Question about Hampton Bay 60 In. St. Regis Fan, Ancient Bronze
I have a 60" fan mod# 640-659. The top light will not shut off. The fan & bottom light work fine. What can i check? thanks M. Fitz
2 Suggested Answers
  • 4 Answers
SOURCE: fan & lights doesnt work
If you can find the exact fan at Home Depot, purchase it and return the lemon that you have. I cannot find a hampton bay website. Home Depot apparently buys these directly from overseas manufacturers, so there is no "company" to contact for real support. I had no luck finding my capacitor C61 E185116. Stick with the big names like Hunter in the future. Believe it or not, I received a free trim ring for mine about five years after purchase because it kept falling onto the body. Now that is world-class support!
Posted on Jul 25, 2009
2002 BMW 530i -My a/c quit working and wont come on at all, even the fan only. The rear windows also stopped working but the front windows work fine. Could this be a fuse? if so, how do i determine...
hi
locate your fuse panels for your model and when you open the lid/panel it will have symbols to id each fuse like a door window for a window fuse
it will also have the amp range 5 amp or 10 amp or more for that fuse etc
look at the panel symbols and compare them to the fuse amp range from the bottom to the top so you can match the symbols to the right fuse amp
each fuse has two tips slightly extending from the top of the fuse top so you can use a light tester to test the top and the bottom of the fuse, both sides most light up, if only one side lights check that fuse
some fuses only come on when the accessories is turned on, so they might not work until the accessories is turned on
anyway check any fuses that dont light up and if broken replace them
there are also fuses under the bonnet of some cars so dont forget to check there too
cheers
Sep 04, 2013 | 2002 BMW 5 Series
No flame
when this happens it is usually because of a faulty flame/gas safety valve.
Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
Why wont this model stay powered on
I spent 4hr this morning trying to fix my Samsung t.v. I replaced the bulb, cleaned entire insides of t.v., checked if both fans were running, yes, checked for any corrosion or disconnects on boards/wires the best I could, I read several internet sites an kept checking what was suggested, then I found this one, I disconnected the blue & white sensor wire from top connector(right above the bulb casing). I put one end of a piece of wire in each of the holes -2 holes, it didn't work.. I tried several times...I took my piece of wire out and plugged it back into the sensor, then I unplugged the blue and white from bottom connector, this had 3 holes.. I separated one side of my 1 piece of wire (rope type) into 3 and inserted (snugly) into coupling and my tv is now working fine. I had to try this a couple times and discovered that I didn't have my wire pushed in snuggly. I will replace temp sensor, still need to figure out if I need to replace top or bottom panel, I'm guessing the bottom panel ?????? The standby light and bulb light are both off now, yay. I have a large Samsung t.v. I think 52" that I purchased from Circuit City around 5 yrs ago, model # Hl85086W. The problem I was having; Standby Light was on when I'd turn the t.v. on, would hear a low Beeping Noise from back of tv, the Lamp Light would come on I could hear the t.v. would try to turn on and in seconds the t.v. would just Shut Off, Both Lights would stay on, I'd unplug and plug back in and try again and get the exact same thing, Both Lights would come on/ stay on, t.v. would try to turn on and Automatically Shut Off. Thank you krimi !!!, for taking the time a year ago to post this. Very Grateful! Robin from Indiana I hope this helps someone else.
Sep 08, 2012 | Mitsubishi VS-60707 60" Rear Projection...
My Leviton 6260M is wired to a bath fan according to the diagram provided: Green wire connected to ground, White neutrals connected together, Black wire connected to 'line' feed wire, Blue wire connected...
Countdown timers are made to work with bath fans.
Leviton countdown timers are stout product with 1HP rating.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#6200
It sounds like timer is bad.
Wiring sounds good. Make sure you don't have Load and Line wires reversed. Try reversing Load-Line wires and see what happens.
Another thing that affects electronic timers is line noise/interference. If replacement timer does same thing, then noise is suspect. Try timer on another circuit without fan. Try another brand timer. Update to newer LTB60 Leviton timer. Use cheap circuit tester from home center to check outlet on same circuit.
Apr 04, 2011 | Leviton 6260M-T Timer Switch 10-20-30-60...
Frididaire fridge mod.#FRT21IL5DBA 4 1/2 yrs old. In outside storage room of carport. Stopped running after stretch of low 20's temps. in winter of 2009 Unplugged it, checked coils. Plugged it in when...
Well it should be fine when it warms up, these are not designed to run in anything below 60 degrees, when the temp gets too low it confuses the thermostat and it shuts everything off, as long as the room is above 60 should work fine.
Sean
Mar 30, 2011 | Frigidaire Refrigerators
Hi my friend bought a Toshiba L350 and she said that the HDD/ODD light flashes and makes a sound. the next thing she see is the screen goes black and shut the laptop off. what can i tell her to do.
problenm with hard disk. chaque hdd Smart test.& self Status chaque. both r ok than. chaque the cpu fan. internal temprture if more than 60. mean fan issue.change fan reinstall the windows ok.
i hope it working fine
Mar 18, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Getting close...thanks
egear00; OK, you have voltage, check this:
1. Filters make sure both are clean
2. Check the power supply and check for bad CAP's
3. Check the lamp sensor.
Good Luck, big IRISH.
Aug 19, 2008 | Hitachi 60V500 60" Rear Projection...
Television shuts off after being on for 30-60 seconds.
I just had the same problem with mine (Toshiba 42HP85) The TV was fine and shutoff red light blinked twice, and you can turn it on agin right away then it shuts off again. The problem was there are 2 cooling fans you can here at the top rear of the unit, when they get dusty the bearings wear out and shut off. See if you can here 1 or both fans working. If only one is on, you can get a replacement from coolguys.com for 7.95 ea. model # is on the back of the fan. Replace both while you have the cover off, if that's the problem. The unit shutting off is the computer sensing there is a problem the red light is an error warning. Good Luck!
Aug 12, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Hampton Bay 60 In. St. Regis Fan, Ancient Bronze Logo
79 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
