Question about Intel 865G Motherboard
To give 12v supply systemis not working - Intel 865G Motherboard
  • 808 Answers
Motherboard problem
Posted on Jul 28, 2010
My up and down buttons do not work on my hand control ?
These hand controls give such problems if the power supply is not strong. If you are using small batteries put in a fresh set. Preferably, abandon them and use a mains supply, or a strong 12V rechargeable battery such as
http://www.amazon.com/UB12120-12V-12AH-BATTERY-VOLT/dp/B007QW7T2M
Jun 15, 2015 | Celestron Optics
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Oct 14, 2014 | Electrical Supplies
Ansering systemis "OFF" and will
What model Uniden cordless system?
Jul 12, 2011 | Uniden Cordless Phone
Dear Sir, I have astec model AA23160 power supply input Ac 100-240 5A max output Dc +5v 23A, +12v 22A max it does not give output the LED give yellow when it is ON. the two cooling fans were also not...
Hi! l have have the same problem whit the Asctec model AA23160 power supply.But l need to know how many time your power supply worked: How many time do you use it?
Thank's!
Aug 13, 2010 | Astec 300w AT Power supply 190170-01...
I NEE TO BUY NETGEAR POWER SUPPLY (OUTPUT 12V 1A)
Hi
You can take this adapter any elictrical shop,and asked them to give 12v adapter,if you show them adapter that will help you get the correct one
Hope it will resolved your query
Thanks for using Fixya
May 24, 2010 | NetGear Power Supply
Motherboard power problem due to atx 12v cable
I tried different power supply but its still not powering up. But when i remove the 4 pin 12V cable from power supply the cpu fan is rolling, it means that the power supply is working but when i tried to connect the 4 pin then the cpu fan stop just a second and never rolled on. The main problem is the 4 pin, the model is Asus P5P800-VM. I tried to reset the cmos and replaced the battery but it wont work out. Please help me!!!
Jun 09, 2009 | ASUS P5P800-VM Motherboard
Unsure about power supply
Don't know if you've got round this by now but the supply needs to be 12v 1A with the inner positive
Dec 21, 2008 | HP Scanjet 4400c Flatbed Scanner
Piggy back power splitter
You can connect the splitter to any of the 4 connectors that power IDEs(Hard Disk, DVD ROM, CDROM etc.,). The splitter's sole purpose is to split one 12v supply into two 12V power supplies so that we can connect two devices instead of one. You can disconnect the power from DVD connect the splitter to it and then use one of the two 12v supplies from the splitter to connect to the DVD drive and the other to the HDD fan.
Jul 13, 2008 | Dell XPS 200 PC Desktop
Kenwood KSC-WA801
if you don't mind a large car battery (and battery charger) in your living room, it will work. Another option is to get a 12 VDC power supply, capable of sourcing 100 or more amps, but that would be too costly.
Jun 15, 2007 | Kenwood SW-38HT Subwoofer
Intel 865G Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
