Question about Franklin Merriam-Webster Speaking Language Master
Cannot speak what equiptment is there available to use
Do you know were I could get a surround mat for a 14ft trampoline in blue
do online search --or sports equiptment -outdoor equiptment stores /outlets
Oct 31, 2016 | Sport & Outdoor - Others
WHIRLPOOL W8RXEGMWQ TOP FREEZER FACTORY INSTALLED ICE MAKER, CAN I ADD A WATER FILTER OR WHERE DO I PUT WATER FILTER.
although this unit not equipt from factory with water filter,an add on can easily by installed. many different "in-line "water filter options are available, depending on installation, a filter can go either behind the refrigerator, or just passsed the initial water supply connection
Oct 27, 2013 | Whirlpool W8RXEGMW 17.5 cu. ft....
Need the code for a universial remote
if you go to the web site of the remote manufacturer of the remote, you should be able to get the scan process to search for codes
Mar 04, 2011 | Audio Players & Recorders
Tv picture going wider
There's a defective resistor inside the Vertical block of the TV that's causing the problem on your TV. This is something that needs a technician's touch and requires advanced troubleshooting skills. Bottom line is, send it a local tech as they have tools and equiptment that is not available in your garage.
Trust me, you'll be saving yourself a lot of trouble and money.
Feb 07, 2011 | Televison & Video
What colour wires do i need to use to wire up rear speakers on a pioneer 2000mp headunit
should be listed on the unit itself, however if youre attempting an install there are vehicl specific plug-n-play kits available that cure these headaches with out breaking the bank, and they can be found starting around 10.00 and you dont need to hack up your factory harness to install after market equiptment
Jan 17, 2010 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Tangled shutter curtain
I'm not quite sure what you mean by:
However: The link to professional equiptment online help:
http://www.kodak.com/global/en/service/professional/nav/navigation.jhtml?id=0.1.14&lc=en
If you'd like to speak directly to the support:
http://www.kodak.com/global/en/service/professional/repair/eamerRepairCenters.jhtml?id=0.1.14.38.5&lc=en
If helpful pls. rate me and/or give me a recommendation. TXS
Nov 30, 2009 | Kodak DCS 560 Digital Camera
Hotpoint A34 washing machine causing fuseboard to trip
normally on wash machines the common problems are the heating element or the motor or the motor capacitor. Start by pulling both the element wires off then test. If still tripping, disconnect the motor wires.(trial and error assuming no testing equiptment available.)
Sep 15, 2009 | Washing Machines
Vintage capacitor
The closest substitute I could find is a 19000uF/75V from here. Of course you could also try the original parts manufacturer ELNA America Inc.
  • 5770 Warland Drive, Ste#B Cypress, CA 90630
  • Phone number: 714-761-8600, 800-700-ELNA
  • Fax number: 714-761-9188
  • Email: mail@elna-america.com
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 01, 2008 | Audio Players & Recorders
Franklin Merriam-Webster Speaking Language Master Logo
Top Franklin Office Equipment & Supplies Experts
Marvin
Marvin
k24674
Andrew Taylor
Andrew Taylor
Are you a Franklin Office Equipment and Supply Expert? Answer questions, earn points and help others
