Question about NetGear RangeMax WPN824 Router
Wpn824-all lights are blinking in unison. what does that mean?
All lights are blinking, I am having signal strength issues with Time Warner Telecom but I think at the same time, my Netgear WPN824 is going bad too.
smeago1
  • 136 Answers
SOURCE: Wireless Network Dropping Out- NetGear WPN824 V.2 & Atheros AR5006EXS Wireless Network Adapter
Fergus,
Steps to troubleshoot are as follows.
1. check the physical connections. Go to a broadband testing site to see if you are connecting correctly b/c i am assuming you are wanting to connect to the internet. if not see next step. A common problem with internet connections is the timeout setttings on netgear you should set it to 0 for indefinite.
2. if your problem is related to just the connection between your pc and your router then you should just plug a lan cable in first to see if you can connect to the router without dropouts. This will help you to determine if the problem is with the router.
3. If it is the router then you need to double check your router configurations. Common problems are firewall rules, port forwarding settings etc etc.
4. if it is not the router then double check that the pc and the network card is working properly. If it is then make sure the the wireless adapter support the protocl eg. wep, wpa, wpatsk etc..make sure they are the same and that you should be setting the network key.
5. one final check is you need to turn off some of the rangemax functionality on the router b/c your wireless adaptor probably doesnt support it. try unsecure connections for a while to see if it works then start adding functionality to determine which one is the culprit.
I hope this help.
smeags.
Posted on Dec 31, 2007
YourTech
  • 63 Answers
SOURCE: how to add a laptop to netgear wpn824 router
access the router page and you will see the wireless settings. if your wireless network is password protected then you may have to enter the password in order for the wireless router to connect.
Posted on Oct 06, 2008
  • 20 Answers
SOURCE: Opening NAT for xbox360 on WPN824
u need to loginto the router page
on the left side of the screen u will see an option called WANsetup under advanced
1.disable spi firewall
2.nat filtering to open
apply the setting
it must work
Posted on Dec 17, 2008
  • 40 Answers
SOURCE: can't install my netgear wpn824 wireless router
You can download manuals and software from netgear.com
Posted on Apr 29, 2009
  • 126 Answers
SOURCE: How do I find my version of netgear wireless
You will need to actually login to the router, usually the ip address is 192.168.0.1 or 192.168.1.1
Type that address into the address bar of internet explorer.
Usually the usernaem and password is some type of combination of admin and password
Or try admin and no password, etc.
Once logged in there should be a main status page that shows up and will dispaly the router's firmware version
Hope this helps!
Posted on Jul 08, 2009
What does the red circle mean on a CASIO WV200A watch?
The red circle is the strength of the receiving signal for time calibration! The 3 sectors are to measure the strength of signal! 3 is max strength and 0 is no strength!
Jan 04, 2015 | Casio Mens WV200A-1AV Waveceptor Atomic...
Hi I have a RangeMax - and it has always been working fine. Last week I couldn't connect wirelessly, so I reset. Nothing. Now I've tried connecting wired through the hub - still nothing. The power is...
Can you please check the signal strength of the wireless router.
If you can log into the wireless router management page and check for the erros if any inside the logs.
Oct 30, 2010 | NetGear RangeMax WPN824 Router
Signal remains low but speed slightly increases when light are double blue lite
The top light should be blue if set up correctly and the bottom light should blink blue because it is an activity light. Sounds like you are just having a signal strength issue and you may be able to find a better location to improve reception.
Mar 18, 2010 | Linksys Wireless-G WRE54G Repeater
When i first purchased the router, sgnal strength was fine. now in the last 2 weeks, i get only 40% signal strength at my downstairs location. when i'm close to the router, strength is 90-100%. what...
It seems that the router is getting interfrence on the wireless channel it is using. Please change the wireless channel on the router and check if that helps.
Jun 13, 2009 | NetGear RangeMax WPN824 Router
Poor Signal Strength!
you can buy a cantenna... http://www.cantenna.com/ or you can get a delicious can of pringles and go here http://www.oreillynet.com/cs/weblog/view/wlg/448...good luck to you
Feb 05, 2009 | NetGear RangeMax WPN824 Router
I installed Netgear wnr834b on time warner cable. it works for a minute but then power and link lights go orange and i lose connection. have replaced router but still same thing. also replaced modem and...
If you already replace the modem and the router so it only means that the problem is with your Time warner internet connection line , did you already contact time warner and let them check your internet line to make sure the signal from them is strong and working fine if not contact them...
Oct 24, 2008 | Computers & Internet
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Weak connection with my xbox 360
The best way to make the wireless connection stable is to do some changes on the wireless settings of the router , like changing its wireless channel to the highest one to avoid any interference on your area.........
Sep 15, 2008 | NetGear RangeMax WPN824 Router
Connecting to internet
i am connected and signal strength is strong but i still cannot get on the interned (time-warner cable)
"dsl server error"
Aug 06, 2008 | Arris Wireless G Broadband Router (wr850g)
NetGear RangeMax WPN824 Router Logo
114 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
