Question about Home
I'm insytalling new tile in shower should the frame of the shower doors be caulked?
  • 10,865 Answers
Hello. Definitely yes. You want the tile, grout and caulk to be a semipermanent barrier for the water. If you do not caulk the frame, water will get in there and either leak or cause mold to form. Use a good quality silicon caulk, either clear, or white or a color that matches your grout lines. J.
Posted on Jul 28, 2010
Testimonial: "Thank you so much. I thought it should but didn't know for sure. I think you have saved me from problems down the road. Thanks again"
Seem to have water leaking under shower into storage competition ment, tried caulking only happens when shower is on and someone is in it very frustrating
Very often happens for a number of reasons
Bad caulking around the shower base and the base drops with the weight of the occupant allowing water past the caulking.
Crack and bad seal on a wall tile.
A split in the base itself which opens up with weight and you can't see with the base empty.
A leak in the pipes behind the wall from the mixer unit to the shower head.
Split pipes or fitting to the drain.
Best way is a full tear down, refurbishment and start anew :>)
Jul 10, 2016 | Home
How to Grout ceramic tile to shower base
Don't use grout! Instead use silicone caulk that matches your grout color as close as possible. Never grout where tile meets at a 90 degree angle it will crack.
Jul 13, 2014 | Building Materials
3 piece tub needs to re-caulked. Is this a do it yourself project?
Are you talking about caulking around all sorts of small tiles, or is yours a one piece wall unit that only has caulking around the edge of the tub and the nozzels? If it is the latter, you simply remove the old and add new. If it is all the old tile caulking then If you are not good at handyman (handywoman) things, then you should call a professional. Most of the home outfitting places have help available to you if you wish to DIY the job. You should visit a place like Home Depot, Lowes, etc. for their free advice and a lot of them offer classes in home repair things.
Jan 26, 2013 | Home
Glass shower leaking into wall, can't figure out how.
Hi dont know about shower,but think it would not hurt to take one screw out at a time and and squeeze a little water proof silicone in the screw holes then put the screws back in,and putting the silicone down the joint proberly would work but you would need to use a good anty mould silicone sealent(but if possible would be better to take the joint apart and seal it if posible,hope this was some help.
Mar 02, 2017 | Home
Replace shower door
Hi
You did not mention any additional information about your problem except replacing shower door.However use basic hand tools to complete the job.
Try this following general steps :-
1. Remove the doors by lifting up on one door at a time and then pulling each out. The top of the door has rollers attached to it, and the rollers rest on the inside of the top rail of the frame. Set the doors aside.
2. With your drill, remove the two screws on each end of the top rail, located on the inside of the shower frame. Then lift off the top rail of the shower frame.
3. Use your box knife to cut the caulk on the side and bottom rails of the shower frame. Shower frames are caulked on the outside where they meet with the walls and floor of the shower.
4. Use your drill to remove the screws from the side rails. There will be two screws on each rail, securing it to the shower stall. Then, take the rails out. Remove the screws from the bottom rail and take it out.
5. Use your tape measure to measure the old side rails, top rail and bottom rail. With a pencil, mark the lengths on each new rail. Use your hacksaw to cut each rail. Hold a side rail in the exact location where the old rail was located. With your pencil, mark the screw holes on the shower wall. The new shower frame screw holes may not line up with the old shower frame screw holes. Use your drill and 3/16-inch drill bit to drill new holes if necessary. If the shower walls are ceramic, use the concrete drill bit. If the shower walls are fiberglass, use the multipurpose 3/16-inch drill bit.
6. Insert the 3/16-inch anchors into the holes that you drilled. Put the side rail into position and insert the screws into the holes. Use your drill and Phillips head drill bit to tighten the screws. Place the bottom rail into position and mark the holes. Drill new holes if necessary and install the anchors. Insert only one screw at the end where you installed the first side rail. Lift up the loose end of the bottom rail and slide the second side rail into place. Mark the holes. Remove the side rail and drill the new holes using the 3/16-inch drill bit. Insert the anchors and put the side rail back into place. Insert the screws and tighten with your drill using the Phillips head drill bit.
7. Set the top rail directly onto the side rails. In each end of the top rail, insert the two self-drilling screws until the top is secured to the sides. Insert the tube of clear caulk into the caulking gun. Cut the end off of the tube with your box knife. Caulk the side rails and the bottom rail to the shower walls on the outside of the shower. Re-hang the shower doors by lifting each door and placing the rollers on the inside of the top rail.
Also giving you some links from where you can find a detailed information regarding replacing shower doors.
http://www.diynetwork.com/how-to/how-to-replace-a-shower-door/index.html
http://www.thisoldhouse.com/toh/how-to/intro/0,,214441,00.html
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 20, 2012 | Home
We have had our shower for 5 years now and it continues to leak at the bottom corners. we have the corner shower stall against a tile wall. I have replaced caulking several times even removing stiles...
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Nov 06, 2017 | Maax Brio II One-Piece Neo-Angle Corner...
I bought a maax shower base. i am going to intall a cement board on the wall, water proof it and then tile over it. The shower base has a flange that is 1/4'' thick. do i install the cement board on top of...
There are two ways that I would do it depending on the width of the ledge on top of shower base. If you have enouch room I would shim studs with strips of material thick enough to bring the surface out even with flange on shower base. Then I would put cement board(wonder board) on wall and over shower flange to set on top of shower base. Finish seams on wall board per manufacturers directions,Let seam filler dry then seal with thompsons water seal or equivalent sealer. Let that dry then tile on that grouting and sealing with quality caulk at joint between shower base and tile.
If ledge on shower base is not wide enough then I would place cement board directly to studs then use filler strips on face of shower base flange to bring two surfaces flush. Water seal let dry and tile again coming down over top of shower. Grout and caulk to finish. P.S. I would use a siliconized latex emulsifier to mix in with grout. It gives a better ware proof seal. Hope this helps you. Good luck and thank you.
Jan 30, 2011 | Maax Acrylic Base for Shower - 102623
Cast-iorn tub to fiberglass shower kit not sealing
keep caulking or change to ceramic tile, or one piece shower units ,without seams
Mar 03, 2010 | Home
Caulk coming off in Corian stall shower
If you have the option of not using the shower for a while, I would put a dehumidifier in the shower to **** the mositure out from below. If cost is no object, you can go ahead and pull the base. The key to the caulk is to completely remove the old caulk, clean carefully and use a silicon based caulk. Be sure to let it dry properly (see caulk cure times on tube).
Dec 30, 2009 | Daltile Bathroom Accessories Resin Soap...
I have frameless shower doors, the bottom sill is tile, with grout lines. Water leaks under the shower door through the grout lines, how to correct this.
if the glass actually contacts the tile you can go to the homedepot or similar place and buy some glass silicone sealer and just run a nice bead of caulk along the line, make sure you get clear silicone and let it thooroughly dry before you get it wet
Sep 14, 2009 | Dmm Vigo Frameless Shower Enclosure with...
Home Logo
124 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
