Question about Pentair Kreepy Krauly Inground Automatic Cleaner
Suction is ok but it wont move around the pool
  • 640 Answers
Try checking the following things that often happen when these automatic pool cleaners are not moving: First, make sure that the main drain and and all suction lines not being used are closed. You might be getting some suction, but it might not be enough. Also, check for debris in your filter and pump baskets. Make sure that your flapper is working. If it has debris, it can prevent movement.
Posted on Jul 28, 2010
Viper moving very slowly and wont turn
check water flow to unit if ok take apart check hoses and belts
Sep 11, 2012 | Hayward Viper Pool Cleaner
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
My navigator is like brand new and strong suction, but it just won't move around.
If you are getting suction through the cleaner, but it is not moving around, you probably have wings or shoes improperly installed. If the pool cleaners shoes look worn or are not installed properly, this will happen. A copy of the users manual is below. Check to make sure that they are installed properly.You might also need to adjust the rear tension flap. Finally, even though you think your suction is good, make sure that there are no obstructions or leaks that would cause movement failure.
Apr 06, 2011 | Hayward Navigator Pool Cleaner
Barracuda has plenty of suction but hardly moves around the pool, goes very slowly
You likely just need a new pad on the head. When they ware down they allow the head to get closer to the surface that it's cleaning, but the additional suction makes it difficult for the head to move.
I hope this helps you!
Jan 29, 2011 | Zodiac Baracuda Zippy Pool Cleaner
Wont move,has suction but wont move?
If cleaner is pulsing, you probably have a worn out foot pad and it should be replaced. If it not pulsing, you probably have a ripped or torn diaphragm and it needs to be replaced. Also, make sure there is enough suction.
Aug 03, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Changed the fin on the baracuda, but it still does not move around the pool, can fill the suction if I lift it up, but it does not move.
If you have good suction at the head you may have a bad diaprham or something stuck in it. If you have suction but it is weak check for cracks in hoses or you may have a clog in your pump impeller.
Oct 30, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Lots of suction, but G3 won't pulse or move around pool
theres a throat in it. Its damaged or ripped take a close look at it . you can gey at your local pool store
Oct 05, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Hayward pool cleaner wont move
Make sure the feet have springs in place, move freely, and rubber not too worn. If that all looks ok, then probably too much suction pressure. Use gauge that came with unit to verify proper suction.
May 30, 2009 | Hayward Navigator Pool Cleaner
Pentair Kreepy Krauly Inground Automatic Cleaner Logo
397 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
