Need manual for econair air-condition
Don't know how to start heater
Take batteries out of the remote control. wait a minute till display is empty then return batteries. The display then alternates between a snowflake and sun, you touch any button when it reaches the sun. If you misjudge timeing try again from the beginning. You do the same when returning to cooling.
Posted on Mar 14, 2011
Econair split system need code for new remote
The code, if applicable, is in the remote.
Jun 23, 2016 | Heating & Cooling
I do not know if I will get an answer, but here it gos, my moniter heater cuts on, starts to heat up a little and then makes a small click noise and then shuts off
Remove Obstructions The overheated condition may be caused by obstructions blocking the air flow to the heater. Check: • The front of the heater • The circulation fan (on the back of the heater). • The flue pipe (outside) Step 5: Remove the Louver Remove the screws at the louver, and carefully clean.
Below is a link to your manual
http://monitorproducts.com/wp-content/uploads/M441OwnersManual.pdf
Jan 14, 2016 | Heating & Cooling
Heater plows cold air on drivers side on my 2005 inpala
You probably have automatic air conditioning with dual zone capability, Please review the owners manual for the dual zone operation. I looked in the service manual and certain heat / air settings criteria have to be met before the system will work properly in automatic mode. If those conditions are not met, the system will assume manual operation and mostly play dead waiting for the user defined manual settings. Start with a good review of the dual zone automatic settings.
Nov 04, 2012 | 2003 Chevrolet Impala
Why does the air conditioning light blink when the defrost is on in my 2003 mitsubishi eclipse
Because on most vehicles your defrost is tied in with your air conditioning,They have it that way,That your widows don,t mist up when it is (Raining) Out, It explains this in most owners manuals for your car,Where it shows you the different settings for your heater. The high pitch squeal is your belt sliping on the air conditioning compresser.It is probally loose or needs to be replaced.
Oct 18, 2012 | 2003 Mitsubishi Eclipse
My heat don't work it blows cold air
Could be the heater core went bad, heather core lines are plugged, cover on the blower motor is off, or if your temp selector is cable, the cable may have seized
Oct 16, 2012 | Air Conditioning and Heat for Mercury...
I lost my user manual for my 4 in 1 portable air conditioning unit. Does anyone know where I can find a replacement?
Hi, you don'tmention what model you have but don't worry; most portable 4 in 1 airconditioning units are similar. Here is a link to a user guide that should helpyou. http://www.onninen.com/sweden/produkter/onnline/Documents/Manual+OPAL+AC%201.pdf
Jul 17, 2012 | Soleus 4 in 1 Portable Air Conditioner
99 ford mustang 6 cylinder. Recently i had to add antifreeze to my car couldn't find the radiator drain to take some of the water out so i loosened the lower coolant hose to drain some out after...
replace any soft hoses.
collapsed hoses cause water flow constriction
.that increases temp fast
to bleed air out of the system . if no air bleeder as such
with heater on full .-engine running
loosen the bypass pipe for the closed thermostat till only coolant flows no air bubbles
check if
the engine cooling fan spinning fast enough
the water pump in good condition
the interior directional flaps motors or actuators working
Apr 01, 2017 | 1999 Ford Mustang Cobra
The air conditioning system will only blow cold air. Regardless of the mode, I can only get cold air. Can you give me an idea on how to fix the problem? Thanks Don 615-653-3834 drcamp117@comcast.net
The air conditioning is supposed to blow only cold air. Are you trying to get the heater to blow hot air? Make sure the temperature selector is in the hot position.
Dec 19, 2010 | 2002 Buick LeSabre
Heater/air conditioning external slide broken. Where is the inner link?
Take your time and pull the dash apart piece by piece as to not break. Start on the passanger side. It will be close to your blower motor. You can turn it on and listen for location. Hope this helps.
May 30, 2009 | 1997 Isuzu Oasis
Heating & Cooling Logo
832 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
