Question about RTO Echo 25.4 Cc Backpack Leaf Blower - Pb-265lc
I have a Echo PB-260L Blower. It starts fine then gradually loses power sometimes completely shutting off. I have replaced the fuel filter spark plug air filter and have cleaned the screen.
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Posted on Nov 12, 2010
  • z3500 Nov 20, 2010
    You're a genius. Thank you. Pulled off the muffler and found so much carbon, it was a wonder it ran at all. Cleaned it up and it now runs like new. Interestingly, the loss of power is similar to the loss of power experienced in an automobile when the catalytic converter gets clogged up. But this was a much cheaper fix. Thanks again.
How do i check spark on my echo leaf blower
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
May 15, 2014 | Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas...
Need a tune up kit
on a 2 cycle engine change the spark plug and air filter fresh fuel
Jul 03, 2012 | Echo Garden
ECHO PB-500T - Stopped running and added gas fuel mix. Quit running again with full tank and now flywheel is stuck and I can't pull to start it. What is the problem?
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
  • Refill fuel tank with an 2-cycle Oli/gas mixture.
  • 40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
  • Remove the spark plug.
  • Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
  • Remove the pull cord assembly (4-bolts)
  • This reviled the crank shaft-Pull cord bracket
  • I use a large monkey wrench to turn the shaft (CW) Clock-wise.
  • Complete approximate 20 revolutions.
  • Reassemble, but don't install the spark plug yet.
  • Complete approximate 20 more revolutions
    by pulling the pull cord.
  • Use q-tips to swab the top of the piston, as much as possible.
  • Install the spark-plug and crank, it will smoke for amount 7-10 minutes
Jul 30, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo 260L no power, will start but not run
Check the insulator block for cracks and the 2 gaskets behind it. Make sure the gaskets are lined up properly.
Apr 01, 2009 | Garden
Echco PB-230LN blower
Try adding some "Seafoam" brand additive to the fuel mixture, that did the trick for mine. Must have been something in the carb and the Seafoam cleaned it out, runs just like the day it came out of the box
Nov 01, 2008 | ECHO, Inc. PB-251C Handheld Blower
RTO Echo 25.4 Cc Backpack Leaf Blower - Pb-265lc Logo
2,102 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
