Question about Hitachi Televison & Video
Hi I am Mahesh Chavan From Akshay Multimedia Projaction System I am service Engineer My Projactor Model No-CP-X1250 Problam-RGB Not Conected, PL Send P5-SIGNAL -PWD Capactor Valu cp no-cs01,02,03 & Resitor no RS54,51,67,57,66,68,36. This All Part Is Burn Thanks & Regards Mahesh Chavan
  • Hitachi Master
  • 12,061 Answers
You need to get a service manual, either Google, for one, or contact the manufacturer and ask them for a copy. Then you will be able to determine these parts and values. Usually though, the values are on the components? and resistors have color codes? It indeed seems odd, all those resistors faulty at the same time, is unusual to say the least. Are you sure your power supply voltages are correct? As if this isn't all 100% nothing else can be.
Posted on Jul 28, 2010
The filter needs replacing. Do you sell replacement filters for model CP-X1250?
Take the filter to the local electronics repair shop and ask them for some filter material like the one in the unit. Then cut it to size to fit like the old one.
Mar 25, 2011 | Hitachi CP-X1250 Multimedia Projector
Is the only difference between at CP-X1200 and CP-X1250 the bulb, or is the ballast circuit different too? Just thinking how easily I could boost the brightness from 3500 to 4500 lumens.
Model: CP-X1200 ( Lamp)
Part#: DT00591
Lamp Type: UHB
Wattage: 275 Watts
Lamp Hours: 2000 Hours
Model: CP-X1250 ( Lamp)
Part#: DT00601
Lamp Type: UHB
Wattage: 310 Watts
I'm not sure but I would think the same ballast board is used, and the trimpots adjustments set in the factory.
If you fiddle with it, you may not be able to get the tube to strike on startup, or worse you can explode the lamp.
Also the extra heat generated may degrade the optics and LCD panels.not mention melting the housing.
Better to leave well alone.
Feb 18, 2011 | Hitachi CP-X1200 Multimedia Projector
Hitachi CP-X1250 MULTIMEDIA PROJECTOR - MENU> MAIN> BRIGHT and CONTRAST are not active. BRIGHT and CONTRAST How to enable? I can not make adjustment.
hi,
Go to menu and then select main. then select reset and execute it.After that try to adjust the brightness and contrast.
Remember on thing, in some projectors the brightens and contrast will be active when there is video signal. also try that.
ok
Jan 26, 2011 | Hitachi CP-X1250 Multimedia Projector
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
Color shift blue tint
This could also be a setting. If you are using component video as a connection, make sure that the unit is set for RGB if coming from a laptop or other computer system. If the projector is set to YPrPb, the picture will look purple or bluish as you describe. Change the setting to RGB and all should be well.
Dan
Oct 26, 2009 | Hitachi CP-X1250 Multimedia Projector
Projector looses rgb signal
Hi
This is probably a cable problem, can you please try another video cable
Cheers
Dave
Jun 21, 2009 | Hitachi CP-X885 Multimedia Projector
Bulb
Instructions How to change Lamp in Hitach CP-X1250 are available on User Manual page-38
Please confirm do you have User Manual?
Oct 01, 2008 | Hitachi CP-X1250 Multimedia Projector
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
