Question about Apple MacBook Pro with 17" Display
Screen light i went to wake my laptop up form sleep mode and i could vaguely see the windows that were on the scrreen rpior to it falling asleep but it wouldnt illuminate so i rebooted and it was fine, What casues this? thanks, beth
    Genius:
  • 1,224 Answers
The module standard sleep mode is in effect this usually requires you to log out and then log back in as a screen saftey percausion so it dont burn what ever is on your screen
on desktop right click
properties
goto screen saver
then down at bottom monitor power click the tab
adjust how you want your settings but be warned that adjusting settings might hurt your screen as you leave screen on for lenghth of period the image burns into screen
if you remember monogramn this was a fault of continuous screen deplicition
Posted on Jun 05, 2008
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Moved my computer and now my monitor won't wake up. unplugging the cord to the computer comes up with a no connection signal but the blue light stops flashing. Plugging the cord to the computer back in...
Be sure computer is actually starting. Power off then on computer you should see the boot sequence and then windows screen on monitor. If you do not see startup sequence monitor is not sleeping either the monitor has failed or the video card has failed. Try another monitor first.
Oct 16, 2017 | Samsung SyncMaster 940N 19 inch LCD...
HP Pavillion a6230n Desktop PC sleeping mode is not working properly. After it entered into Sleep mode, it will keep waking up as long as the Internet cable is plugged in. Any other computer can sleep...
Click on Start, Control Panel, Network Connections, Right click on local area connection that is connected and click properties
Under networking tab, click configure. New window opens, then click on last tab power management, take check mark out of "Allow this device to wake the computer" then click "OK"
Nov 30, 2010 | HP PAVILION A6230N DESKTOP PC
Laptop wont wake from sleep or hibernation
1. you will need to go into you BIOS settings for the mother board to disable the sleep mode.
2. You also have a " sleep mode" in your Windows environment.
Check how to in the "help and support" link at the start button or Windows Orb ( for Windows 7)
Apr 15, 2010 | HP Pavilion dv2000t Notebook
What shld i do if asus laptop is in zzz mode and it wont turn on?
Try this simple solution- press on the power button for a very long time, until the laptop stops working.
After the computer shuts down, turn it on again and look for the sleep settings, sometimes the computer is too eager to turn off the display. You'd be surprised how many computers have troubles waking from their sleep (maybe they need to call the charming prince). Anyhow, check the settings for the computer's sleep. I always ensure that my laptop won't independently fall asleep, always by button.
Nov 05, 2009 | ASUS Computers & Internet
Sleep mode wakes up on it's own
turning off all the power saving items does not help this- it just ensures that it doesn't automatically power down your hard drive or shut off power to your monitor automatically when you aren't using it.
May I suggest Hibernation Mode as an alternative? this mode saves everything you are doing to disc and shuts your computer down completely. when you turn it back on, it will restore what you were last doing onto the screen, so you can pick up where you left off.
you can find more information on this and sleep mode from here: http://windowshelp.microsoft.com/Windows/en-US/Help/335c6a5d-0304-4af1-b135-6bf6c124dc111033.mspx#EZAAC
Cheers,
-Demolitio
Aug 03, 2009 | Microsoft Windows Vista Home Premium with...
Laptop turns on but scrreen remains blank and keys do not work
Hi, you should try to re install windows xp or maybe there is a button to make the laptop not sleep.
Mar 28, 2009 | HP Pavilion dv9000z Notebook
My Sims Game - Nintendo DS
try and click "A" when you are stppd beside the bed that works for me then click nap i hope i helped you if i didnt sorry :)
Sep 03, 2008 | EA - Electronic Arts My Sims for DS
Apple MacBook Pro with 17" Display Logo
83 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
