Question about Bosch TWK-9110UC F.A. Porsche Water Kettle Electric Kettle
Connection diagram of bosch water kettle,model TWK9110UC
Send connection diagram of bosch water kettle,model TWK9110UC
It beeps and the temperature light comes on but then it immediately fades and the kettle does not heat up.
I had the same problem after 2 years usage and found the problem to be the contacts between the kettle and base.
  • Unplug the base and using a very thin needle file clean the 3 contacts and centre pin carefully. These contacts are sprung metal, so be careful to apply slight pressure in a clockwise direction.
  • Next empty and upend the kettle, now use a fine abrasive pad (I used a piece of 'wet and dry' paper) and gently clean the surface of the contact rings.
  • Clean away all dusty residue, this should cure the problem.
Jan 13, 2016 | Bosch Styline Collection Kettle Twk8633gb,...
I think I broke the element when I poured cold water into a heated kettle. Is there a fix for this?
No. Can't happen. Have a Bosch. Always forget to add water before turning on, never ever went wrong. Even if I poured cold water into it 10 sec later. Take it back where you bought it and ask for a refund, or for another one. These are built to withstand these impacts. That's what I'd do for sure.
Dec 04, 2014 | Hamilton Beach 40870 10 Cup Electric...
Why won't our BOSCH TWK8633 stay switched on?
You don't say how old your kettle is, but if it is less than 1 month, I would go back to the retailer where you purchased. Make sure you have your guarantee or proof of purchase.... Otherwise, going by past experience, kettles that won't stay switched on usually need de-scaling. Even if you can't see any lime scale in the kettle, there are sediments in the water that will build up over time & that can cause the element to overheat. This makes the kettle switch off prematurely or not switch on at all. In the UK, regardless of where you live, you should de scale your kettle at least once a month. If this doesn't work, you should still go back to the retailer, but if it's found that the malfunction uis diue to lack of de-sclaing, this isn't usually covered by the warranty....good luck!
Aug 09, 2014 | Bosch Styline Collection Kettle Twk8633gb,...
How do you descale
Same as electric kettles stand overnight with lemon and water filled to just above scale. works treat on electric kettle Do not boil, just stand overnight.
Jun 28, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
Hi, I have a Bosch Private Collection Kettle. It is over a year old and has until recently been working fine. However, lately I do not feel that it boils to a high enough temperature for a long enough...
Some types of kettles use a separate power base to heat up the kettle jug. If this is the case with yours, turn the jug upside down and look. Also look at the parts on the base that touch the kettle jug contacts. If you can see the electrical contacts; mine were built on spiral rings for differing temperatures; try cleaning them with Brasso and a Q-tip (cotton swab) wiping the contacts several times to remove any tarnish and then use clean swabs to remove all traces of Brasso metal cleaner. Fill the kettle jug up to the maximum fill line and put the boiler on the maximum setting... boiling water. If the water doesn't boil... you have a more serious problem. Buy a new boiler as it isn't worth having someone fix it. Mine worked like new after I cleaned the contacts. Never immerse the jug contacts in water!!!
Nov 25, 2012 | Bosch Private Collection Jug Kettle steel...
Is there a kettle that will not switch on without water?
hello,
The solution to this question is YES.
while because if the lens could not read any h20(water)in it then element will not respond to the power supply .
Good lock and thanks for using fixya.
Jun 02, 2010 | Bosch TWK9110UC Porche Design Water Kettle...
Kettle doesn't heat up and no light comes on when press the On button
Check the obvious, 13amp fuse, if intact connect a multimeter switched to ohms across the live and nuetral pins of the plug (not plugged into mains) the reading should be between 0.05 ohms and 1.5 ohms if higher the element has burnned out or the over temperature sensor has activated. to determine which you will need to open up the bottom of the kettle and expose the wiring. using the above multimeter with the same settings locate the heating element this will have two terminals protruding from the water compartment thes will have eithe screw or spade connections, connect the multimeter across these two terminals and check for the readings above if correct the problem is the over temperature sensor if not then the problem is the heating element. the over temperature sensor will be a circular disk with two terminals clamped to the underside of the water compartment.
Aug 27, 2009 | Bosch TWK-9110UC F.A. Porsche Water Kettle...
Light switch on Breville SK500-XL Kettle
e mail askus@brevilleUSA.com
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Jul 24, 2008 | Breville SK500-XL Stainless Steel Cordless...
Open Questions:
See all Bosch TWK-9110UC F.A. Porsche Water Kettle Questions
Bosch TWK-9110UC F.A. Porsche Water Kettle Electric Kettle Logo
144 people viewed this question
Top Bosch Kitchen Appliances - Others Experts
Martin Olney
Martin Olney
Level 1 Expert
Oloyede Monsuru
ray gallant
Are you a Bosch Kitchen Appliances - Other Expert? Answer questions, earn points and help others
