Question about Kitchen Ranges
Hot water heater model ge4786a. no hot water.
Hot water heater model ge4786a. no hot water. Tried turning breaker off and then on. Is there a reset on the unit and if so what do I do?
jtate9
  • 68 Answers
SOURCE: Hot Water Heater Trouble
There are 2 checks for the heating elements:
#1 Check the voltage to element ( Black to ground, and red to either terminal of the element.
#2 Check resistance across the element. First turn the power off to the Water Heater, remove wires from element, then measure resistance across element. A good element could read anywhere from 9 K Ohms to 13 K Ohms depending on the voltage of the element. A bad resistance reading would be an infinite reading, or 0 Ohms.
If your elements check good, you might replace the thermastat
Please rate t
Posted on Jul 29, 2008
  • 68 Answers
SOURCE: Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Posted on Mar 07, 2009
SOURCE: hot water heater won't stay lit
Brad Z - you are absolutely correct!
Mine is a sealed burner type and was flooded with 4 inches of water and after I pumped the water out of the basement, the pilot wouldn't stay on for a long time and also when I turned the thermostat on burner went out after few seconds.
The problem was that the air intake screen under the burner had water on it and air canot make it through. I used a paper towel and wiped as much as I could and it started right up, I could feel the air sucked in when I turned the thermostat up.
Hope someone finds this helpful, I had 3 plumbers that wanted to replace the unit and couldn't figure out why it was not starting.
Posted on Mar 20, 2010
freetek
  • 5568 Answers
SOURCE: I have to turn on
This is not an uncommon problem with 'flash heaters' of this type; for safety, they all require a certain minimum of flow before the gas supply is turned on. Some brands/models have a factory-set adjustment for the minimum flow rate.
You might locate the mfr.'s website, contact them and describe your problem. This can also be caused by the modern flow-limited shower heads not allowing enough water to flow to keep the heater turned on.
If you have a retired shower head, you might try replacing the one currently used to see if it allows enough flow to allow proper operation. Either way, it is a waste of water.
Posted on Aug 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: frigidaire range F10 error and very hot
The F10 F11 F12 F13 F14 Error Codes indicate that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%ER
Posted on Oct 01, 2010
Water got extremely hot and then tripped a breaker. now if i reset the breaker and turn on the hot water switch on the wall, all is good. but when i turn the switch on the hot water heater itself it trips...
Sounds like you have a short in wiring for 120VAC system of water heater. Shut breaker at panel off, and remove cover on back of water heater to look for any burnt wiring at connections such as switch, or thermostat/eco assembly.
Jun 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
Power was shutoff to house at pole all breakers were off.power restored breakers turned on took ashower next day no hot water breaker tripped will not reset water heater reset doesnt work either i have a...
according to your problem, the power was cut to the house; then power was restored and everything went back on that was on except the hot water heater. when you tried to reset the water heater breaker, it wouldn't reset. the hot water heater also won't reset. the problem is not w/the breaker, the problem is w/the hot water heater. you need to buy a new reset for the hot water heater which means a new control unit, since the reset is hooked to the contol unit. this is answered by an electrician w/35 yrs experience. the breaker controls the hot water heater. since the breaker won't reset, the problem lies in the control unit for the hot water unit.
Mar 08, 2011 | Kitchen Ranges
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
Jan 07, 2011 | Water Heaters
81sv-300 Breaker was turned off then back on. 8 hrs later no hot water. breaker was found to have tripped. turned on but still no hot water. thermostats were found to have been at top:140,...
The button could be stuck on the thermostat or needs replacing. You try to reset it by putting the screw driver head against the reset button and bump the handle with your hand to try to free it up. I have tried that and it free up one, reguardless if it didn't you would have to replace it any way if it is bad.
The button should pree in to reset, also check element's out they can short and throw your breaker.
Jul 29, 2010 | Rheem 81VP6S/430126 Water Heater
No hot water
If you checked the reset, then the next thing to check would be the breaker in your breaker box. If that doesnt work start checking the elements. The reset, the thermostat and the elements are pretty much all that can go wrong with an electric water heater, short of a leaky tank or faulty t&p valve. Hope this helps.
Sep 24, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Residential electric hot water heater throwing br
If you reset the water heater the first time you were without, Then odds are it is the water heater. probably an element went back. If the power off check for continuity.
Please rate this response and Good Luck, Phil
Dec 28, 2008 | RELIANCE ELECTRIC WATER HEATER
Kitchen Ranges Logo
105 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
