Question about Sony VAIO VGC-RA840G PC Desktop
How to install W7 on this model. i tried but after installation, it's reboot again and again. it's any option on bios regarding this problem? thx
  • 808 Answers
U try to update ur Bios it will helps u
Posted on Jul 28, 2010
    New Friend:
    Problem Solver:
  • 5 Answers
Both of these answers aren't right. I have successfully installed Windows 7-64 bit. Make sure you upgrade the ram to at least 4 gb, from there make sure you have a legitimate copy of Windows 7. as long as you follow the directions you should have no problem. good luck!
Posted on Nov 04, 2013
  • 6,826 Answers
OK, I encountered this problem where it would reboot and reboot during the installation, until I realized that I was choosing to install from scratch every time when the disc was inserted.
When it asks to reboot, remove the disc from the drive to allow it to install regularly.
Does this make sense?
0x8007045d
Unless you are trying to install the 64bit version of Windows 7, it is not compatible with a uefi boot option - this has to be switched in the bios - F2 to access your bios, then look under boot options (I don't have the specific menu for that laptop) what you want is to enable legacy boot options.
Here is some information - select legacy boot options
http://technet.microsoft.com/en-us/library/hh825112.aspx
Apr 13, 2014 | Computers & Internet
How to fix no boot device on emachines e442 for free
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 09, 2012 | eMachines E442 E442-v133 15.6" Notebook...
I have formatted the boot partition (winXP Prof pre -installed) and installed Windows 7 and after BIOs the screen goes blank
Hi pratimpal
You should have directly upgraded to W7 instead of formatting . Try reinstalling Windows 7 on the same partition , it should work . Otherwise , back up all data on an external device , format entire drive while installing W7 and create new partitions afterwards with http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html
Best regards ,
fanaudi .
May 03, 2011 | Computers & Internet
I have an acer extensa 4230 which I reformated.I installed the audio,vga and rebooted the system.It rebooted fine.But upon installing a bios system driver,it requested for a reboot.After the system short...
It sounds as though the wrong BIOS has been installed or when downloading the correct BIOS there was a problem with the file and it is corrupt.
Apart from removing the BIOS chip and fitting a programmed one, there is not a lot else you can do except speak to Acer and see if they can help.
Regards.
Oct 20, 2010 | Acer Extensa 5620-4020 Notebook
When I reset My HP Pavillion 9728ca, it would not turn back on no lights no bells or whistle at all then a few day latter in tuned back on???? Then it happen again but it didn't turn back on until a few...
what does RESET mean. tell the helper that first.
my guess is you mean BOOT?
first take out the relic battery (i bet its old and shorted)
does, BIOS work now, hit the BIOS key? yes/no
does it boot to the hDD, now?
To installed W7, Who's, Microsofts or HPs' latter works other dont.
using CD driver to install w7, that it?
does the CD boot and run and ask all the normal questions?
it takes a good HDD to installed W7.
for a fact.
I test the PC with a Linux live disk or Windows PE live disk
first to see if all is good, then run HDD tests from there.
using HDD test software, (free from hundreds of sources) ask
then install w7, when sure.
battery is out.
power pack ok.
and HDD ok.
only then can it work. (if luckly , )
May 21, 2017 | Compaq Pavilion ZT3280US Notebook
I was trying to get the Dell Printer 942 to scan by installing the All-In-One Center but couldn't get it to work. now the REAL problem is I can't print anything. I get a response "Communion not...
Ok, I presume you are using a parallel printer, what you have to do, is go into the BIOS, SETUP, and find the Printer Port, LPT1, and set the port to bi-directional, or SPP, now save, and reboot. Now reinstall again, and it should work. ( It may just work anyway, after reboot, that may be worth a try first)
Apr 23, 2010 | Office Equipment & Supplies
I want to install w7 and mandriva in my laptop,configuration of my laptop is intel dualcore t4200,2gb ram, 320hd,
go ahead and do it.
Install Windows 7 - run all the updates. Reboot several times.
Install Mandriva - use the "free space" option - or one of the other options.
Here is a discussion about the options - click here
Feb 25, 2010 | Compaq Presario Notebook
How to re-install Bios
hello bhargav....
To make BIOS to default.... you have to do a jumper setting.... on motherboard
or based on the model number of the motherboard... download updated bios.. and copy it into the Floppy/CD... and try installing it... going to bios and choosing update bios option..
Nov 07, 2008 | HP Compaq Presario V2000 Notebook
Sata drive problem
Depending on the brand and model of the motherboard, your concern is indicative that the SATA is not enabled. Pls enable, save and exit, reboot. Thereafter enter CMOS/BIOS again to auto/manually detect.
Hope this be of initial help/idea. Pls post back brand & model of your motherboard, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Computers & Internet
Sony VAIO VGC-RA840G PC Desktop Logo
133 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
