How can i use a recovery disk on a acer aspire 2930, the thing is i have a disk read error and cannot get passed this. I have tried to change the BIOS but nothing has worked.
  • 12,061 Answers
If you have a disk read error it may be the actual HDD IN the laptop, and NOT so much the actual recovery DVD...
Perhaps your DVD unit is faulty, OR the actual DVD itself? To find out, if you get a USB to SATA/ATA DVD Dongle, And test on another PC. Then you could try this as the boot device, and select Boot from removable device in the BIOS, IF it DID BOOT with the original DVD disc, than all good.. Proceede with the recovery.
If NOT, and it still will not read and gives same errors, then you most likely have a faulty, recovery DVD, and you should obtain another. I say this as that Recovery DVD has failed in two boot devices, the actual laptop's and now the USB DVD dongle, and are of differing types, so it is unlikely that BOTH ways of DVD reading would be faulty.
This is of course AFTER you proved your HDD is A OK, again the ONLY way to do this is to use that USB to SATA/ATA DVD/HDD Dongle, and hook up the drive to another PC, and see if the drive is OK, If it is OK, then Your HDD is OK, You may even have to perform a CHKDSK, to check. if the HDD is OK, then problems lay elsewhere, the HDD can now be returned to the laptop.
Posted on Jul 28, 2010
  • georgecook13 Jul 28, 2010
    The restore disk i have received is not faulty, and i am sorry i am very inexperienced and do not know the terms or where i could get a USB to SATA/ATA DVD Dongle.
I have one aspire d260 notebook, but i try to recovery to original factory, i read one error dont complete the instalation. what can i do
Good Day Mcontreras!
Can you tell what operating system you are using? It may be possible that your Recovery disk is already corrupted.
or
Recovery disk detected a hardware error on your notebook preventing the restoration point.
Jul 13, 2011 | Acer Aspire One PC Notebook
I have an acer aspire 2930 but want to restore to factory settings? how can i do this? i have tried once but as i don't have any disk's it will not allow please can you help?
You might find help here on the Acer site. Apparently you can obtain their media recovery disks by clicking on the link to go their order form.
Hope this helps. If you're not particularly happy with Windows Vista, you can download and run free operating systems such as Ubuntu that provide a comparable user experience.
They even have a distribution optimized for netbooks: and it's free !
Sep 25, 2010 | Acer Computers & Internet
Acer aspire 2930 disk read error.
the disk error has to do with your hard disk. The operating system on the drive is corrupt and needs to be reinstalled.
Get the operating system CD that came with your computer and use it to run the installation. By so doing, the problem will be solved.
If you don,t understand this, please let me know so that I can explain further.
Good luck.
Jul 22, 2010 | Computers & Internet
PASS BIOS ACER 2930 ASPIRE
Hi the only possible way to reset the password in the BIOS is to reset the CMOS battery. It is located in one of the panel below the sys (you must have proper expertise to do this) towards the right hand side. The battery is set on a jumper You first need to disconnect all power source i.e adaptor and battery. than remove the panels to try and locate the CMOS Battery. Remember not to tuch anything else or connect any of the cables any where else it may cause a problem for the sys and you. Once the CMOS battery is reset the BIOS password will have gone.
All the best
Feb 09, 2010 | Acer Aspire 2930-4661 Notebook
Laptop does not boot up and recovery from cd gives d2d32 type mismatch error
A couple of things to try in the bios:
1. try changing the SATA mode to IDE for the restore and then back to AHCI mode after it was complete
2. Enable disk to disk recovery mode: To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this
value to Enabled.
Jul 11, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer Aspire One, ZG5 ~ A disk read error occurred, Press Ctl+Alt+
After searching and reading many doomsday comments about this error message and what it means and what caused it, I found the simple solution with the Acer Aspire One ZG-5 mini-laptop displaying the "A disk read error occured... Press Ctrl+Alt+Del to restart" error message, the probable simple solution is to Press Alt+F10 during reboot and the laptop will go into the Acer eRecovery mode.
IMPORTANT NOTES:
  • It may or may not ask for a password or require creating a password, this password will be required to use eRecovery in the future. If you forget this step, you will need the recovery disks in the future to reformat the system.
  • Also please note that depending upon the options you choose you may lose any data on the computer because it restores the original operating system as the computer came out of the box.
  • Also, because restoring or recovery is a lengthyprocess you will need to plug the computer into the AC power supply.
Follow the instructions as they appear on the screen to restore or recover the operating system.
Also, it is a good idea once you have restored or recovered the operating system to go on the Acer website and download any patches or updates available.
Hope this helps.
Donald
donald@seacaptaindonald.com
May 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
My Acer won't boot up
Either the boot area has been damaged by malware or the hard drive is failing.
Changing the boot order to start with the optical drive and using a recovery or installation disk should let you boot so you can run checks on the hard drive.
BTW, a set of 4 recovery disks I received from the system mfr. claim to each be bootable and they definitely are not; there is no reserved space for a boot sector on any of them.
Jan 11, 2009 | Acer Aspire 5610-4648 Notebook
I have disk read error on my laptop -acer aspire 5520
dear sir
5570z driver winxp download parmistion.
thanking
abhishek mohan
Oct 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
