Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Have new door gasket for Kenmore 20 Frostless. Is there any sealant that needs to be put on the gasket before installing or do the screws hold it in place? Thanks for your help
  • 74 Answers
SOURCE: door handle loose
they are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
Posted on Jan 10, 2008
  • 1596 Answers
SOURCE: head gasket sealant
As a A S E Certified Tech I Do NOT RECOMEND ANY "QUICK FIX" ADDITIVES Especialy for such a Critical Engine Component
More Costly but Also More effective is to Tear down Engine and Replace Head Gasket as You may have A Cracked Head Or Block That NO ADDITIVE will TRUELY REPAIR PROPERLY
Rough Estemate In USA Midwest $350.00-$600.00 For The Real FIX yep they vary that wide Some of us Love Helping PEOPLE the Rest LOVE THE MONEY MORE
Posted on Jan 14, 2009
  • 240 Answers
SOURCE: My kenmore he2 plus washer door gasket is loose.
it goes on the groove in the gasket at the door , the side view of the gasket would be a V, it goes right in the middle. make sure the gasket is first snug on the metal frame groove. the spring is very tight, start at top then work down, use a flat screwdriver to pry it in at bottom. it may help to wet the gasket
Posted on Apr 28, 2009
SOURCE: Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
Posted on Oct 14, 2009
Testimonial: "Contacted numerous resources to try identify LG dishwasher leak problem, including LG. Found solution,vent tube right here on FixYa. Many thanks!!!!"
SOURCE: oven door handle falls off screw not holding on Kenmore 790.7876
After several unhelpful calls, we called sears parts at 1800-366-7278 and they are sending us a supposedly 'new and improved' door handle & screws (for $44). When we receive it, we'll put up a post if it is actually 'better' or if it's just the same (to save others the same $44 charge). The part comes with a 90 day guarantee. Although I don't feel we should have to pay $44 to solve an obvious manufacturer flaw - we'll just be happy to have an oven that's 'safe' to use again. Fingers crossed.
Posted on Mar 29, 2010
How do i get a gasket replaced on a sears kenmore freezer model 31165
Order the new gasket using your model number- 31165 is not a valid/complete model. Remove the door and lay it flat on the floor, then remove the screws from the upper half of the door perimeter- DO NOT remove all the screws at once or you will be unhappy! Pull the top half of the old gasket away from the door, then put the top half of the new gasket in place and screw it back down. Next, remove the bottom half of the screws and pull the old gasket off, then put the bottom half of the new gasket in place and screw it down. If you try to do it all at once, the door will flex out of plane and won't lay flat when you re-attach it. You might need a hair dryer to soften the gasket if it was deformed during shipping. If you have a newer, press-fit style gasket, just yank it and press the new one in... Door Gasket 241872513
May 20, 2016 | Kenmore Freezers
We have a Kenmore 16, model model 253.8283680, that recently continuously cycles on and off. What could be the problem associated with this?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The normal cycle is: Your compressor will turn on to raise the freezer temperature 20 degrees F. above the set temperature, and then the compressor will shut off, Until the freezer temperature drops 20 degrees F. below the set temperature and again the compressor will turn on.
One of the main problems with this type of freezer is the door gasket becomes crushed over time or the door is so thin it becomes deformed.
Do not try to replace the door gasket. You have to soak the new gasket in hot water for 1/2 hour and then form it on the door.
If you notice a gap in the corner of the door - pull hard on it to get it flush.
Recondition the door gasket - With a hair dryer and a kitchen spatula, heat the gasket and try to expand the gasket by pulling out with the spatula.
You can purchase a special freezer lubricant. Be sure not to over do it. It can make the door hard to open. P/N 542638
1/2 Oz. $12.00.
Mar 19, 2015 | Kenmore Freezers
Kenmore frostless freezer, Model 253-9280413. Food is properly frozen but both outside walls and the top are extremely hot to the touch, particularly the wall to the left of the door which is so hot you...
If your condenser grill is extremely dirty or air flow is not adequeate there will be heat transferance to the cabinet itself.
Highly recommend that you clean your condenser grill (the grill underneath the cabinet) and vacuum as much as you can then blow it out with an air compressor.
Jul 17, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
There is frost in the freezer. I thought it was frostless.
If you live in a humid environment its the water vapor in the air that is turning to frost in your freezer. Every time you open the door you are exchanging the cold dry air in your freezer for the humid air on the outside, and when you shut the door closed its this humid air that turns to frost inside the freezer. If its building up frost faster than normal you might have a door gasket that is leaking the cold air outside thus letting the humid air in, which is turning to frost. Check that your door is aligned properly and that the gasket is secure on the freezer door.
Hope this helps explain it.
Feb 01, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
How do I change the door seal on a gibson UR freezer?
The most important thing is to make sure the new seal is warmed up to room temperature so it is soft and workable. Since the seal on mine is attached to the top door there is nothing to gain by leaving the door attached. Working upside down would leave the door open longer than just taking it off.
If you still have food in the freezer just put blankets over the top until the door is back on. If you have screws holding the seal it will go much easier. Mine has plastic pins that break easily pulling them out.
Get the edges as straight as possible to avoid leaks.
Sep 19, 2009 | Freezers
Mu upright freezer door seal was loose and it is leaking from door would this cause domw food to thaw and can it be fixed
a leaking gasket can cause food to thaw and it can be fixed if a new gasket is avaliable from local appliance parts place..the gasket is held on by the liner which is removed by gently lifting the gasket and removing the screws..the reverse to install the new gasket
Sep 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Door not sealing
After putting a new gasket on you will usually need to form it. You can use a hair dryer to heat the gasket and flat screw driver to form it.
Nov 07, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
95 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
