Clothing stuck in washer - Washing Machines
  • helpsista May 09, 2008
    I have a top loading machine and there's a sleeve stuck below the agitator. How can I safely get it out?
  • 240 Answers
Please give more info. top or front load, make/model.
Posted on Apr 24, 2008
Our whirlpool cabrio washer model wtw8500dc0 will start a cycle. It shows error codes E9 F7 what is the problem?
you either have a bad motor or a piece of clothing is stuck between the tubs,open the lid and see if the tub will spin,if not clothes got down between the tubs.also check the wires down near the motor,sometimes the snap inside the casing from the tub going off balance,if there is a piece of clothing stuck between the tubs you pop off the top plastic part on the tub but first you have to get the top of washer off to do this,usually the clothing will be in the back right side,the metal might be sharp on the tub,i use a coat hanger to hook the clothing and pull it out,good luck and hope this helps,go here to see error codes.
Sep 26, 2017 | Whirlpool Washing Machines
Clothing stuck in washer machine
Is it stuck in the center agitator or the out tub?
Jul 04, 2008 | Washing Machines
Eliminate washer Odor
To clean washer add 1 cup of bleach while washer is being filled with hot water and run entire small cycle. DO NOT add clothes. This will help to eliminate odors and any stuck on dirt/ grime on the sides of the drum before washing clothes. I'm not an expert, just an experienced clothes washer for over 30 yrs. ,
on Oct 19, 2013 | Washing Machines
Clothes stuck under basket
you are over loading your washer. You may have to raise the top to free up the stuck clothes in the upper basket.
Oct 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Stops in the middle of rinsing...leaves some water at bottom-
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
How do I replace a lid switch on a kenmore heavy duty washer model # 22442 my switch is in pieces
I just stuck a wooden clothes pin in the hole to keep the little level in check. My landlord's washer had that problem and he didn't want to pay to fix it. It ran great for many more years after I stuck the wooden clothes pin in it.
Feb 24, 2009 | Kenmore 22442 Top Load Washer
you have something stuck in the pump..a sock maybe or some other small article of clothing
Jan 11, 2009 | Hotpoint -Ariston VVSR1030HWO Top Load...
Clothes stuck under the agitator
you really have clothes stuck under the "wash plate" it has almost zero clearance and would be very hard to get something stuck under the wash plate.
if you do have something stuck, then remove the 1 1/2 inch cap in the center of the plate, then a 7/16th bolt that holds the plate down. then grab the wash plate and lift up to remove it.
next time check your pockets and dont let this happen again, it could ruin the outertub by cutting a hole thru it and then leaking.
Jan 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Hello, Our Maytag washer drum is stuck
Hello, the most common problem was clothing objects getting stuck between the inner tub and the top tub cover, run your fingers between the two and see if you feel any stuck clothing (socks) for example. Good luck
Dec 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Drum is stuck
Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub. Open washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. keep a rag nearby to dry up spillage of water when removing the rubber host. Good luck !!
Jul 01, 2006 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
