Question about Kenmore Elite 45986 Front Load Washer
How can I increase the water level in my HE3t washer? Does not have enough water to wash clothes.
5 Suggested Answers
Washer_tech
  • 164 Answers
SOURCE: Not enough water
run the machine empty. if the water comes to the bottom of the glass window, you're fine. No you don't need to see the soap suds either, too musch soap will cause the machine not to function properly and won't spin out all the water
Posted on Nov 17, 2007
  • 105 Answers
SOURCE: TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Posted on Jan 28, 2008
SOURCE: HE3t Kennmore water fill level adjustment?
I completely understand your dilemma as I have the same problem with my HE3. I was so frustrated I called a service tech out before my warranty expired and he told me the #1 complaint about these washers is that they don't get the clothes clean. I was surprised at his honesty! He told me to get a water softener and to use hot water but said nothing about clothes that are supposed to be washed in cold water. I asked him how to adjust the water level and he said the sensor is not adjustable but I have been unable to find out if these is true. I agree with you and believe it's because they use too little water. I have come to absolutely hate this washing machine for many reasons. When washing anything long (jeans, pants, long-sleeve shirts, etc) it literally ties the whole load into a clothes knot. You can grab one item and pull the whole load out because it's a huge knot ball. So tell me, how do the clothes get clean (or properly rinse) when they are in a ball and unable to freely move through the water (which isn't there) in the bottom of the tub? Another problem is that it takes a MINIMUM of 3-4 rinse cycles to get the detergent out of the clothes...yes, I use HE detergent. Here's what I do. I use the 'add a garment feature' to interrupt the cycle after the washer has filled. Then I add about 2-3 gallons of additional water to both the wash and 1st/2nd rinse cycles. This has helped immensely but leads to two more reasons I hate the machine. First, that makes it extremely high maintenance to stand waiting for the moment to add water. Second, when adding the additional water, clothes have a tendency to get caught between the rubber gasket and wash tub where they can sit during the entire cycle not getting clean. On the up side I can say I've never had a mechanical problem with the machine. I am sorry and wish I could help more.
Posted on Jun 08, 2009
woodchuck789
  • 4070 Answers
SOURCE: Water Level
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Yours seems to be to sensitive and cuts off too soon. You may need a new switch.
Posted on Sep 14, 2009
I just put in my first load of clothing in my new machine. It does not seem like there is enough water flowing into the machine. I cannot see a water line while the clothes are being washed. It seems to me...
If this is a HE unit it's probably fine. Front load units determine how much water to add based on how big of a load you put in. As long as water is flowing (waterfalling) over the clothes as the machine tumbles then it is fine. Try a larger load and see if the water level increases.
Apr 06, 2011 | Samsung Washing Machines
Which washing machine is better front load or top load?
Front load washing machines are better than top load money wise.
One advantage of a front loading washing machine is an increased capacity. Since there is no central agitator, the horizontally-oriented drum can hold at least 20 to 30% more clothing per load. For a large family, this could mean running only three loads in a front loading washing machine compared to five in a top loader. Fewer loads often translates to savings in utility bills and water usage.
Another advantage of a front loading washing machine is less water and detergent usage. A top loading washer must use enough water to cover the highest level of the clothes. A front loading washing machine, on the other hand, only uses enough water to cover approximately the lower third of the tub at most.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer seems to need more water.
HI, the water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
I would advise to Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If there is water present, the switch must be replaced.
The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test.
Feb 01, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Sides vibrate during spin causing a lot of noise and machine moves. could it be out of balance?
1- Clothes are not balance inside the tube. Try to rebalance the clothes when it happens. It usually happens when towers leaning on on side when water level selector not set appropriately. 2- Try to level the washer by adjusting the leg screws at the bottom of the washer. 3- It make a lot of noise since the whole washer moving against the floor. When it spin only the tube then it won't be like that.
Jan 02, 2010 | Kenmore HE3T Washer
Washer over fills and water comes out the door. Water continues to run even durring the pump out cycle just before the spin cycle
  1. Water inlet valve. It may not be able to shut completely when the electricity to it has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow. Remove the washer's cabinet to access it.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
  3. Air-hose. It is connected to the water level switch through a tube. If the tube or hose is cracked or broken, no enough pressure builds up to trigger the switch and shut the water supply off. Check it for any obvious damage.
Oct 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water Level
Sep 14, 2009 | Kenmore Elite 45986 Front Load Washer
Washer overflows after taking it apart
You may have missed something when putting it together. Take it apart again then check and properly install the following:
  1. Water inlet valve. It may not be able to shut completely when the electricity has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow.
Aug 23, 2009 | Kenmore Washing Machines
No water level in new Kenmore HE3T Steam front loader
high effeciency washes use very little water , the water is at the bottom of the drum (not visible )
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Water level adjustment
You don't. Front load washers use only a very small amount of water. They fill a small amount, tumble a bit, resulting in water being absorbed into the clothes, which drops the water level in the tub. The washer senses this and adds more water, which repeats until water level stabilizes. The only way to get more water on wash cycles is to use delicate cycles, which use more water, resulting in a more gentle wash action. Remember that due to the low water consumption of front load washers, you should only use one tablespoon of HE detergent per cycle. (even less if you use 2x or 3x concentrate.) This is a FixYa solution. Your washer is working as designed.
Oct 23, 2008 | Whirlpool GHW9100L Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
326 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
