPS yourself only increases the risk of damaging the unit even further.
also it could be a battery problem if the nuvi is not getting power ?
May 08, 2013 | GPS
How to pull off the face on a garmin
You would want to use a small plastic piece with a hook to gently pry the plastic face off. Once you get the silver plastic face off there are screws.
This is the first step in replacing the battery. Here is a video that shows the whole battery replacement process including removing the face.
Oct 20, 2012 | Garmin StreetPilot c340 GPS Receiver
The screen has a plastic film on it that has come off. can it be replaced
You don't need to replace that film, it was just there to keep the screen clean during the manufacturing/packaging process. You're supposed to remove it when you unpack the GPS.
Aug 04, 2009 | Garmin StreetPilot 2620 GPS Receiver
White oval spot in center of screen on garmin 2720 gps
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
If the touch screen is still working the moisture probably isn't between the layers. My guess is moisture got through one of the gaskets and made it's way in between the touch screen assembly and the TFT display.
If you want to clean it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the ones by the IR receiver.
Now that the touch screen is in your hand you can carefully clean the moisture from between the two assemblies. The gaskets are tricky to install again but it can be done, maybe you'll see where they were leaking.
Jan 18, 2009 | Garmin StreetPilot 2720 GPS Receiver
Garmin 2720 touchscreen won't work, must use remote control.
I'll start with a comment I made on another post:
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. Actually the real last resort is to have Garmin fix it for a flat $250. Good luck.
Replace glass screen on the 60 csx garmin
yeah sure with some handy work and a llittle patience you shouldnt have a problem just remove all the screws, be careful not to tear any wires remove the internal componets from your face plate take a small prying tool and remove the glass , just a few dabs of superglue and your back in business! if you want a shatter proof you can alsi use plexi glass.... and if your really adventerous you could remove the standard led's and put custom colors in .... but beware soldering on a board can be dangerous
May 28, 2008 | Garmin GPSMAP 60CS GPS Receiver
What sort of internal memory battery is in my garmin 12xl?
You can find the battery here:
http://www.mouser.com/Search/Refine.aspx?Keyword=658-VL1220-1VC
To open the case, scrape the sealant in the grove around the unit; then use a flat screwdriver, as wide as possible, that fits in the grove. Place the screwdriver on all sides and different places. Rotate the screwdriver gently until the glue tears and both gps housings can be separated.
To replace the battery you will need to be handy in soldering in tight spaces.
Mar 24, 2008 | Garmin GPS 12XL GPS Receiver
Touch screen won't calibrate on garmin 2720 gps
The touch screen is a 4 wire resistive type made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches or cuts that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. You could send it to Garmin for a flat $250, but that makes no sense at all.
If you get another screen (Garmin won't sell you one), Here's how to replace it:
Unlatch the 4 conductor ribbon from the ZIF connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the two by the IR receiver.
When you reassemble, don't get frustrated with the gaskets, they're tricky but it can be done. Tom
Sep 30, 2007 | Garmin StreetPilot 2720 GPS Receiver
GPS Logo
50 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
