Question about Ricoh Aficio 1013F Copier
Elements of the test chart S5S - Ricoh Aficio 1013F Copier
Heated drivers seat dont work on my 1998 lincoln contenital
It could be the heating element or the Driver heated seat module ! Do you know anything about automotive electronic's ? Circuit testing with a DMM - digital multi-meter ? This system has a element in the seat an the back . None work ?
  • Heated Seat Inoperative
  • Circuitry open/shorted.
  • Damaged heated seat heater elements.
  • Damaged heated seat module.
  • Damaged heated seat switch.
  • GO to Pinpoint Test G .
PINPOINT TEST G: HEATED SEAT INOPERATIVE G1 TEST HEATER ELEMENTS
  • Disconnect connectors C352 LH ( C356 RH) at heater modules.
  • Using an ohmmeter, measure resistance of heater elements according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 12 1067 (P/LB) 9 1066 (GY/LB)
Is resistance of elements 2.5-10 ohms?
Yes No GO to G2 . GO to G4 .
The seat heater module is under the driver seat .
G2 TEST HEAT SENSORS FOR OPEN CIRCUIT
  • Using an ohmmeter, measure the resistance of sensors according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 11 1063 (O/LB) 10 1062 (R/LB) 6 1061 (BR/LB)
Is resistance more than 10,000 ohms?
Yes No REPLACE trim covers. RESTORE vehicle. RETEST system. GO to G3 . G3 TEST HEAT SENSORS FOR SHORT CIRCUIT
  • Using an ohmmeter connected to a known good ground measure resistance of Circuit 1063 (O/LB) at Pin C352 LH; Pin C356 RH.
  • Measure resistance of Circuit 1061 (BR/LB) at Pin C352 and Pin C356 .
Is resistance 0 ohms?
Yes No REPLACE trim covers. RESTORE vehicle. RETEST system. GO to G6 .
G4 TEST CIRCUITS BETWEEN HEATER MODULE AND HEATING ELEMENT CONNECTOR
  • Disconnect connectors C353 and C351 LH.
  • Disconnect connectors C355 and C354 RH.
  • Using an ohmmeter, measure resistance of circuits between module connector and heater element connector according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 12 1067 (P/LB) 11 1063 (O/LB) 6 1061 (BR/LB) 10 1062 (R/LB) 9 1066 (GY/LB)
Is resistance less than 5 ohms?
Yes No GO to G5 . SERVICE suspect circuit for open. RESTORE vehicle. RETEST system.
G5 TEST HEAT ELEMENT AND SENSOR CIRCUITS FOR SHORT TO GROUND
  • Refer to Circuit charts in G4.
  • Using an ohmmeter connected to known good ground, check resistance of circuits.
Is resistance less than 10 K ohms?
Yes No SERVICE suspect circuit for short to ground. RESTORE vehicle. RETEST system. Circuits satisfactory. REPLACE trim cover. G6 TEST HEATED SEAT SWITCH POSITION 1
  • Disconnect connector C352 LH ( C356 RH).
  • Make sure switch is in position 1.
  • Using an ohmmeter measure resistance between Pin C352 , Circuit 1018 (LG/O) and Pin C352 , Circuit 1019 (T/LB).
  • Measure resistance between Pin C356 , Circuit 579 (BK/O) and Pin C356 , Circuit 580 (BR).
Is resistance between 2.0 K and 2.75 K ohms?
Yes No GO to G7 . GO to G14 .
Jan 07, 2018 | Lincoln Cars & Trucks
Model MER6772BAB - Top heating element does not work in top oven however it is a brand new heating element. How do I fix this?
You can perform this test:
Test Mode: Accessed by holding Cancel and Broil keys down for 3 seconds within 5 minutes of power up. The test mode cannot be accessed if the oven temperature is above 400?F. When test mode is activated all digits will display "-". To exit the test mode press Cancel or auto exit occurs 16 seconds after last key pressed.
See attached chart for help determining what each ket pressed does
gemini range test press-vuvts55dnhaxpesxfnyb2z0s-1-0.png After you get to the error code page , if there are any stored, write them down so you can tell me what was displayed. Good luck.
Dec 31, 2017 | Ovens
I have a E2EH- 023HB Intertherm electric furnace. The contactors are sparking after furnace is turned on for a few minutes
replace contacters, probably old and pitted (remember points in the distributer on older cars?)
Feb 18, 2015 | Intertherm Heating & Cooling
I need a chart that has text features
You can insert custom HTML into Weebly very simply. Look for a chart or table generator online that spits out HTML. Then copy/paste the HTML into Weebly using the Custom HTML element. Good luck!
Nov 03, 2013 | weebly.com Computers & Internet
I want to get a Saleen S5S Raptor but I dont know how to get it
It is a free gift of the expansion known as "Rally." Here is the information about the car, and what packs are released with it.
http://forzamotorsport.net/en-us/news/Rally_Expansion_Announce
Oct 09, 2013 | Microsoft Xbox 360 - Forza Horizon
Installed but not heating
State point-of-use electric water heater plugs in.
Check that outlet has power.
The water heater must be full of water or elements burn out instantly.
Test the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Match voltage to water heater:
This electric water heater, like all electric water heaters, will work on 120Volt, 208-240Volt or 3-phase unbalanced.
But wire size and breaker must match element wattage.
If you have outlet, check the wire size and breaker, and check what other devices are drawing power from same circuit, then add up total watts and compare with charts on link below.
http://waterheatertimer.org/Color-codewire.html#water-heater
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 20, 2012 | Water Heaters
Machine filling & draining ok, but water not getting hot. Any ideas? Cheers Tony.
Tony -
Your heating element has probably burnt out, but it's possibly just a break in the wiring or a bad connection to the element.
You need to gain access to the element to do some resistance/continuity testing to find out which of the above is the problem.
Hope this helps.
Oct 14, 2010 | Dishwashers
My dishdrawer gives a F4 code. What does it mean?
The F4 code means that the machine has sensed that the water temperature is not rising while the heating element is energized. There are tests to perform to determine if this condition is caused by a faulty heater plate or the machine's controller. The heater element relay can be energized in the diagnostic test mode, and if the heater does not come on, the heater plate can be tested with an ohm meter. Changing a heater plate is a fairly complex job and you would want to consult a service manual for the proper procedures.
From below website you can learn how to go to diagnostic mode and the reference chart
http://www.fisherpaykelparts.net/techsheets/603.pdf
Thank You
Sep 06, 2010 | Fisher and Paykel (IWL12)
I cannot use fill colour for shapes, text boxes etc on either Word or Publisher -Office 2007 I click on fill colour but shape remains blank - a series of dots do appear around the shape.
Apply a different shape fill You can fill a selected shape (such as data markers, titles, data labels, or a legend) with a solid color, gradient, picture, or texture. You cannot use shape fill to format lines in a chart (such as gridlines, axes, trendlines, or error bars).
On a chart, click the chart element that you want to change, or do the following to select it from a list of chart elements:
  1. Click a chart. This displays the Chart Tools, adding the Design, Layout, and Format tabs.
  2. On the Format tab, in the Current Selection group, click the arrow next to the Chart Elements box, and then click the chart element that you want to use.
On the Format tab, in the Shape Styles group, click Shape Fill
  1. Do one of the following:
    • To use a different fill color, under Theme Colors or Standard Colors, click the color that you want to use. Tip Before you apply a different color, you can quickly preview how that color affects the chart. When you point to colors that you may want to use, the selected chart element will be displayed in that color on the chart.
    • To remove the color from the selected chart element, click No Fill.
    • To use a fill color that is not available under Theme Colors or Standard Colors, click More Fill Colors. In the Colors dialog box, specify the color that you want to use on the Standard or Custom tab, and then click OK. Custom fill colors that you create are added under Recent Colors so that you can use them again.
    • To fill the shape with a picture, click Picture. In the Insert Picture dialog box, click the picture that you want to use, and then click Insert.
    • To use a gradient effect for the selected fill color, click Gradient, and then under Variations, click the gradient style that you want to use. For additional gradient styles, click More Gradients, and then in the Fill category, click the gradient options that you want to use.
    • To use a texture fill, click Texture, and then click the texture that you want to use.
Tip If you don't like the change that you made, you can undo it immediately. On the Quick Access Toolbar, click Undo default.aspx?assetid=za101819851033, or press CTRL+Z.
Jun 01, 2010 | Microsoft Office Professional 2007 Full...
I have a Bosch oven model HBN58066OB. It was used in an exhibition and de-commisioned. The element wires were disconnected for safety reasons and then re-connected. I think the wires are connected...
HI
Step 1: If the oven element doesn't work, first check to see if the range is receiving power. Don't overlook the fusing system inside the range.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale.
Step 4: Remove the screws or plugs that connect the element to the power. Remove the retaining shield, which is usually held by two screws, and remove the element from the brackets that hold it in the oven. The element is usually held in these brackets by screws.
Step 5: Clip the probes of the VOM to each element terminal. If the element is in working order, the meter will read from 15 to 30 ohms. If the meter reads higher than 30 ohms, the element is faulty and should be replaced. If the element tests all right but doesn't work, the problem may be at the terminals. Make sure the terminals are clean and tight at the element connections.
Oven and broiler elements cannot be tested without a VOM. If you don't have a VOM, take the element to a professional service person for testing. The problem is usually a malfunctioning element; however, you aren't risking much by replacing the element without a professional test.
Oct 13, 2008 | Kitchen Ranges
349 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
