Question about Hardware & Accessories
I want to set my Vigoro timer #196-036 to water once a day (every 24 hrs) for 1 hour. Seems I don't have this option the closest being twice a day (every 12 hrs). There is no 24 hr setting maybe? help!
4 Suggested Answers
SOURCE: vigoro water timer 196 036 water timer programming
every x days vs every x hrs. (once a day or every 12 hours)
Posted on Jun 29, 2009
SOURCE: I have 2 Vigoro 196-036
It comes out of the holes because the water goes in the holes. That might sound dumb but Vigoro designed these only to be in dry conditions, such as attached to the water line. I used them for sprinklers, but the water poured into the timer so bad it shorted it out in a week. I did find a vigoro timer with no holes and a sealed unit, and they work great. But I can't find them anymore.
Posted on Sep 28, 2010
SOURCE: vigoro 196-036 water timer manual
Here is theinstruction:1. Install the battery2.Use left attor to decrease and right arrow to increase numbers < > to set current time to nearest hour at the time, noting AM and PM3. Repeat above instructions to set "start time: to desired time for day to begin watering4. Use left and right arro <> buttons to set "how often" (watering frequency) to select an hour/day increment (8 hours=3 times per day, 2 days=every other day).5. Use left and right buttons < > to set "how long" (watering duration) to select a min. or hr increment.6Activate the watering program by pressing the Program on/off buttin: a horizontal bar will be displayed to signify the program is on. Press the program on/off again to disable the programTo avoid accidentally changing the current program, the arrow button will be "locked out" or inaccessible if "program on" is selected.To create a new program, press Program on/off if necessary to disable current program.
Posted on Jul 12, 2011
I need to reset the timer on my 633T Krystal Clear pump as we have unplugged the power and we can't get the timer to work.
You know the timer can only be programmed once and it is 24 hrs after the last time it ran. So turn it on at the exact time of day you want it to run every day, set the dial to how many hours to run and walk away. It should start up automatically 24 hrs later each and every day (as long as you have the on switch set to the timer position)
Jul 12, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Vigoro 196-036 water timer manual -- need instructions on how to set timer for the Vigoor 196-036
Jun 12, 2011 | Hardware & Accessories
Have a taco 24 hr timer on water heater of home we purchased. pls descvribe how to set it to circulate the water just twice a day for a couple of hrs. thx, mg
Your question is very big because recirculation systems have a lot of parts and options.
Please open following link for re-circulation system resources that show pictures of how the system works. After reading information, add a comment with more questions.
http://waterheatertimer.org/Water-heater-recirculation-system.html
The page shows two different types of Taco timers. One timer is programmable and the other timer is called analog timer where the timer dial rotates just like a clock. Small pins located on dial face are set inward or outward. As the dial rotates, the pins move a tiny on-off lever that turns the pump on-off. The pump can also be set to operate thermostatically. You choose either timed operation or thermostatic operation using slide-switch located under timer dial.
Look at, and read information on link above. Try some things on your timer so you are familiar. And then add a comment with specific description of your Taco timer, and include what you have done so far.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 11, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
The timer is used on an Electric Point of Use 2.5 water heater. Currently I get hot water only about two hours in the evening. Before it was --on demand. I opened the timer box and one of the timer box"...
No overcharges here Ms bernarda
If I understand correctly you have Intermatic timer with a yellow dial
You have the Intermatic timer hooked to a small 2-1/2 gallon point-of-use water heater
Your point-of-use water heater is working fine
The timer turns on the water heater once a day instead of twice a day
And it seems like one of the tripper pins has fallen off the yellow dial
The tripper pin is missing and you can't find it or put it back.
You can turn off the electricity and poke around the bottom of the timer box and see if tripper pin can be pulled out using tweezers
Do you know Grainger sells Intermatic tripper pins for $1.67 plus shipping?
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Now, if this is not the right answer, you post a response and we can probably help
Oct 21, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
Sep 29, 2010 | Paragon 8145-20 Defrost Timer
Regarding the Vigoro Electronic Water Timer, Model 196 036: How do I program the timer to water every day, in the early a.m., then in the evening? Is the greatest hourly spread per day 12 hrs.? In...
I think you almost have it right, you can program how many hours apart.
4=6 x per day
6=4 x per day
8=3 x per day
12= 2 x per day
24=1 x per day
Then you set how long you want it to be on, but that can't exceed your hour setting. I believe these are the same timers as Melnor. You can go to their web site for manuals. http://www.melnor.com/instructions.php. If you really want exact timing, I'd get a quality electric timer, and then buy a electric valve such as you'd use for a sprinkler system.
Jul 13, 2010 | Garden
My vigoro water timer i bought at home depot will not stay on manual off/om or on its program. I have installed the new 9 volt battery correctly since i can program ok but it shuts off in a short time...
I have a Vigoro 271-687 in which has worked well except when i change the batteries it wont reset and will not work do you have any solutions to this problem i really like this product just dont understand the prob
Jul 01, 2009 | Garden
Vigoro water timer 196 036 water timer programming
Jun 18, 2009 | Hardware & Accessories
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
Hardware & Accessories Logo
236 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
