Question about Intel D865GBF Motherboard
Display problem cpu start normaly but no display on the crt monitor i had already checked the vga card m.board intel865
This motherboard requires memory to be inserted in matched pairs _ same kind ,size,speed, etc plus two memory chips at a time _ meaning if u have 4 slots you need to add either 2 chips or 4 _ adding only 1 or 3 could cause system instability_
note: if you have 4 slots ( slot 1 and 3 is how u would add memory not the 1st two slots ) or u could use slots 2 and 4 but not only 3 and 4 ) if more explanation is needed refer to motherboard manual
Posted on Aug 09, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 196 Answers
Check ur cable connections jackie
Posted on Jul 28, 2010
  • jacqueline sanders Aug 09, 2010
    Also a helpful reminder when adding memory add one memory stick(Module) at a time ... then restart yor computer .Then add another and restart your computer.
My problem is my computer cannot open the display in the screen is "check the video cable"
Good Day Efren!
When you turn on your PC and your monitor displays "Check the Video Cable", it means that there is no signal coming out from the video card going to the monitor.
It just gives you the direction to check if the VGA cable is properly connected to the video card and to the monitor. There are two screws that need to be fixed to both ends of the cable to ensure its connection. You can also try other VGA cable to make sure that the one you are using is not faulty.
After you have made sure VGA connection is secured and restarting the PC did not fix it, the next suggestion might fix it.
Turn off your PC and unplug it. Disconnect VGA cable from the video card and open the casing cover. Disconnect the video card from the motherboard. Using a clean clothe moistened with alcohol, gently wipe the contact surface of the video card. Reseat the video card properly to the motherboard. Return the casing cover and connect the VGA cable.
Restart the PC and see if that fix the problem.
Good Luck Efren!
You can give some ratings if this fix your problem.
Thank you for asking Fixya.
Jun 09, 2011 | Computers & Internet
POWER COMING NO DISPLAY
check cable connection (vga cable). Have you check your video card. Are you sure that the problem is not with the CPU (system box).
May 14, 2011 | SAMTRON 55V 15" CRT Monitor
No display, light goes green but on screen says no connection then goes yellow for standby tried both DVI and VGA so now linked my pc to my tele via DVI to HDMI and works fine anyone know what this could...
here is the simple test to detect hardware malfunction.
on every monitor these days whether its CRT or LCD already programmed inside self test.
detach your cable data to CPU and power on your monitor. if its displayed self test on your screen mean its OK and something wrong with your CPU, could be VGA error.
if its just black display mean some is wrong with your monitor.
if you post more detail maybe we in FIXYA could help.
thanks.
Mar 11, 2011 | Hannspree HW191D LCD Monitor
Led bilinking
green LED blinking but no display, when disconect VGA cable from CPU than monitor displays cable disconected. CPU vedio card is ok
Jan 08, 2011 | Samsung 793S 17" CRT Monitor
Power is on but self display & cpu display not
probably itz either minor case of improper ground/cpu fan/faulty power cable..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)a)in power on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd'or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7)open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8)on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Feb 17, 2010 | LG Studioworks 563N 15" CRT Monitor
700e Lg crt monitor problam power on eht on but not display
The normal crt monitor have a demo display when you unplug the vga cable to PC like this image below.. fd6b6b9.jpg
Note:
If the crt monitor green LED light steady and heater beam have light, the horinzontal and High Voltage supplied to tube is completely good. If you encountered this problem just focus on video section of crt monitor. But before you start... find the flyback transformer behind this they have two controls screen & focus. After you found it plugin the monitor use plastic precision or small screw philip driver for safety to high voltage at horizontal area choose screen control rotate it to clockwise direction follow this....
5b5166c.jpg If the display responses or from dim to lighter 100% you have a problem to ABL find this at the bottom of horinzontal section near at flyback transformer pins trace the line of ABL for dried solder, open resistor if nothing happen find the Video IC at chroma section and replace it. follow this...
3c6e89c.jpg For LG & Redfox you found LM1269NA Visit this site for seaching semiconductor matches www.alldatasheet.com Good luck.
Check this site for searching semiconductor
Aug 12, 2009 | LG Studioworks 700S 17" CRT Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
Horizontal lines that look like streaks or smears going from left to right
Horizontal lines that look like streaks or smears, you need consider:
1) video card memory error cause it if the display memory on the video card
2) check RAM (clean pins and slot pin)
3) monitor power on without cable to see the menu display, it is ok if no streak, need to clean monitor cable plug.
Aug 25, 2008 | Dell E207WFP LCD Monitor
Intel D865GBF Motherboard Logo
81 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
