Question about Garden
How to replace the belt on a craftsman model 502-255030 rideing and mulch 5 speed 10 hp30 in electric
4 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Trying to find replacement belts for a Craftsman
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=craftsman+rider+belts&_sacat=See-All-Categories
They do have some for your rider here on ebay.
You can also Go to http://www3.sears.com/ Enter your correct model number (the one under the seat; starts with 917) then continue to the diagrams list
Posted on May 13, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a belt diagram for a Sears Craftsman II 12
http://www.searspartsdirect.com
Go to the above address, type in your model number
917.257280 just like this with a dot not a dash it will locate the tractor for you, go to the list on the left side of the page and select >>38" mower<< at the bottom of the Sub-components list and it will show you a picture of how it looks installed as well as all associated parts
Posted on Oct 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a Craftsman II
Hi
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel line/s from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 19, 2011
WHO DO YOU TIGHTEN THE MOWER DECK BELT TENSON?
Not sure of your model but you can find the Craftsman web site and get a diagram.Most of the decks I have come in contact with will use an idler type pully somewhere in the belt route that will move in or out etc. to take up slack in belt.Sometimes a spring does the job by holding a pulley against the belt so check to make sure all the pulleys are ok and all the springs are ok.Hope this helps.Rick
Oct 10, 2014 | Sears Craftsman 46 in Mulching Tractor...
Disengage mulch drive
Have you looked beneath the deck with someone engaging or disengaging the blade lever? Get underneath and observe how the belt travels from the engine pulley back, and follow it in the loop it travels to see how it works with the lever engaged and disengaged.
Jun 08, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lost my manual on my Craftsman LTS 2000 20 HP-wondering if I can mulch leaves with my lawnmower and how?
They make a mulch cover for the discharge chute and a good set of mulcher blades. You need the 9 digit model number from the label under the seat and you can get them from sears
Oct 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I would like to replace the mulching blades on my Sears Craftsman riding mower with regular cutting blades. I can find plenty of sources for new mulching blades, but not cutting blades. My mower is a model...
The straight blade for the 42 inch mower is 138971.They cut better and are easier to sharpen and you will need them if you use a gass catcher. If you do not want to use sears for parts you may be able to find good deals on ebay.
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Trying to find replacement belts for a Craftsman Riding Lawnmower. 6 speed 46'' cut EZ 3 Mulching Family SKH 624U1G2RB Model #CV207 Serial # 2811705321
May 13, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Riding lawn mow
give as the model so we can help.
Apr 15, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
238 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
