Question about Fisher and Paykel Washing Machines
It fills up with water then stops, it does spin but doesnt agitate
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now can you please reply with the model number of your machine and also after it stops filling does it stop and beeps and shows an error code?Please reply with additional information and I am sure I can help you rectify this fault.
Posted on Jul 28, 2010
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
My GE WCSR4170D AWW top loading washing machine will not stop filling with water. i can get it to agitate when i blow into the air line hose attached to the water level switch. BUT it never stops filling...
Thanks for choosing FixYa and welcome. You probably have a bad water level switch. As for the agitation, the drive motor controls the agitation, spinning, and draining. It is possible for the machine to not agitate, but yet spin and drain. The motor runs clockwise and counterclockwise. It may be bad and if so, will need changed.
Apr 30, 2011 | General Electric WCSR4170D Top Load Washer
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Fws445rf1 washer didnt stop filling and flooded my apt and it doesnt aggitate when it is washing,the whole thing just spins inside instead of moving back and forth,what are the most likely reasons for...
    if it's a top-loader, then the water level sensor is probably failed! if an older machine- there's a plastic tube (which you can't see from the outside) that measures the column of water in the tub of your machine, and triggers the agitate and spin, and rinse cycles of your machine.
    when it's in wash cycle the water level is lower, then it spins and drains and the rinse cycle pumps in more water (makes sense!), then drains & spins, then re-rinses at the same water level. your water level sensor is defective, probably. allowing it to over-fill.
    it detects the water level as 'spin' and doesn't agitate!
    my theory- no guaranty! if it's old get a new washer or a good used one! this is not a problem i've encountered, just a guess. good luck!
    Apr 17, 2010 | Frigidaire FWS445RF
    Washer agitates while filling and runs water when it should be spin cycle
    filling and agitating at same time could be pressure sw / but if filling in spin / I would replace water valve . sounds like its stuck open . . when washer stopes does the water stop. ?? if not may be timer .. your is hard to diag . need to know brand and model # ,, mm
    Dec 08, 2009 | Washing Machines
    Agitator doesnt start
    Sounds like the lid switch is acting up on you.
    Jul 26, 2009 | Whirlpool LTE6234D Top Load Stacked...
    My masher wont stop filling with water or agitate
    if water stops coming into machine when you pull the plug you have faulty water level control or the hose going to it.
    check the hose for cracks or worn spots, repair or replace.
    If the hose is ok you have a faulty control.
    If water does not stop when you pull the plug you have a faulty water valve.
    You can try dismanling it and cleaning or simply replace it.
    Jul 03, 2009 | Whirlpool LSR5132PQ Top Load Washer
    Washing Machines Logo
    41 people viewed this question
    Top Fisher and Paykel Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    michael_t919
    Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
