Question about Kyocera Mita Office Equipment & Supplies
Error c2550 on kyocera mita km 8030
Error c2550
5 Suggested Answers
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
Posted on May 26, 2009
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
bolinlamar
  • 157 Answers
SOURCE: kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Posted on Sep 18, 2009
SOURCE: DISCULPE REQUIERO SABER EL ERROR A 400 DE MI
bonjour ,j'ai une photocopieuse kyocera km 1505 et me marque le message erreur A400 ,y a t 'il quelqu'un qui pourrait me dire quesque c'est ce message là je vous remercie d'avance
Posted on Jul 19, 2010
Eroor code 4200
your problem is not the dv unit it is the laser that makes the image on the drum
Apr 27, 2014 | Kyocera Mita Dv-650 Developer Unit For...
Solution of error code 7410 for kyocera mita 5035
When Your Kyocera Mita KM 5035 Indicates Code 7410, It's the problem with your Drum Unit Or Drum. You Can Solve This Problem Either By Changing If You Have Another Drum Or Buy A New Drum Unit.
May 23, 2012 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Code erreur
c610Bitmap (DIMM) problem
Sep 08, 2009 | Kyocera KM-1510 Copier
What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
Feb 12, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Please help me
C2550 = Drive Motor Problem.
Try to reset it first. Enter the numbers "10871087" on the keypad. Enter 906, press start, Press Execute on the touch panel. The machine will reboot.
If it comes back, you may have a bad drive motor.....or something else is dragging it down. Check that the developer unit turns. Check that the fuser unit turns. Check that all the gears in the transport unit turn. Maybe one has a bad tooth.
There is a double gear that sometimes causes the metal to flex on the transport unit frame and it doesn't mesh like it should.
Jul 29, 2007 | Kyocera Mita (km-c850d) All-In-One Printer
404 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
