Question about Dremel Variable - Speed Multipro Rotary Tool 395
How to replace brushes?
How to change brushes on Dremel multi speed tool?I can't find a wire hole where I can push the new brush in, then lock it down with a piece of wire until I get the holder part back on. So, there must be another trick.Thanks.
    Problem Solver:
  • 7 Answers
On either side of the switch is a black disk with a notch small enough for a small screwdriver. Unscrew it and take it off to expose the spring. Gently pull the spring out and the brush should be attached. If you encounter resistance, then you may disconnect the spring from the brush. If this happens then push the spring back in and hope you catch the brush; if this does not work, then get creative or take the whole thing apart to get to it. After that, just put the new brushes in and recap.
Posted on Aug 03, 2008
How can i test if it's brushes or speed switch fault on Piggin Dremel
Problem sounds like the switch. Easy to replace and a lot cheaper than a new Dremel. One other thing comes to mind. Blow out the Dremel with compressed air. I could be to dusty and overheating.
Aug 28, 2014 | Dremel Tools & Hardware - Others
Location of brushes on dremel multi max kit
There should be a second brush. Look along the motor - you're looking for a spot where the armature (the part that rotates) is surrounded by a ring of little straight copper-colored bars. That's the "commutator" section. The brushes run against the copper bars.
Look on the outside of the plastic shell - there may be two large plastic screws, one on the outside of each shell half, right about where the commutator would be on the inside. Those are your brush holder screws; you should be able to change the brushes from OUTSIDE the tool without opening it. Some tools are built without external brush holders like that, but most have external brush holders.
If you find external brush holder screws, then track down the second brush and set it aside. It MAY be hanging from the brush holder in one of the shell halves. Unscrew both brush holders and remove them from the shell. Set them aside and reassemble the motor back into the shell. If the brushes are really short, like if they're nearly cube-shaped, then it's time to replace them. If not, try them again.
Insert one brush into each of the holes the brush holder screws came out of, and put the brush holder screws back in. Be careful not to cross-thread them. Try the tool.
If it still won't run, it's possible that an armature winding has given up the ghost and it's time to replace the tool...
Jul 11, 2014 | Dremel Multi Max Kit
Dremel MultiMax 6300 has stoped working Will not turn on.
Mine died also. It's the on off switch. Where can I get parts?
Oct 27, 2011 | Tools & Hardware - Others
I was working with the dremel and it shut down and would not turn back on, the motor was not hot. I'm wondering if it has anything to do with the brushes in the side of the motor housing?
My dremel started doing that too. If I rubbed the sanding drum along a piece of wood, it would start up again. I think the brushes and the copper armature get glazed over with non conductive dust and possibly insulation smoke which disconnects it enough to stall out. Change the brushes to the new ones in the kit. After a year of heavy use mine slowwed down to about 300 rpm and then died. A very nice tool but I prefer the Makita which is about three times this size just because it is longer lived.
Apr 09, 2011 | Dremel 395 Variable Speed Multipro Rotary...
Dremel while runnibg cuts out if i wiggle the case or touch the brush cover it starts back up.
Hi it sounds like you have a brush worn out. I would change out the brushes first and go from there. Brushes are relatively cheap and it is a good investment to check out first. You can get brushes from almost any hardware store that sells Dremel parts and accessories.
Jan 30, 2011 | Dremel Variable - Speed Multipro Rotary...
3981dremel I can not find out how to change the brushes or fit them. Where can I have this service carried out in bedfordshire n
you can change the brushes by opening the two little doors one on the top and one underneath the tool and the brushes will just fall out. you can then pop the new brushes in and replace the little doors. if you are looking for where to bye the brushes then just go on ebay or bye from dremel direct. im not sure how much dremel want for the brushes but i paid £7.58 on ebay.
i hope this has helped.
Sep 04, 2010 | Dremel 3981 01 Professional 1.15 Amp...
Either side of the body are two round plastic caps with a slot in under these are a spring attached to the brush, what you need to do is unscrew the cap with a small screwdriver or the end of the collet nut spanner, and withdraw the spring and carbon brush, check the length of the brush and replace if worn down, replace the brush cap and run the tool without load for five minutes to bed the new brushes in. (if the brushes are ok make sure you replace them in the same orientation as removed).
Sep 02, 2010 | Dremel 395 Variable Speed Multipro Rotary...
New dremel 4000 used very little is missing the brushes and whatever else goes in the brush hole. found the cap laying on the table with no other parts. what do I need to replace???
Dremel has all their replacement parts right on the shelf at walmart, brushes, caps, chucks, the works. You found the cap, the brush is a little carbon square attached to a wire with a spring on it. Real simple. Buy a pair and get it fixed up. My favorite tool.
Jun 25, 2010 | Dremel 4000230 High Performance Rotary...
Have a multip speed dremel 350
clean the slots that hold the brushes, sometimes they get cloged and the springs do not push the brushes all the way to the armeture.
Aug 19, 2008 | Dremel Variable - Speed Multipro Rotary...
Is there a reset button for a Dremel Multi Pro?
When the brushes go on my Dremel, it just stops, sometimes erratically - no smell or burning.
May 04, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
939 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
