This is called the Blue Screen of Death or BSoD, this usually happen if u plug in or insert any new hardware. If u have recently added any new hardware, try it out, after plugging off the newly inserted hardware.
providing the actual dump message will greatly increase the chances of a correct diagnostic of the problem. (yes the message actually tells us why it goes to physical mem dump) other than that i'd check the fans and fins for dust buildup (causes overheating)
Hmm... Well a Bluescreen is when your computer crashes, and (as you have found out) preforms a physical memory dump. This can be caused by multiple things. Such as bad drivers, PFN(page frame number) or problems with your memory. When a bluescreen event occurs, the is a technical information which has an error code that can be used to help find the problem. In order to fix this problem, you may have to remove any software, or hardware that you have recently installed. To uninstall software, you may need to boot in safe mode, which is where your computer starts up using the minimal amount of drivers needed, in order to try to prevent the computer from crashing. Here are some useful websites (sorry, my hyperlink icon isn't working):
This is not the problem of drivers it is the problem with the memory when one or more programmes try to occupy the same ram space at the same time if you want to get rid of this problem i suggest you to format your pc once and reload the os.
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
First of all if u r getting the blue screen what is the stop code and what is the error, is it saying physical dump of memory,or it says like stop code; 0x000000ed or something like that,in these case if it is just physical dump of memory and the main thing is from how long r u getting the blue screen,and did u install any new software or hardware,and what u can do is disconnect the ac adaptor and take out the battery from the computer and then press and hold down the power button without the ac adaptor and the battery for one minute and then turn on the computer and still if u get it then reseat the memory of the computer and then reseat the hard drive of the computer and still if u getting it then u need to repair the operating system with the help of the windows operating system disk and if u r ready to lose the data from the computer then u can reinstall the operating system and after reinstalling the os also if u get a blue screen then definitely u need to replace the hard drive of the computer.and if u don’t want to loose ur data u can repair the os with the help of windows os disk.,try it out it will definitely help u out…thanks
hi daget200; can you post the exact error message? its located at the top few lines so that we will know whats causing it. have you inserted a new hardware recently? when does the error occur? intermittent? does it happen when you are playing games or something? pls expound. thanks
