Question about Dell Inspiron 1545 Notebook
The display on my DELL Inspiron 1545 went blank. The screen was still backlit but apart from that it was black........ I plugged in an external monitor and the display on the external monitorwas fine..... then the laptop screen kicked back into life!!.... Removed the external monitor....... Laptop screen is OK, for now. It almost seems like some kind of video driver problem...... Does anyone have any ideas at all please? The O/S is Vista...... Thanks
    New Friend:
  • 170 Answers
The cable between the motherboard and the screen is probably breaking into.
Posted on Jun 22, 2017
preachw996
  • 1179 Answers
SOURCE: what kind of mother board...
Dell used proprietary motherboards for this model so unless you are comfortable doing major modifications you would need to contact them to see if they have upgrade motherboards for your computer. Sorry. Hope this helps.
Posted on Jul 11, 2009
Geekman
  • 32281 Answers
SOURCE: Black screen- laptop only works with external monitor
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
If your Dell has a S-video output it could connect to a TV or a video device, which allows for a TV option.
Posted on Jul 24, 2009
Geekman
  • 32281 Answers
SOURCE: kindly tell me about the regular maintenance
The maintenance on a computer should be done once a month.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes and then Click OK and Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk does not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click/highlight the C drive and click Analyze - then click Defragment.
When this is completed repeat these steps for the D Drive if you have a D drive.
Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Posted on Oct 12, 2009
mash_jumbie
  • 138 Answers
SOURCE: dell inspiron 1545 went black after i gave it wrong passwords
this definitely a security thing so don't hurt your head you need to send it by a service center to get it restored.
Posted on Mar 12, 2010
bob_computer
  • 3153 Answers
SOURCE: dell latitude D610. Screen goes black. External Monitor OK.
Make sure you have not accidentally used the FN+F5 key
That combination sets the laptop to use an external display.
If using that does not give you a display take a small torch (flashlight if in USA) and shine it at an angle on the laptop screen.
If you can see any sort of picture you would be looking at replacement of some minor parts to the laptop screen
Hope this gives you the information you need. If not add any extra information you may have and lets see if we can FixYa
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Mar 15, 2010
How do i switch a dell inspiron with a broken screen to a vga monitor?
Look at the "F" keys. One of them has a drawing of a screen. Press it and your external screen should work, or, plug the external screen in before youboot up. The pc will detect the external scree and switch automatically.
Nov 19, 2013 | Dell Inspiron 1545 Notebook
Dell Inspiron Black Screen
more likely a fault with the wiring or an invertor board problem
Jan 14, 2013 | Dell Inspiron 1545 Black Intel Celeron 900...
I have a 18 month old inspiron 1545 and suddenly its display went to dead black. But still windows is loading up i can hear sounds and music but can't see a single blink on the display. Don't know...
Hi paramvirgull...
Hook your laptop to an external monitor and see if the screen comes on...if it does then your lcd screen is faulty and needs replacment.
If it does not come on then re-download your video driver/s. If that does not work.
Maybe your lcd inverter or backlight bulb is faulty and needs replacement.
Please take time to rate me thumbs up
Sep 16, 2011 | Dell Inspiron 1545 Notebook
My Dell Inspiron 1545 will not load windows. The screen is lit but it is blank. I have taken out the battery and reinserted. What else should I do?
Is the screen black with the cursor blinking at the top left?
I have a suspicion that the coin sized battery is dead.Go to www.dell.com and get a service manual, replace the coin battery (Lithium battery). Put it all back together and it should work.
Mar 10, 2011 | Dell Inspiron 1545 Notebook
Can't get past main screen were inspiron comes up i have a Dell Inspiron 1545 and can't progress past the first screen, it just goes to a blank black screen with a _
Yes you can fix the issue by reinstalling the OS in a simple way
Follow the steps given bellow
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Dec 01, 2010 | Dell Inspiron 1545 Notebook
Blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
Apr 25, 2010 | Dell Inspiron 1545 Notebook
Dell inspiron 1545 went black after i gave it wrong passwords
Mar 12, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 Broken Screen?
The LCD is definitely shattered, looks like pressure was applied from the back of the screen (Pressed on, laid on etc) and the LCD will need to be replaced.
Several are available on Ebay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1545+LCD&_sacat=See-All-Categories
Service instructions are here
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1183775
Feb 07, 2010 | Dell Inspiron 1545 Notebook
Turn power on and nothing but a black screen dell 1545, any ideas. Is there a reset button?
If it turns on and makes all the normal sounds, hold the screen up to a light and move it around. If you see a very dim picture then your inverter has failed. This can be fixed.
You can also plug an external monitor into the laptop to make sure that your graphics chip hasn't let go.
Jan 12, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 Notebook Logo
145 people viewed this question
Alun Cox
