Question about Jandy Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
I am trying to determine if my temperture controller is bad - pn R0058200What should the output or steady state be from the pp and th connectors to the gas valve in order to turn on the valve?
    Top Expert:
  • Jandy Master
  • 7,919 Answers
If calling for heat check to see if 24 volts ac to the brown wire on gas valve if 24 when lighting check ignitor or fuses going to ignitor
Posted on May 01, 2016
2 Suggested Answers
johnsonr1
  • 91 Answers
SOURCE: Laars LG 250,000 Bypassed Safty's But NO Burner Light
Have you checked your pilot generator voltage while everything is connected properly? You may have a shorted wire or limit or even thermostat. If you jump the TH connections on the gas valve, it would lead to shorted, inoperable safety, thermostat.
If everything is connected properly, the MV reading should be 500+, less than this and you are losing power somewhere.
Posted on Aug 22, 2009
Have a Harris Vent Free Propane Gas Log, 65% gas left, the pilot will not stay lit.....any help?
check the pilot generator for proper current. check from PP terminal to TH/PP terminal while pilot is still lit. you should be getting well over 250dc millivolts. if not, replace the pilot generator
Dec 14, 2014 | Heating & Cooling
HI Please tell me how the fan in the front of the engine should work, we had the fan switch replaced when we start the car the fan turns faster before it was slower is this correct, is this how it is...
The fan speeds are control by th ECM. The fans speeds are determined by the temperture and load on the engine. And when you use the A/C. Sometimes you will see them at a low speed , sometimes fast. This is normal.
May 05, 2011 | Mercedes-Benz 190-Class Cars & Trucks
I need a Part. My manual states my model # is 107624-01 or 107624-02. Parts needed are 107710-01 and 108640-01. I can't locate
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Guide Bar Nuts (pn 107710-01) are available, $2.10
The entire sprocket cover (pn 108640-01) is not.
There is a "Sprocket Cover Adjustment Screw Repair Kit" available (pn 108640-MD), $5.95.
There is a "Sprocket Cover Bushing" (pn 107711-01; different model; may require modification) available; $2.10.
The bushings can probably be fabricated with the correct ID metal tubing. I really tried to help.
Are you aware RemingtonPower is no longer in production? Often eBay is the only source of replacement parts. If the replacement parts I located remedy your current problem nothing will remedy a burned out motor. Only you can determine if the money would be better spent toward the purchase of a replacement saw. I suggest a name brand that you expect to be in business for the next 10 years when it will need replacement parts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 13, 2010 | Remington Garden
I have a minimax 250 i can light the pilot but the main burner will not light. i jump the th to th/pp and the pilot goes out.
are you sure your jumping th and th/pp? the labeling on valve is a little deceptive.should use 1st and 3rd terminal on gas valve. if your using correct terminals try same thing with thermostat wires disconnected from gas valve. this will isolate valve from all controls and safties.if it fires valve is good and need to look in thermostat loop for problems. hope this helps
Jul 18, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Pilot is lit, but burner will not come on. I jumped TH/PP to TH then burner comes on. Pilot generator = 350mV.
More than likely the tempature control is defective, since you effectively bypassed that connection. I found a manual for your unit which shows different types of ignition. I'm not even sure if the millivolt system is covered in this manual. Here's the sight
http://shop.solardirect.com/pdf/pool-heaters/gas-pool-heaters/jandy-lite2manual.pdf
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Hayward pool heater pilot won't stay on
a short circuit in the heater wire will cause an immediate loss of all flame, pilot and main; check the wiring diagram and make sure your pilot wires go to the PP and PP/TH terminals; make sure the terminals are clean and the connection is good; you are dealing with .320 volts DC, any bad connection drops the voltage below the required minimum.
Jun 27, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hello, I have all working speakers for the JVC TH-M505 home theater system, but the control center/receiver gave out. Do you know if I can use them with the JVC TH-M606 HomeTheater Control Center? Thanks...
If the JVC m606 requires a stipped wire to connect them then they should be fine just make sure you connect the right speaker to the proper output if your speakers have a specified connector on the end then you would have to cut that off and strip the wire. if your m606 requires a specified connector for the speakers then you would have to change the connectors out for the proper ones.
Mar 07, 2009 | JVC TH-M606 System
Oven temperture is incorrect
If your sensor has a quick connect, try eliminating it and hardwiring the connection. Sometimes the connectors wear from the heat. If this doesn't work, then the control is bad.
Feb 18, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Kyocera KM-1510
BD steady-state problem • BD steady-state problem is detected. (jam code 98)
BD steady-state problem • The VTC detects a BD error for 800 ms after the polygon motor rotation has been stabilizad.
Poor contact of the connector terminals. Defective LSU. Defective main PCB.
Check the connection of connector CN18 on the main PCB and the continuity across the connector terminals. Remedy or replace if necessary. Replace the LSU. Replace the main PCB and check for correct operation.
Dec 30, 2008 | Kyocera KM-1505 Copier
No sound from the amps outputs
field inspection is more accurate than on line and it depends on the personal of the service spechialist.and from here i can not make fair judgement.
Dec 11, 2007 | Audio Players & Recorders
Jandy Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
121 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
