Question about LG KG270 Cellular Phone
HOW TO SWITCH ON THE PHONE? Im a first timer using this phone.
    President:
  • 1,932 Answers
HI,
To switch on the phone please press and hold the end call button for about 4 seconds it wil switch on.
Follow the same procedure for switching off also
For easy understanding i have attached you a image
Thanx
Posted on Jul 28, 2010
I need to wire a GE #15086 programable timer into a 2 pole/ 3 way circuit.can it be done and how?
You want to wire GE 15086 timer in place of 3-way switch.
You do not have correct timer for the job.
GE 15071, 15086, 15065, 15066 series in-wall timers are for single-pole only.
Open following link to see GE timers and list of timers & manuals for 3-way switching.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Timers made for 3-way are for indoor use only and not cold weather applications. This is because these timers use a battery or rechargeable battery that will not perform long-term when exposed to cold temperatures.
Wiring for 3-way timers requires slightly different wiring at remaining 3-way switch. In other words, the timer replaces one 3-way switch, and the other 3-way remains, but wiring is different on remaining switch.
Look at manual carefully.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | Office Equipment & Supplies
My leviton countdown timer switch makes my bathroom exhaust fan rotate much more slowly than a regular switch. Why?
If this is a new installation, I believe you have a Leviton dimmer instead of a timer. For example, Leviton countdown timers like the 6260 and 6230 have times printed on face, while the similar-looking Leviton dimmer has no times.
Look at instruction sheet that came with product and make sure it says 'timer' and not incandescent 'dimmer'
If this installation worked before and suddenly stopped, then timer has gone bad.
Use circuit analyzer and check nearby outlet to make sure line is clean. Ground faults and circuit noise can adversely affect electronic timers.
Feb 06, 2011 | Heating & Cooling
Can this timer be used as a three switch.
Woods 59028 is a single-pole timer, and cannot be used for 3-way.
Following link shows Woods 59028 timer and also lists timers that can be used for 3-way plus links to each with manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
3-way timers generally have a battery or internal rechargeable battery that powers display and timer clock. As a result of battery, 3-way timers are for indoor use and will not perform very long exposed to cold temperatures.
Look at the manual for each 3-way timer, since each requires wiring change on 2nd 3-way switch.
Feb 02, 2011 | Woods 59028 Programmable Timer Switch...
Model ST01 to be used on a 3 way switch arrangement. Unit works in one switch position but fails to allow light to turn on in other switch position. Several other switches are adjacent in same box and...
You have ST01C timer.
If I understand correctly, timer is wired for 3-way and was working fine before.
Now, the timer is no longer letting the 2nd 3-way switch operate.
I tested this timer.
When the red and blue wires on timer are connected, the timer reverses.
When the red and blue wires are disconnected, the timer reverses back.
So the 2nd 3-way switch merely connects and disconnects the red and blue wire on timer.
This is why wiring is different on 2nd 3-way switch, and not like ordinary 3-way wiring.
http://waterheatertimer.org/images/ST01C-EJ500-w-3-way-450.jpg
This means that a) Timer has gone bad or b) 2nd 3-way switch has gone bad.
1) Replace 2nd 3-way switch
2) ST01C instructions say as last resort, reset timer.
However all timer programs will be lost.
Open following link to read steps for resetting and reprogramming timer, plus wiring diagrams.
http://waterheatertimer.org/ST01C-program.html
3) Replace timer
Amazon:
http://www.amazon.com/Intermatic-ST01C-Digital-wall-Timer/dp/B0045D3D16
Aplussupply
http://www.aplussupply.com/intermatic/timer.htm
Jan 30, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I need to rewire this switch into a light for an aquarium..can you supply wiring diagram
You posted under Intermatic 240Volt T-1906 box-type timer:
Look at model number on inside of timer door.
If this is not your timer, then link below doesn't apply.
Wiring diagram appears on following link:
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html
It seems unlikely you have expensive 240Volt box timer for aquarium light.
So add a comment with clear description of your timer/switch.
If you have wall switch instead of timer, please describe the device, and screw colors on device, and wire colors inside box.
For a price, expert speaks with you over phone while you work on your do-it-yourself project.
Jan 17, 2011 | RTO Intermatic T1906 Elec Mechanic Timer...
On my Woods 24 Hour Mechanical Heavy Duty Timer (59382) there is a slide switch on upper right of face--set to left, switch is adjacent to a circle with a check mark in it; to the right, it is a vertical...
Switch settings are 'Override' and 'Timer'
http://waterheatertimer.org/Woods-timers-and-manuals.html#1702
The manual is unclear which is which.
Pull up a few of the segments located around edge of timer dial.
Segments UP for timer off, segments down for timer ON
Plug timer into wall, and plug lamp into timer.
Lamp is ON and bulb is good.
Move timer switch back and forth to see if lamp turns on.
Manually rotate dial to observe if timer segments are correct for ON-OFF.
Unplug timer and set segments, and rotate dial until current time lines up with black triangle.
Plug timer in.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | Woods Outdoor 24 Hour Mechanical Heavy...
My wall box only has a black & a white. Can I still use this timer?
You posted under GE 15069.
If you have different timer, then add a comment.
Yes you can use this timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15067
Here are wiring instructions
Timer might have blue wire instead of red wire.
Some timers do not have green wire.
How to wire this timer:
1) Green wire connects to bare copper wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This will power timer electronics.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Jan 13, 2011 | GE 60minute Automatic ShutOff Timer Switch...
Whats the side swicth for
15004 timer slide switch is to control timer mode.
When switch is one direction, lamp is ON all the time.
When switch is other direction, timer programs control lamp.
See 15004 timer instructions on following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15004
Dec 27, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Can GE Digital Timer model 15086 be used for two way switch?
GE 15086 can replace single pole switch only.
If you have "3-way" switch, that is when 2 switches control same light, for example in a hallway.
Open link below to identify GE15086 timer, see wiring instructions, on-line manual <> and see list of timers that can be used for 3-way switching with links to those timers and manuals:
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
Dec 20, 2009 | Hardware & Accessories
On my nokia 6500 slide the profile timer keeps reverting my screensaver, wallpaper and ringtone to factory setting at the time set on timer. How do I switch the timer off?
It is a serious design defect of the 6500s. The reason why your screensavers, wall papers and ringtones are lost is not due to some timer setting in profiles but due to a small inconsistent contact between the phone and the memory card.
The only way to eliminate this problem is by placing the screensaver files, wallpaper files and image files in to phone memory (the phone's in built memory and not in card memory ) and then set them in your profile. Always keep them in phone memory as long as you use them in your profile.
Cheers.
Apr 20, 2009 | Nokia 6500 Slide Cellular Phone
LG KG270 Cellular Phone Logo
21 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
