Question about HP ScanJet 3970 Flatbed Scanner
Buttons on the front of my scanner won't work
How do I get the buttons on the front to work. They quit working.
  • tinhquang Jul 31, 2008
    I have the HP SCANJET 3970 and it worked fine when I invoked its functions via HP SOLUTION CENTER. Recently, I found out that the scanner did not allow me to specify the area that need to be scanned as it used to do before. Pls help me figure out what I need to do. Thank you very much. Best. Sister Minh Nguyen
Heard that you can't plug into a hub, that it should be a direct connect to computer
Posted on Jul 13, 2008
My scanner quit working it says no scanner was detected. but it was working
I have a Xerox scanner that disappears. So far the only way to fix it is to uninstall and reinstall the drivers.
Apr 24, 2017 | Office Equipment & Supplies
I got a 2000 Pontiac trans am and every time I turn the car on the driver side window will roll down and it won't roll back up. But the passenger side window works fine. And when the stereo works the...
How about when the radio is on & the key is off or
in your hand,if you open either front door does the radio go off
& do you lose the delayed window feature assuming you have that
If so you problem is a delayed accy relay
Next would be the front door switches
I will give you credit for what you tried
but fail to see why you would switch motor
from door to door,they work powered directly or they don't
I would think your battery would have gone dead by now
if the relay failed to time out or go to sleep
Jul 27, 2013 | Cars & Trucks
My Dell W3707C LCD TV won't quit flipping. The only button that works is the power button. I can hold the channel button down and flipping stops for about 2 minutes and then it starts flipping a
one of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
Oct 29, 2012 | Dell W3707C 37 in. LCD Television
2007 Kia Optima front vents quit blowing air
If you mean the blower motor is not working at times, it can be the motor, a resistor, or the switch on the dash. Could also be a bad connection in the wiring harness.
When the blower won't work, a mechanic would check for power and ground at the motor.
Jul 11, 2012 | 2007 Kia Optima
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
Scan snap won't work
This is a known problem with Fujitsu ScanSnaps. Some units experience the "blue button of death" meaning they no longer respond to waking the driver up when you press the blue button. Customer service is aware of the problem and if you are under warranty you should be able to get a new unit.
Mar 21, 2012 | Fujitsu ScanSnap S1500 Instant PDF...
Scanner is stuck @ bank 1, ch.16 @ freq.155.5800 and wont bugd . HELP ME PLEASE
If no buttons are responding it is quite possilble that a button is physically stuck (when you depress one button and hold it, no other buttons will function). Press and wiggle EVERY button to see if perhaps one is jammed. Rubber buttons especially can get caught under the surrounding plastic.
Let me know if that works.
Jun 28, 2011 | Radio Shack Pro-95 Handheld Scanner
Scanner quite working
Reinstall the driver software and keep pressing the scanning button for 3-4 times to move the scanning head.
Sep 17, 2009 | HP DeskJet F380 All-In-One Printer
Scanner quit
Is the scanner still under warranty? If so, then see if you can get complementary service for the unit. Otherwise, it might be time to junk it.
Feb 08, 2009 | Epson Perfection 3490 PHOTO Flatbed...
PANASONIC DMR-ES46VS Front Panel buttons quite working
I have a Panasonic DMR-EZ47V. All of the panel buttons plus the remote will no longer work. I get a display showing F60. Unit is not very old.
Nov 06, 2007 | Panasonic DMR-ES46VS DVD Recorder/VCR
HP ScanJet 3970 Flatbed Scanner Logo
128 people viewed this question
Ben Johnson
