Question about Toshiba SATELLITE A10 A15 A20 A25 A35 A40 A45 SATELLITE PRO M15 SERIES 15 INCH XGA LCD DISPLAY -LQ15 (LQ150X1LHC3B) CD-ROM Drive
Toshiba satellite pro a40 power problem
I have a power problem with the above laptop. For the vast majority of the time it shows no lit LEDs on the front but very ocassionally they will light for about 30 secs. It is the same with the battery in or out.
This is the type of end connector to the charger:
http://www.easy2pc-chargers.co.uk/toshiba-satellite-pro-a40-131-ac-adapter.html?source=googleps
If looking end on we call the pins left to right 1 to 4 then these are the readings i get.
1-2 6.1V
1-3 6.1V
4-2 6.1V
4-3 6.1V
The problem is further complicated by the fact i've ordered a replacement charger and when i first plugged it in the LEDs lit for about 5 secs and after that nothing. The new charger has an LED on the block whixch is not lit and i measure no Voltage whatsoever on the equivilent pins on the new charger.
I've stripped the laptop down and with the original charger i measure the same voltages on the quivilant pins on the motherboard.
I'm confused about the voltages but the original charger worked for at least a month no problem. However it is rated at 15v.
Any help appreciated.
  • Toshiba Master
  • 17,326 Answers
There is no power on the cable that comes from the mains to the power block. Check the cable for continuity.
Posted on Mar 03, 2017
Bogdan
  • 198 Answers
SOURCE: Toshiba Satellite 1135-S125 front LED indicators gone weird
Hi The strange operation of those LED's is most probably an error mode indicator. If a laptop fails to power on corectly it will use those LED's, lighting in a specific pattern to signal the error. That's an example. In your case something was damaged in some way because the error code indicator is still acting like there is an error. You may try to reset the BIOS to factory defaults (small chances that this will work) and leave the laptop unpowered for about 1 day. If the problem is still there you will need to have it fixed in a service center. By comparing the LED lighting pattern with information from the Toshiba service catalogs they will be able to tell you what kind of error had happen for wich the LED's to light in this manner. Sorry for my bad english, I live in a non-english speaking country. Good luck and don't forget to rate any answer received from this site.
Posted on Mar 05, 2007
flipbooks
  • 177 Answers
SOURCE: Toshiba Satellite Laptop Power Failure (A105-S1013 System Unit)
Okay, lets troubleshoot this:
1)Does your laptop run on battery alone ?
yes )test your jacks continuity to the motherboard using a continuity tester or Digital Multimeter.
a)test between the center contact and the motherboard.
b)test between the outside metal cover of the jack ,and the motherboard.
c)If either of these fails continuity,replace the jack.
2)does your laptop now power up on AC ?
yes)Stop
No)Try the BIOS upgrade.
Posted on Feb 10, 2008
mewms_14904
  • 1027 Answers
SOURCE: ac led blue battery led amber will not power on
Check with toshiba, they have an update on this link
On my Toshiba M105-S3051 the reset switch is a pin hole above and to the left of my microphone jack on the front.
Posted on Mar 27, 2008
SOURCE: Toshiba Satellite L25-S119 Does not Power on
The Toshiba laptops are famous for the power jack wriggling loose from the motherboard. Once it gets so loose the adapter power stops and it uses battery power until that runs out. You can usually move the power cord around until it starts working again but this is just a temporary fix and the jack will eventually need to be replaced. Most computer shops charge between 100-250 bucks for this service.
Posted on Jul 17, 2008
RescueTechLA
  • 2653 Answers
SOURCE: Toshiba Satellite A135-S4527 Charger problem
Get another laptop.
The A135 is a lemon.
Problem is either with the dc jack on the board or more than likely the motherboard is damaged.
I've repaired a number of A135's and 95% of the time motherboard had to be replaced.
Sorry for the bad news, but I hope this helps.
Posted on Mar 02, 2009
Toshiba satellite a40-s270 won't turn on
Either the power supply is not working or the battery has failed and will not hold a charge. If the laptop is 3 or more years old, the battery is the likely suspect.
Feb 12, 2010 | Toshiba Satellite A40-S270 Notebook
A neet drivers for my Toshiba SATELLITE A40
You can download them from here, http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU&mode=allMachines&action=search&teddProduct=532&selShortMod=370
Jan 26, 2010 | Toshiba P000392200 - Satellite A40, A45...
The m and caps lock keys on my Toshiba satellite
Bad keyboard. This series have a higher frequency of keyboard problems because ... well .. the keyboard cable got folded by design. Just replace it. The A40's uses the same keyboard as a A10, A15, A55, A60, A64, 1400, 1405, 1410, 1415, 2400, 2405, 2410, 2415 ... and many others. A new replacement keyboard should run about $20 on eBay.
Replacing the KB is easy: lift up the power button board above the keyboard, remove the three screws holding the keyboard down, then remove the keyboard connector cover panel, and you'll be able to disconnect the keyboard.
Oct 11, 2009 | Toshiba Satellite A40 Notebook
How do i get to the Ram in a Toshiba Satellite pro A40 laptop
You can view/download your Service Manual here:
http://www.notebook-manuals.com/laptop-manuals/service_manual_for_TOSHIBA_Satellite_A40_15231a7ce4_TA40_EN.pdf
Which has pictures and instructions for everything you'll need to know about your A40.
If this helps out, please write a testimonial- Thanks!
Oct 10, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Toshiba Satellite Pro A40 Can't find RAM memory
The memory is located under the keyboard
Remove batt and cables
open screen
pop out the rectangular panel surrounding the on off buttons
remove the 3 screws and lift up the keyboard to access the memory
Dont ask me why they made it this complicated
Manual can be got here
http://209.167.114.38/support/download/files_downloads/SA40/SA40EXUM.PDF
Sep 05, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Dont know how to change ram in the toshiba satellite pro A40
Flip it over and loosen 2 screws holding a panel in the center of the laptop.
Once door is removed, it will expose ram modules.
pry locking tabs out, and module will spring UP. remove, and replace reverse of removal.
Jan 12, 2009 | Toshiba Satellite A40-S270 Notebook
Toshiba satellite pro psa45e-007n1-en manual
Also, Is it "Toshiba Satellite" or "Toshiba Satellite Pro"?
Sep 14, 2008 | Toshiba P000392200 - Satellite A40, A45...
Toshiba SATELLITE A10 A15 A20 A25 A35 A40 A45 SATELLITE PRO M15 SERIES 15 INCH XGA LCD DISPLAY -LQ15 (LQ150X1LHC3B) CD-ROM Drive Logo
98 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
