Question about Epson EMP-54 Multimedia Projector
Projector instalation on ceiling - Epson EMP-54 Multimedia Projector
  • 23 Answers
Not sure what your problem is. If it's how to turn the image upside down for ceiling mounting open the main menu & go to settings & check for a setting that shows choices of "FRONT" "REAR" "CEILING" etc. & select "CEILING". Otherwise you'll need to clarify please.
Thanks & good luck,
Jim
PRMHELP@EARTHLINK.NET for projector repairs & sales
Posted on Oct 02, 2010
Optima Optima hd81 projector mounted on ceiling now picture is upside down
There is an option in the setup menus to re-orientate the picture, to flip it either vertically, horizontally or both to correct for the various installation options. You should be able to correct it quite easily :o)
Mar 29, 2014 | Hitachi PJTX100 Multimedia Projector
How do you rotate the picture
If u have installed the projector to the ceiling, u will see the image upside down. for this u need to orient the projector image upside down
use the remote,
go to menu, installation, front ceiling option, u are done!
Dec 07, 2012 | Panasonic PT-AE8000U Full HD 3D Home...
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
Our picture is upsideddown how do you rotate the picture???
Go to the Option menu and select Installation then if your projector is sitting on a table or shelf, select "front/desk". If your projector is installed on the ceiling, select "front/ceiling".
That should solve the problem.
Aug 22, 2011 | Panasonic PT-AX200U Projector
Projector is mounted on ceiling mount. Projector
try it without the ups unit, just in case the ups unit is dodgy
Jun 09, 2011 | ViewSonic PJ506D DLP Projector
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
Projection up side down
The NP2000, like most projector, can be set for table top, or ceiling mount, and front or rear projection. It sounds like you have a problem with the mounting orientation.
  1. Open the Basic menu.
  2. Select "Setup"
  3. Select "Installation" tab.
  4. Select "Orientation"
  5. Select the orientation that best meets your situation. The choices are Desktop front, Desktop Rear, Ceiling front, and Ceiling rear.
You can download the manual here.
Nov 11, 2010 | NEC NP2000 Multimedia Projector
Ceiling installation of pull down screen
Found the correct clips (at an acustical supply store) needed to install the 120" Projector Screen to the 'drop' ceiling in our office. Thanks anyway.
Jan 26, 2009 | Focupix 4:3 Standard Format Manual Pull...
Hitachi XGA cp-x275
Yes, this unit is made for either or solution. If you look at the under side, you will see three screw holes, these are for your mount kit which you can get form http://www.mountsandmore.com/Projector-Ceiling-Mounts-C13810.html?refid=G6435.%22projector+ceiling+mount%22&gclid=CIyfl7G_2pgCFQEoGgodXmajdw
There are other sites as well.
Hope this is not too late.
Oct 02, 2008 | Hitachi CP-X275 Multimedia Projector
Projector vertical running lines
Hi there
This is definatelly a interference from a power cable. If any of your signal cables in the ceiling is closer that 5cm to one of those , you will get interference.
The Company that did the installation should know this and I would suggest you call them and tell them that they should sort it out. They should either move the cables or insulate them by means of conduit.
Apr 15, 2008 | NEC MultiSync MT830 Multimedia Projector
Epson EMP-54 Multimedia Projector Logo
180 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
