Question about EliteGroup K8M800-M2 Motherboard
Im trying to install a 250g sata disk but computer is not even getting into bios .motherboard k8m800-m2
  • 808 Answers
Update ur bios
Posted on Jul 28, 2010
I need manual instructions for instalation of K8M800-M2 Motherboard
go to ecs.com elitegroup or google K8M800-M2 THEN SELECT ECS SITE mobo drivers bios and manual all available
Dec 15, 2009 | EliteGroup K8M800-M2 Motherboard
I install a sata 160 disk and cant access the bios mi motherboard is K8M800-M2 (V1.0)
Press DEL to enter Bios SETUP
Pressing the delete key accesses the BIOS Setup Utility:
Sep 10, 2009 | EliteGroup K8M800-M2 Motherboard
Motherboard ESC k8m800-m2 (v1.0A) 2x1Gb RAM
You have to verify the in the motherboard book if the brand name or vendor of your merory stick is compatible with your computer's motherboard, there all written : Kingston, Samsung, micron etc... Check all details if meets your motherboard's model requirements and make the change if necessary.
If all details are correct, check in your motherboard's manual if there is a special configuration to respect (in withc bank you should place your memory stick and witch order etc)
Sep 02, 2009 | Computers & Internet
Cannot pick up sata hdd
Hi there
VIA K8M800 is an AMD platform motherboard and should pick up the sata drive. Connect the drive to the motheboard, make sure that both leads are connected, go into the bios and set the bios to default settings, hit F10, save and exit, the machine will restart, go back into the bios and check to make sure its been picked up by the system.
post back if you need any more help
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | EliteGroup K8M800-M2 Motherboard
K8M800-M2 motherboard
Try checking the BIOS settings some motherboards have some settings to power on the PC via network cable or modem. If this setting is turned on and you're connected to a router or modem (cable or dsl), it may be turning on your computer as soon as you turn it off.
May 30, 2008 | EliteGroup K8M800-M2 Motherboard
SATA HDD
you have to update your Bios./in your manual ,you can find on how to update your Bios.
Apr 02, 2008 | EliteGroup K8M800-M2 Motherboard
ECS K8M800 bios can't detect hd pata seagate
How you setting the jumper, pls refer to mobo manual book or HDD or your DVD/CD recorder. i gues your problem is in setting the jumper. thx
Jan 31, 2008 | EliteGroup K8M800-M2 Motherboard
SATA
is posible that u're motherboard does not support sata II (i presume that the drive is )
if that's the case, u'll have to set the jumpers on the drive to work in sata I mode ....
if u have more sata drives, check if they both are working in the same SATA mode (I or II), some motherboards can't work with both SATA standards at the same time ...
Jan 21, 2008 | Soltek SL-KT600-RL Motherboard
EliteGroup K8M800-M2 Motherboard Logo
202 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
