I load up the lap,wait a while,then get 3 beeps and shutts of,every thing works fine till then,can be with in 10 mins or 30 mins,then the lap is of,i bought it second hand,the battery has gone,but using a power lead,so should be ok,the battery has 4%power when turned on with the lead
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
It can a problem with your graphics card or your Ram, Try removing your graphics card and reboot the machine. If it works then it's the problem with the Graphics Card. If it is not working then and still sticking with the old 3 beeps then Remove your Rams and Insert them individually or replace with a spare one or a new and see if it works.
Usually this will solve your problem. Please let me know if you can't solve even after doing this solutions
Best Regards NextDoorNerd.
Posted on Jul 28, 2010
  • Deepak Dharan Padmini
    Deepak Dharan Padmini Jul 28, 2010
    Forgive the typos in the previous post.
    I forgot to remind you that most motherboards come with 3-5 years of warranty, if *********** board is still under warranty and if the above problems didn't solve your problem then take it back to the shop/place where you bought it from and ask for a repair/replacement.
    Best Regards
    NextDoorNerd
Phone makes a beep nosie
is it while your on the phone?
Jun 01, 2012 | Southern Telecom EM2116 Phone
Just bought this 1999 tahoe from my brother in law and out of curosity i went through the fuse box and realized a 10amp fuse was missing from the fuse box which read security so the person that i am i put...
You need to reset the Passlock security system to your Tahoe.
1. Attempt to start the car, let it stall, but DO NOT turn the key off! Leave it in RUN.
2. Wait 10 minutes or until the Theft System light glows steady instead of blinking.
3. Do not turn the key off, but start it immediately.
4. This should reset your Passlock system.
Good luck and thank you for using Fixya.
If that does not work then your may have to do the 30 min relearn. You do basically the 10 min thing with the security light trick instructions above. Here goes this only works if your secuity light is on.
Put key in ignition don't start the car but you want to turn the key all the way on and release it back to the on position wait 10 mins or till the security light stops flashing repeat this the exact same way two more times( dont take key out) ending in about 30 mins total time. this should reset the code to the computer and you should have no more problems with it.
Nov 24, 2010 | Chevrolet Tahoe Cars & Trucks
Hi my washing machine door wont open, feels like the lock has broke ??
hi have you tried turning machine off at plug for a min then power back on put on a cycle press start. wait till it starts to fill and press stop and hold down the reset button till it beeps and wait till door unlocks. Or a quick way to open the door is unclip the foot kick stopper at bottom front of machine and pull the emergency door open which is a thing peace of hanging plastic. if none of this works try starting a cycle then press stop soon as it starts to fill and turn off on machine not at plug. hope this helps.
Sep 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
Unable to load games on ps3 comes up error disc, games worked well previously
if you switch your ps3 onto standby and leave it a min
then you need to hold the on button in till it beeps 3 times then release it will go bk onto standby
then you need to hold it again till it beeps 3 times but last beep will be a double fast beep
a menu should appear on screen
chose the one that says files
this will restore the lens drive and it will load discs
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Fuel pressure intermittently drops causing sputter and die.
check for 12v constant at your fuel pump if you are not getting that replace your relay.
if you are getting 12 volts at your fuel pump the fuel pump is possible to run tuel it gets warm then shut down to a lower rpm I would then replace the fuel pump
Oct 10, 2009 | 1994 Dodge Ram
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
NO POWER JUST BEEPS F70 CODE
Bad main control or ccu here is a link to the repair manual.
http://www.affordableappliance.com/Download%20Folder/Whirlpool%20Duet%20Washer%20Service%20Manual.pdf
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My 88" 2500 Chevy 3/4 ton will only run for about 30 minutes then cuts off, if I let it sit it will start right up and then do the same thing. is it the fuel pump relay or the pump its self
could be fuel related or i found a bad coil going out will crank and run about 10 miles till the coil gets hot then will shut of, wait about 10 to 20 min. to cool crank up and run some more ,check the coil, hope to help robert b.
Jul 16, 2009 | 1988 Chevrolet Silverado 2500
I turn my ps3 on and it freezes after 30 secs i have my fan next to it so i doubt its from heating issues
what u have to do is hold the power button down until 3 beeps . now the system should be off wait 10 mins and then turn it back on. if this does not help there is nothing u can do.
Jun 29, 2009 | Sony PlayStation® 3 (60 GB) Console
Wheelwriter 10 Series II doesn't work
My repair book shows:
1 Make sure the printwheel in installed correctly. 2. make sure the ribbon and correction tape are installed correctly 3. turn the typewriter off wait 30 seconds then turn back on if the same thing happens install another printwheel. 4 turn the typewriter off wait 30 seconds then turn it back on if the same thing happens call for service.
Jan 17, 2008 | Lexmark Wheelwriter 10 Series II...
Computers & Internet Logo
35 people viewed this question
Alun Cox
David Payne
David Payne
