Question about Sony Handycam CCD-TRV11 8mm Analog Camcorder
My sony CCD-TRV118 camera has lines when you record or playback video. Sort of happens when light throws on it.
  • 6,826 Answers
I've read not to point the camera directly into a bright light or sun or else the symptom you describe may occur.
Posted on Jul 28, 2010
I have sony Handycam model ccd-trv118. When the casset is playing, no sound is coming however befor working good. Please solve this problem
Hook camcorder with TV through its AV cord, if you get playback sound in TV then there is small speaker in lcd section of camera that will be replaced and if you do not get sound in TV then sound processor chip on camera main board will be replaced.
Let me know if you are handy with electronic stuff repair to provide you more info to repair it yourself or take it to local camera tech for fix.
Thanks.
Sep 26, 2009 | Sony Video Cameras
My Sony TRV118 displays C:31:23 when trying to playback or record. Have tried different tapes, left open for sometime, removed battery. All to no avail.
The camcorder has detected an issue that may require a power reset.
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Aug 12, 2009 | Sony Handycam DCR-TRV118 Camcorder
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
My Camcorder is in full power and I can see what I am trying to video . . . but nothing is happenning when I click the record button. I have a SONY DCR-DVD100 NTSC and am using a Sony DVD-RW DVD (1.4 GB).
Let me know do you see correct picture in playback of previously recorded disc?
If yes, Then camera has ccd imager problem and that part needs to be replaced.
Let me know about playback question to help you more.
Jan 10, 2009 | Sony Handycam DCR-DVD100 DVD Camcorder
Sony handycam dcr trv lines problem
You camera Sony DCR-TRV255E requires new CCD Imager and Sony announced to provide Free of Cost repair for subject problem. Please click Sony Support (for UK) for details as assumed you are in UK. If you are living in different country, let me know.
Sep 11, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony handycam DCR_TRV118 Hi-8
THIS IS THE CCD ..SONY IS AWARE OF THIS AND WILL FIX FOR FREE.. GOOD LUCK
Jan 01, 2008 | Sony Handycam DCR-TRV118 Camcorder
Sony camcorder CCD-TRV118
the cameras power may need to be reset
Turn the camera off and remove the battery and the power chord
wait for a bout sixty seconds
put the battery back in and try to start it up
Dec 11, 2007 | Sony Handycam DCR-TRV118 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Lcd problem
Sounds like you have either a problem with the CCD block or on the mainboard where the encode/decode section is. If it is the CCD block it is defective or you have a loose or dirty connection on the ribbon cable from the CCD block. In record mode you are seeing the video E/E, which means you are looking at the video from the CCD block which has passed through the mainboard. That would explain the lines on the viewfinder. When you playback a tape you are looking at the recorded signal, but it also passes through the mainboard. It is not clear whether the tapes you are talking about playing were pre-recorded previously (prior to this problem) and played previously, with no lines present. If they were recorde previously, played back previously with no lines, and not re-recorded. They should be OK provided the problem is not tape damage. Since you say that all tapes do it, I would think it is not tape damage. The best place to start, to sort out the problem, would be to locate a known good camcorder and try your tapes in it. If they play fine the problem is on the mainboard but after the record circuitry, ie. only in the playback circuitry. If they have the lines the problem could still be on the mainboard but also could be the CCD issue I talked about. This is a tough problem to isolate and will take a good repair tech. If you are not familiar with troubleshooting camcorders you will need to locate a reputable and experienced repair facility. First you should do the test I mentioned on a known good camcorder as this will help a repair tech make a diagnosis. If there are no repair shops in your area here are several which offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck.
Jul 25, 2006 | Samsung VP-D103i Mini DV Digital Camcorder
Sony Handycam CCD-TRV11 8mm Analog Camcorder Logo
113 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
