Question about Whirlpool Duet GHW9150P Front Load Washer
Control locked is on. How do i reset this mode ?
  • 5,911 Answers
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more significant problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Posted on Jul 28, 2010
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
How do I reset my tv without remote control?
Without the remote control, you can not do a factory reset; Can only of the hard reset. There are two methods to reset TVs. The first is simple to do; Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it to reset system [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the website linked here. Pull up older posts. Http://electronicshelponline.blogspot.com/
Service entry mode, adjust and exit procedure to many popular brand are given Beheerder TVs. Never forget to exit the service mode, after all adjustments Have Been done.
Jun 09, 2016 | Televison & Video
The control touch panel is locked in door locked mode wont clear to use other control functions
I appreciate your post, philip hunter!
From my understanding the control panel on your Electrolux range is locked. On the control panel you should see a button near a lock symbol, typically it is labeled control lock, and if you hold that button down for three to five second it should release the control panel. If that does not help release the panel I would suggest performing a reset and you can do that by disconnecting the power from your range for ten minutes. Hopefully this helps. -Matt
Dec 20, 2014 | Electrolux Kitchen Ranges
I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
Nov 03, 2017 | Maytag Refrigerators
Magic chef model# cer3725acw. Using stove top burner.(CAL) Error message came on briefly on touch pad display window. Can't change time on clock,turn on oven,set temp.or timer.Burners work fine. Unplugged...
It sounds like a bad control. Before replacing the control, make sure it is not in Sabbath Mode, Child lock and if all else fails try resetting the control to factory defaults. If none of these work then replace the clock/control part number 5701M827-60. This part runs about $175.00
I attached a cut out of the service manual, to show how to reset the locks and factory defaults
May 27, 2010 | Magic Chef Kitchen Ranges
I lost control of my camera d40x
Go into the menu and find "reset".
Jan 25, 2010 | Nikon D40x Digital Camera
GHW9100LQ1 machine stuck in control lock mode
Press and hold the "END OF CYCLE SIGNAL" button for three seconds and it will unlock the control panel. At least, I think that is the button for the Whirlpool Duet. If you look closely at the front panel, it will clearly state "Press and Hold for 3 Seconds to Lock" on one of the panel buttons (should be all the way to the RIGHT HAND SIDE). This button is designed as a safety feature to prevent small children from being able to operate the washer and inadverntenty getting locked inside the unit. If holding the button fails, unplug the washer for at least 30 minutes to reset the computer. I hope this helps.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GO-Video model DVR440 (DVD/VCR combo) Child Lock ON, No response to POWER button
can only be done by remote control unless you have the complete manual to reset all your saved settings from the front panel
Mar 31, 2008 | Televison & Video
Whirlpool Duet GHW9150P Front Load Washer Logo
79 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
