Question about Lenovo ThinkCentre M57 Desktop - Intel Pentium Dual-Core E2160 1.8GHz - 1GB DDR2 SDRAM - 80GB - DVD-...
Computer response very slow - Lenovo ThinkCentre M57 Desktop - Intel Pentium Dual-Core E2160 1.8GHz - 1GB DDR2 SDRAM - 80GB - DVD-...
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Computer slow?
-- clean system junk
-- optimize computer services
-- repair registry
-- defrag registry
-- clear browsers junk
You can do all this using some reliable software such as PC Fresher.
Posted on Jun 29, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
If you are using windows machine, go to start->run and type cleanmgr.exe and follow the instructions to clean up the junk and temporary files in your machine.
Also go to start->run and type msconfig and go to Startup tab and remove all the unnecessary startup items.
Also uninstall unwanted programs/applications from control panel (start->controlpanel) and go to add or remove programs / Programs and features based on your operating system version.
Now you can clean up your registry values using http://www.pctools.com/registry-mechanic/ or some other software available in the market.
Once you have done this if you know you have many unused useless files in your machine remove then and do a fresh restart. Then defrag your drives using the utility available in windows (go to my computer and right click on the drive you need to defragment and then click on the properties in the pop down menu. Once you are in properties window go to tools tab and click on defragment now). After the defragmenting is complete you can restart your machine again and you will notice a significant performance boost.
However if after doing all these your machine is still slow. Then you have to consider upgrading your Ram and sometimes even the hard disk.
You need at-least 1 GB of Ram to work well with normal applications and if you are into the multimedia applications like photoshop and if you are into gaming you need at-least 2 GB Ram and a graphics card.
You need to replace the hard disk only if it is under 7200 RPM. Lower rotations per minute means slower performance so in such cases going for a 7200 or 10000 Rpm drives can boost your performance.
Hope this will help you.
Best Regards NextDoorNerd
Posted on Jul 28, 2010
  • 808 Answers
Use some authentic and registered antivirus and use reginout i hope it will fix ur problem
My 2004 Honda CRV showing code P0133 and P0171
  • P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
  • P0171 System Too Lean (Bank 1)
Hi Michael, After fixing errors you need to reset your computer by disconnecting the battery for a minute or two, Also you'll need your radio code to reset your radio, I hope this helped...........CHEERS..
May 07, 2016 | Honda Cars & Trucks
My samsung gt-5230 response have turned very slow
u can format it through ur computer and update ur mobile from update center in run type cmd
format h: drive name of ur phone with: then asked is ur device ready then yes, yes then it will format ur phone then press enter
Mar 18, 2010 | Samsung Star GT-S5233 Cell Phone
Slow response from on switch
If the computer is slow to boot up, there are several factors to take into account. The RAM could be going bad. The hard drive may be going bad. There could just simply be too much "junk" on the computer and it may just need defragmented and cleaned out.
Feb 02, 2010 | Shuttle XPC PC Desktop
SLOW RESPONSE TIME WHEN TRYING TO PRINT
Hi !!
Laser printer are usually fast but if you are getting slow response try to clear cache. Bocz computer holds print in memory so it can be one of the reason and i'll be able to answer in more detail if you'll send me complete configuration of your computer along with any error if you are getting while printing and also let me know is it just with printing or overall your computer is slow.
Thanks,
Hope that helps
Jul 09, 2009 | Dell 1720dn Laser Printer
Acer extenza 5620z mouse not responding as it should keyboard input slow and not responsive cannot input all digits of my password to get computer started
How long since you've run the computer? Might it be processing and update like when it reboots after installing a service pack? That might be making the computer run slow for a few minutes. Give it a little time to get started and see if your mouse and keyboard begin to work.
Jun 01, 2009 | Acer Extensa 5620-4020 Notebook
Code: P0133 - O2 Sensor Circuit Slow Response Bank 1 Sensor 1
is this a 4 or 6 cylinder?
if a 4 cylinder it will only have 2 o2 sensors
V6 will have 4 o2 senors which the sensor will be the right side of the engine first sensor.
1st sensor on exhaust, I recommend if you change one change all, as this will make the computer when it rechecks the system you have all clean/fast responding sensors.
if you have a slow response it means the sensor is dirty and not reading well, which is usually caused by minor misfires that the engine computer dismisses, so a tune up would be recommended too.
May 06, 2009 | 2001 Saturn SC
I have somes REV. problem. When I check whit the scanner throw me 2 codes: P1133 / P0325. Its a Outback S/W 2000 2.5l.Thanks for everything.
Off hand sounds like the wires. The first is the O2 sensor getting slow response. The other is your knock sensor. If the wires are in bad shape or coroded conection on the knock sensor this will confuse the computer and change timing and idle to correct it until it gets a good reading from knock sensor. This also slows the response to the exhaust system giving the sensor a slow or poor reading of exhaust gases. Hope this helps and have a good day.
Apr 17, 2009 | Subaru Outback Cars & Trucks
Windows XP SP2 Slow printer driver response
hey,
Well, maybe you already have tryed this: uninstall all printer drivers, and reinstalled xp sp2? Or other updates for your operating system.
Also check you system ressouces: RAM usage, cpu usage
On my new vista computer, system is a little slow in general , so if you run vista on a old computer, that might be the problem.
;) /michael
DIY site 'why pay when you can play'
Dec 14, 2007 | Office Equipment & Supplies
Lenovo ThinkCentre M57 Desktop - Intel Pentium Dual-Core E2160 1.8GHz - 1GB DDR2 SDRAM - 80GB - DVD-... Logo
155 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
