Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch WFF1401 motor does not turn
Machine stopped rotating the drum and blew fuse and lifted MCB at some point in wash cycle. The direction/speed selection relays on the PCB are clicking in and out as they should and using a meter on the motor 6 wire plug I see 240V across pins 1(or2) and pin 3 and a switching 25V across pins 1(or2) and pins 3, 5 and 6 which switches from 0 to 25V The brushes were very worn and have been replaced and re-fitted twice. If I knew what volts I should see on the various pins I would be able to determine if it's the control card (not worth replacing at £180,) or the motor. I have not pulled the motor out myself so not sure if there is a taco device. Is the switching 25V expected? The only capacitor is on the mains inlet and I sassume nothing to do with starting the motor
  • steve_haycoc Jul 28, 2010
    Bosch WFF1401 washing Machine stopped rotating the drum and blew fuse and lifted MCB at some point in wash cycle. Now the unit goes through it's cycle water in water out etc, and the direction/speed selection relays on the PCB are clicking in and out as they should. Using a meter on the motor 6 wire connector I see 240V across pins 1(or2) and pin 3 and a switching 25V across pins 1(or2) and pins 3, 5 and 6 which switches from 0 to 25V as the relays select The brushes were very worn and have been replaced and re-fitted twice. If I knew what volts I should see on the various pins I would be able to determine if it's the control card (not worth replacing at £180,) or the motor. I have not pulled the motor out myself so not sure if there is a taco device. Is the switching 25V expected? The only capacitor is on the mains inlet and I sassume nothing to do with starting the motor
  • 11,896 Answers
The switching 25 volts is should be 0 when off and 25 when activated
I would measure voltage at the motor. If voltage is correct, then measure the motor with an ohmmeter and see what you get. You should have a strong reading at the motor. If not, motor should be replaced. Can you spin the drum freely by hand? If not, check the drum bearings
Posted on Jul 28, 2010
  • steve_haycoc Jul 30, 2010
    I will pull the motor and mega down the various windings and also check segment by segment at the comutator to check I don't have a rotor winding down to earth. If I plug the motor connector in TURN THE POWER ON and initiate a cycle, I don't get a fuse pop or the MCB lift so if something did short in the motor it's not shorted now.
    Not being familar with small multispeed motors the 25V switching on an off threw me a bit as I expected higher stator voltages but if 25V is about right then there is obviously nothing wrong with the control card and the fault has to be with the motor? As the capacitor is directly on the mains inlet before any card or component in the machine I assume it is purely for smoothing and plays no part in motor starting, unlike me old dishwasher where the single speed motor was capacitor started.
    Thanks for the help.
    steve H
  • Bosch Master
  • 12,061 Answers
Actually, the Capacitor can short and stop the entire thing, Whenever a unit blows a fuse or breaker, it is usually something major, and is usually some form of short circuit, or very close to one.
As such, it can be an easy thing to look for as you are looking for a short circuit between Phase and Neutral/Earth... that simple... so meter out the Componentry until you find your suspect component(s).
The Voltage on the Pins may be OK, but the only way to know for sure is to consult a manual.
One really must get a service manual, as inside this are ALL Voltages circuits etc. I have Googled, but have not been able to find a manual, you may need to contact Bosch direct, I am sure they will supply you with a manual.
Below is a DIY self help washer repair website.
http://www.washerhelp.co.uk/diy-repair-help.html
However with a unit such as this, it may simply be uneconomic to repair, as apposed to putting the money into the repair into purchasing a new unit, with a warranty.. Often these days the cost of repair is almost as much as a new unit.
    The machine is still going through the cycle letting in water heating and pumping it out etc., and the motor control relays on the circuit board are sequencing and I get these switching 25V voltages at 3 positive pins on the motor connector plus a 240V at one pin. I have not taken the motor off yet to check where each pin goes (Brushes or stator windings) but I will.
    There is no dead short anywhere now with or without the motor plug on and the capacitor which is simply on the mains inlet cable is obviously working (At least with no real load).
    I very much doubt that Bosch will be very forthcoming with a service manual even to a chartered Engineer like myself.
    I gues my one question to tou is do the 25V switching power connections to the various coils in the motor sound about right is this the kind of voltage you would expect to the stator give a 240V supply to the brushes/comutator
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Bosch wfo2866gb wont work
Possible that the control panel had failed, there is a fuse within the control panel which needs to be checked. Most probably if this fuse has blown there is a short within the board which need to be confirmed for a board failure.
check this link to remove the panel: control panel
Jan 10, 2013 | Washing Machines
I have a LG WM0642HW washing machine. During the wash and rinse cycles the machine runs really rough and will not turn the drum over. Sometimes the machine will stop and go into the LE error. I have...
Your problem requires very skilled LG technician to check the wiring circuit from the control board to the motor and hall sensor. Very possible that the control board is bad but highly unlikely. Suspect the wiring harness with high resistance to the motor.
Good luck
Jun 16, 2011 | Washing Machines
Lr code
HI, this is an electric motor issue. its possible that it is windings failuer or , the hall sensor may be bad. It is recommend to cal for service in this case. the motor will need to be replaced.
**NOTE(((It is also possible that your issue will be a Motor Control Board issue as well. you can confirm the issue by manually rotating the drum. If the drum can be turned easily with very little resistance, this will confirm MCB failure. if there is considerible resistance when manually turning the drum, this will lead to the motor failure.))
Jul 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
F05 Fault code
this will be the motor brushes
Jul 07, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfk2801 washing machine drum does not rotate
Remove rear panel and check the belt is o/k, if it is, then remove belt, undo 2 bolts that hold motor, unplug the motor connector, lever motor back with a screwdriver, and remove motor.
Check the brushes, they should be at least 5mm long, \any shorter, then replace.
Plz rate my solution.
TRhanks.
Jan 11, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing machine won't spin or rotate
Sounds like the motor brushes need replacing, you will have to remove the motor to do this.
Hope this helps.
Please leave feedback.
Nov 29, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch model WFF1401 : Noise like a Boeing 747 @ top speed @ the end of the spin cycle otherwise all noises sound normal and no effect on washing performance. Main drum bearing failure??? Easy to mend ? ...
This usually indicates that there is an issue with the motor or rear bearing. This can be isolated by first removing the power from the machine the removing the inner rear panel from the machine. You should be able to see the belt and motor. You can spin the belt off easily then reapply power and place the machine in a spin. Keep clear of the motor as is spins around 18000 rpm. Let the motor stop and remove power from the machine. You can spin the inner tub by spinning the large pulley by hand, if there is a excessive noise or grinding feel then the bearing will need replacing. The belt can be spun back on and the machine run with the rear cover off but again be very mindful as this cover is there for a reason.
In most of the cases the moise is from the motor itself. There are rebuild kits available but they are mostly a waste of money. The motor if worn should be replaced. They should carry a multi-year warranty, check your manual.
Jul 28, 2008 | Bosch Washing Machines
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
270 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
