Question about Canon PIXMA iP1500 InkJet Photo Printer
No ink I installed new ink and still no print, printer sat for a while. i have done the cleaning and deep cleaning. any suggestions?
  • Bugladybikes May 10, 2008
    I have the same problem - installed new cartridges, and it still does not print. The ink cartridges are not clogged - the little foam outlerts are damp. Is there a way to clean the carriage nozzles?
    Guru:
  • 1,342 Answers
The ink may have dried up. Try this: Put a wet cloth in the microwave to heat it up. Place the ink cartridges on the hot rag with the nozzles resting on the rag. Try not to touch the copper contacts on the cartridge. Do this until the ink begins to seep from the cartridge. Put the cartridge back in the printer and run the cleaning phases again.
Posted on Apr 24, 2008
Pink and blue streaks on right side of page
most probably your "soak" pad need exchange. check your manual and change it. when you "deep clean" heaps of ink is absorbed into the pad exacerbating the problem, not solving it.
remove cartridges first and check them for existence of any foreign matter,
check for presence of debris under the head and parking place, remove if any,
i would suggest cleaning of printheads, albeit this can be risky (check first if your ink is soluble in water, isopropyl alcohol or methylated spirit, use that which solve your ink without clumping as cleaning agent), remove cartridges and allow appriopriate solvent to sit few second on metal rasters, wipe them with clean absorbing tissue and repeat procedure till solvent is "sinking" through the net.
remove old and install new absorbent pad under the print heads,
re-install inks, print rest page and then "normal" page. ink on first test page maybe very weak as solvent need to go through first.
if you follow the steps correctly, your should have clean print on the end.
"deep cleaning" is just waste of time, effort and ink. it is better if you create yourself a document with alternative lines of all three basic colours and black and then print it.
Jul 26, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Epson PM240 Photo printer HAS WRONG COLORS
Hi
You should try to use a different cartridge to see if it is the cartridge or the printer itself.
Also, make sure that all of the colors are coming out of the cartridge. You can touch a moistened kleenex to the head to check this.
you should also try a deep clean.
1. Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
Please let me know how all of this goes and we can try further things if this is still a problem.
Thanks
Aug 03, 2008 | Cameras
My printer won't print it sat for 6 months we put new ink in and it scans and goes through the actions but doesn't print ink
The problem with printers like Epson is that they cannoy stand without being used for that long. The print head that is largely responsible for print quality is built into the machine and the last ink that passed through 6 months ago is hardened inside. Dry several deep cleanings with nozzle checks inbetween. You may need to send it for manual print head cleaning with a printer technician.
Feb 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Won't print PRIXMA iP1500 Going through the actions of printing but no ink appear on paper. Deep cleaning done, reset done, new cartridge done, alignment printing done, still no ink.. and it did print a...
If using aftermarket inks you sometimes have to rap them on a paper towel to break an air lock.If you see ink coming out after rapping them try to print again.If nothing comes out you may have a bad print head or purge pump.
Try cleaning the head (without cartridges)in a 10-20% ammonia warm water mixture for 30-45 min.
Completely dry the head before returning it to printer.
Jun 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Black and Magenta ink won't print...
Do a deep clean on the printer.
Done from the printer setup.
widows is done from start, printers and faxes, click on your printer.
Should bring up window for setup.
Look for cleaning section.
May 07, 2009 | Epson Stylus C88 InkJet Photo Printer
My Canon S750 Bubble Jet Printer does not print with black ink. It seems to print all other colors though.
Replace and install the black ink cartridge with this Black Ink Tank BCI-3eBK Ifyou have done this and is still missing the black ink on print, clean the print heads. 1. Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'. 3. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
That should most likely work. If deep cleaning did not help, you may need to replace the print head.
Nov 25, 2008 | Office Equipment & Supplies
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon iP90 Printer Ink Issue
I have had the same issue with my iP90.  I think this results from the black ink nozzle becoming clogged.  I was able to get mine to print by cleaning the nozzles.To clean the print nozzles open the Canon IJ Printer Utility, select the printer from the list of available printers and click the maintenance button.  Then, select a cleaning or deep cleaning cycle.
Jan 02, 2008 | Canon S 330 InkJet Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
50 people viewed this question
old marine
old marine
