Question about Philips HD6153 Deep Fryer
Cleanup? does the metal inside of the deep fryer remove for cleaning? If so, is there a trick to it?
I just found a manual online and it does not appear that the metal inside of the fryer is removeable.
Posted on Jun 19, 2008
FLAMES ARE COMING OUT THE BACK OF MY FRYER,WHAT WOULD BE THE PROBLEM
There may be an excessive carbon deposits inside he heat tubes of your fryer, you have to clean/ remove these carbon to eliminate flames coming out of the back of your fryer (flue riser).Carbon build up on heat tubes are due to low gas pressure and volume; incorrect air and gas mixture.
Apr 17, 2011 | Pitco Frialator SG18S Deep Fryer
We purchased new fryers that are Imperial IFS40 and the salesman was going to check them out and demonstrate the fryers by putting water in them and turning them all the way up. It got so that the water...
Fryers use 2 types of stainless steel. Get a magnet and see if it sticks to the inside of the tank. If so...that is a lower grade of stainless. Use some steel wool to clean the rust spots and cover with vegetable oil. The tanks should be ok if you just bought them.
Tom
Jun 22, 2010 | Imperial IFS40 Deep Fryer
Soot build up
Flame is Orange? If so, propane is "choked", not enough air. Remove burners, clean each burner hole with a same size metal dowel (coat hanger works well) flush out inside of burner with garden hose, hi pressure air through all holes to dry. Replace burners ONLY after also cleaning chambers and chimney (garden hose and long brush). Do not forget to clean pilot light area too.
Most Imperials are pre-set air intake. Check gas pressure if able, 3" NG, 10" LPG. Good Luck
May 12, 2010 | Imperial IFS40 Deep Fryer
I need to know the best wayto clean the inside of an IFS40 deep f
Mr. Muscle Commercial oven cleaner, a good brush, a stainless steel scrubbie. Boil out the pot in accordance with Mr. Muscle directions. If all else fails, find "SWELL" oven cleaner in Restaurant supply, use rubber gloves. Spray on, let sit, Use brush and Scrubbie to remove. RINSE WELL!
Apr 27, 2010 | Imperial IFS40 Deep Fryer
Cleaning
I usually boil water in mine to clean it out. I let it boil for one full timer. To clean the outside I just use Windex and some elbow grease. Hopes this helps.
Mar 18, 2009 | Rival CW400 Chef's Fry Cool Touch Deep...
Oil Level Stains
Manufactures are constantly changing the properties in the stainless steel. They are dropping the nickel and alloy contents that they used to use, that's where the dull finish is coming from !
All manufactures are changing there materials to compete in this industry. These units may have been manufactured at diferent times.
Scoota
Dec 01, 2008 | Pitco Frialator SG14 Deep Fryer
Fire from lower ports
is this unit propane?if so the baffles are clogged,you need to remove the burners theres 2 bolts that sit on top of them.loosen the bolts,remove the burners and clean out the baffles.clean the burner orfices as well.this should do the trick.
Dec 25, 2007 | Vulcan EF3 Deep Fryer
Cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Oct 15, 2007 | Rival CF153-WM Deep Fryer
How do I remove the portion that holds the oil to clean?
If I remember correctly, the manual that came with mine said that it is not removable. Pour out the oil and wipe the interior with a paper towel. (I wish it were removable!)
Jun 28, 2007 | Rival CF275 Deep Fryer
Cleaning
From http://www.rivalproducts.com/help.aspx?helpNav=1: How can I clean my fryer? - Unplug from outlet and allow unit to cool. Always turn control to OFF then disconnect plug from wall outlet BEFORE disconnecting BREAK-AWAY CORD. - Clean the outside of the fryer and lid with a damp cloth. CAUTION: Do not use abrasive pads or alcohol to clean the fryer. - Remove basket handle, if one is included. Frying basket can be washed in hot soapy water. - Rinse and towel dry carefully. - Pour out oil and discard properly. - Wipe the inside with paper towels to absorb excess grease. Wash interior of fryer with hot soapy water. Rinse and dry thoroughly. CAUTION: Never immerse the fryer in water or wash in running water. If you own a fryer with a removable bowl or other removable parts, refer to the Owner?s Guide for your specific fryer to determine which parts can be cleaned in the dishwasher.
Mar 08, 2007 | Rival CZF630 Deep Fryer
Philips HD6153 Deep Fryer Logo
197 people viewed this question
Top Philips Kitchen Appliances - Others Experts
Dennis Maeder
Thomas Perkins
Thomas Perkins
Robert Kilpin
Robert Kilpin
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
