Question about Protron PLTV-37 37 in. LCD Television
Inherited a Protron 37" and want to know if it's Digital TV ready?
I just inherited a Protron 37" without manual, and I wanted to know is this a digital ready TV or do I need a convertor box?
    Sergeant:
  • 280 Answers
It depends on when it was made.. Look on the back and if it was made before last year it may not be digital.
Posted on Jun 20, 2008
Do I need a convertor box or is this Digital ready?
That set has both digital and analog capabilities, so no you dont need to get a converter box.
Mar 26, 2014 | Samsung HC-R5245W 52" HDTV
What do ineed to watch this tv now that we have digital services
Yes you do. Not only do you need a convertor box but an antenna to connect to the convertor box. The convertor box will have to be plugged in and depending on the antenna it might have to be plugged in. This tv does allow and external antenna to be connected to it. This is where you will attach the convertor box with whatever adaptor you may need. The tv will need to remain on channel 3 at all times.
May 05, 2010 | Coby CX-TV1 5 in. Portable Television
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
Do I Need A Convertor Box?
No, your television has a digital tuner built in. You will not need a converter box. When the switch to digital is made, simply use the auto scan feature to program all of the new channel locations. Instructions found in the manual here - http://www.p4c.philips.com/files/2/26pf5321d_37/26pf5321d_37_dfu_aen.pdf
Dec 27, 2008 | Philips TV Tuner Video Capture PCI Card -...
Can you tell me if my toshiba 20af44 is digital? Will I need a digital converter???
if the tv has a cable ready hook up then it can produce digital the trick is if your tv have satellite or a cable service then you don't need the convertor box but if you don't have none of these services then you will need a convertor box and if you have service provider and the service gets cancelled then you will need the convertor box
Dec 01, 2008 | Toshiba 20AF44 20" TV
DIGITAL READY?
found phone number and called phillips. it is ready. any Phillips tv from 05 on is ready. Thanks
Nov 17, 2008 | Televison & Video
Protron service manual
I do not have the service manual for this LCD. I've looking for it as well.
All my work is done without it.
I'm sorry colega i could not help you on this one.
Aug 24, 2008 | Protron PLTV-37 37 in. LCD Television
Protron PLTV-3750
I had the same problem. Do you have a cable box for digital TV? do you have a remote from the cable company? that is programmed to control the TV? get the cable company to unlock the sound control from it (a 3 number code) put your sound up to maximum if you can if you hear faint sound repeat above you should be able to hear the tv then then go to the sound settings and adjust as needed get the cable company to check the box in case it has been zapped by lightning good luck PS let me know if you want to junk it/sell it? they are excellent TVs
Aug 26, 2007 | Protron PLTV-32 Television
Protron PLTV-37 37 in. LCD Television Logo
139 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
