Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Read only attribute when plugged on a mac
Hi there!
i've got a 250 gigs freeagent external hard drive, ntfs, on a window xp pc, i tried to connect it on a mac to get some data but i can't add anything on it as the drive is seen as "read-only" with that mac.
I tried to select all files and untick the read only attribute in the properties on my pc with no success..but i only have this problem using it with macs for some reasons.. any ideas? help please! thanks!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
You can enable read write access to an NTFS partition using MacFuse a free software available in the internet.
Please go to http://code.google.com/p/macfuse/ and click on the download link and you can get the dmg version of the file.
Also you can have a more faster software here : http://macntfs-3g.blogspot.com/
If you are finding any troubles in installing or using this software please let me know
Best Regards NextDoorNerd
Posted on Jul 28, 2010
Can i transfer information to a mac
If the external hard drive has been formatted on a PC in NTFS file format then the MAC cannot read data off this hard drive.
The FIX..
Connect the USB external hard drive to a Windows computer and copy your data off this hard drive to the computer.
Then format the external hard drive in FAT32 file format. (the MAC can read and write to data to and from a Windows PC)
Now copy the your data from the computer back onto the external hard drive.
Now you can connect the external hard drive to the MAC and download your data to the MAC.
Feb 22, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
I just bought a Seagate 2 TB desktop drive for Mac and PC, it works on my PC but nothing happens on the MacBook
If the Seagate hard drive has been formatted on a PC in NTFS then the MAC cannot read and write to this hard drive.
To exchange data between the PC and MAC then the Seagate hard drive needs to be formatted on a PC in FAT32 not NTFS.
Dec 12, 2012 | Seagate FreeAgent GoFlex Desk 2 TB USB 20...
My Seagate FreeAgent Go250GB become write protected for Macbook, but works fine on windows laptop. How can I fix this issue?
It's probably formatted to the wrong filesystem; Macs prefer HFS+, Windows prefers NTFS, but they both can read and write FAT32. I'd recommend using the Mac's Disk Utility application to reformat the drive to be FAT 32 (but be careful, this will erase the external hard drive, so back up first!)
Apr 04, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
May 03, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
I have a 230 gb FreeAgent Go external drive.
I think the solution that meeknotweak gave is a little bit twisted. First and foremost you can not be able to format a 230gb hard drive as a FAT or even FAT32 simply because that FAT and FAT32 is only set to be used and can be used only if your drive is less than 40gb. If your drive is larger than 40gb then the only option is to format it using NTFS.
Second you can be able to format and set the volume format of the drive under the ERASE tab of the DiscUtility on Mac. Not in "RAID" tab.
This is the right way to do it......
If you plan to use the external HD into a PC or Mac, you should first plug it into a Mac Computer and format it using the Disc Utility. Choose the Erase Tab and select Volume Fomat. Make sure that you choose MS DOS. Only Mac OS can format a drive of any size to a FAT file system. If you have already formatted it you can now be able to use it vice versa.
One more thing if the HD is formatted as NTFS, Mac OS can read it but can't write on the drive. So that's why you need to make it as a FAT so that it would be readable and writable to both OS. Also make sure that the folders and files that you're transferring into the HD doesn't contain special characters. Mac OS can recognize those special characters on a file but windows can't.
I hope this clarifies everything.
Aug 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I plugged my seagate into my mac OS and backed it up first, then went to my pc running windows xp and tried to locate the seagate drive and couldn't. Can I only use the Seagate on one machine or another?
If you are planning to use the Seagate Hard Drive on a PC and MAC better format it on your MAC Computer thru disc Utility and choose MS-DOS. This should solve the problem.
Mac has the ability to recognize a FAT, NTFS and MAC File System for the hard drive but the PC Computer cannot recognize MAC File System.
Check on your mac the File system of your hard drive.
MAC OS Extended
MAC OS Extended (Journaled)
If this is the file system then you now know that it will not be read by PC.
Also formating it with the use of PC will only result in an NTFS File System, and it can be read by Mac but it is only in a Read Only mode. You cannot copy paste or even erase on the drive having an NTFS on a MAC.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Formatting my Freeagent 1tb external hard drive for my Mac?
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Mar 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
FreeAgent Drive is Read Only on Mac OS X
OK, after having read through these responses and having tried some different things, I wanted to post what worked for me, because there seems to be some confusion here. First of all, I took the route of trying the ntfs-3g driver. I downloaded it and looked at the directions for a Mac. I have only had my Mac for a little over a year and working with Fink or whatever was not user friendly, so I looked elsewhere. It turns out that Mac does INDEED do Fat32. As one of the other sites that I read says, it is not really very clearly done, but if you use the Mac disk utility application (it comes with Mac OS - I am using 10.5), then you can reformat the disk. It says "MS-DOS (FAT)" for creating the partition, but if it is a large partition, then it will automatically use FAT-32. So I have just formatted my 1.5 TB Free Agent drive with that and copied a .DOC and .PDF file onto the drive. It works fine on the Mac. Then I take it over to my Windows Vista machine, plug it in, and Windows Vista recognizes it, opens the Doc file in Word, the PDF in Adobe Acrobat, and it sees all of the disk space on the drive (after formatting, it says it is actually a little over 1.3 GB - Western Digital stretches it a bit by calling it 1.5 GB). Anyway, the bottom line is that it seems to work like a charm. One caveat is that apparently formatting such a disk with Windows Vista is limited to 32 GB partitions (see MS docs here - http://technet.microsoft.com/en-us/library/cc766145.aspx). However, that seems to be arbitrary and set by Microsoft and is not a technical limitation of the FAT32 technology. So that is how it worked for me.
Jan 04, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Why won't My external Hard drive work on a Macintosh
You probably formatted it with an NTFS filesystem. The Mac won't read NTFS drives. You will need to reformat the drive (after backing up the data that's on it) with a FAT32 filesystem. AFAIK FAT32 is the only filesystem that can be read by both Mac and Windows.
Dec 04, 2007 | Western Digital 250GB ELEMENTS EXTERNAL...
FreeAgent Drive cannot be Modified?
The problem with the compatibility between your external drive and your mac is that freeagent drives are formatted in NTFS and the Mac uses FAT32. Mac's can read from NTFS drives but cannot write to them. I'm afraid that the only solution is to re-format the drive in FAT32 format if you want to be able to write to it.
Jun 06, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
252 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
