Best Solution
posted on Apr 24, 2008
Rank: Guru
Rating: 92%, 74 votes
ok, fine....
Reset the Ativa router
to factory defaults. This is normally accomplished by holding the reset
button down for 10 seconds or more with power on for most routers.
Once you do that, you need to connect the computer directly to the motorola modem and configure it to be in "bridge mode".
Putting your modem into bridge mode means to bypass the router function and make it work as a simple modem. And, yes, if you do that then you must configure your wireless router to make the internet connection. If you don't want to do that, you can leave the modem as it is, I think the Ativa wireless router can still work even if your modem is still in PPPoE & you can still configure the router as an ethernet switch & wireless access point.
Now you can connect the router (after powering EVERYTHING down), turn on the modem, wait for steady connect, turn on the router, wait two minutes, boot the connected PC.
After you get a wired machine connected, you can enter the Ativa setup and configure the wireless security.
Open up IE or Firefox. On address bar, type in "192.168.2.1" and click enter.
Ativa wireless setup should load up. On top right, there is a
Log In button. If this is your first time login in, leave it blank and
submit.
Check up on the following: a) Internet WAN > Connection Type
> select Dynamic; b) Wireless > Channel and SSID > Disable
ESSID Broadcast, also set wireless channel to AUTO; b) Wireless >
Security > set up your security, you should know what to do.
Now for the most important thing. Click Firewall, and DISABLE
IT!! By doing this, it said that you'll will be vulnerable to hacker
etc...blah blah, but with security keys to access wireless and virus
program/window firewall should be enough to make you stop worrying.
Apply changes, then the thing restarts.
*** also leave MTU setting to 1454 & set it to auto connect; leave the DNS & MAC settings alone; also leave LAN settings as it is.
i would greatly appreciate if you could give me the modem's exact model no. (such as SB4200, 2100 etc.) and the router's as well....
