Question about ASUS M2V Motherboard
I have an Asus 8400GS video card in an Asus M2V m/b. After being away for several weeks with the unit unplugged, I am getting just a blank screen. No beeps. Tried VGA as well as DVI cables. No better with an old Geforce 7300 video card. Beeps if I remove memory.No response to pressing "Del." Monitor works on a laptop. I don't have another machine with a PCI-E socket to check the video card(s) Any other suggestions?
devocap
  • 201 Answers
SOURCE: Adding a second graphics card?
Hey there sven155, If i were you , I would get get the video card for the AGP slot. The main reason is the interface is much more efficient, and as a result the dual monitor output would be better in quality than you can get out of a PCI card or any USB connection. Another option is to have your TV Wonder plugged into the computer via AGP only when you need it, therefore you would be switching one for the other (Inconvenient). Ideally video card on AGP, TV card on the PCI.
Alternately you can make the two work, just not simultaneously, and you would have to change settings in the bios to set one or the other as your primary video output.
Posted on Feb 12, 2008
  • 31 Answers
SOURCE: asus m2v won't boot
Press delete to go to setup. In the boot menu tab of the BIOS make sure the correct boot disk is selected, and that hard disk boot has first priority. Also make sure there aren't any bootable disks in the cd/dvd drives that might prevent the computer from booting.
Posted on Aug 22, 2008
  • 1027 Answers
SOURCE: vga compatibility
It appears that that model is AGP slot based, so it would not work in a PCI slot.
Posted on Aug 31, 2008
hmerchant110
  • 7191 Answers
SOURCE: ASUS P5S8000-VM/S no bios screen no beeps
From the description of the problem, it seems that either the power switch of your PC or the power supply cable is faulty. Also, please let us know if the motherboard LED is glowing or not. Do reply for more assistance.
Thanks.
Posted on Jul 21, 2009
  • 788 Answers
SOURCE: asus p4s800 beep codes. I get one long beep. I
The one long beep, this has something to do with the video card.
Can't really tell without the BIOS you are using !
Anyway, try removing the card and replace it. ( with anything, just to check. )
This is a good board, I have a ASUS P4C800 and you can't beet it.
P.S. Make sure all your memory is the same freq. and clock speed.
Good luck.
Posted on Oct 23, 2009
Asus m2v motherboard has video card 7300 gt problem
most probably the graphic card has failed or failing
Feb 27, 2012 | ASUS M2V Motherboard
Want to install pny technologies gforce 8400gs ddr2 512mb pci graphics card but do not know how to deactivate my graphics card on my motherboard as I do not have a emachines 5250 manual can you help
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also you might uninstall the display adapter restart your computer then reinstall the display adapter and its drivers this would apply to the sound video and game controllers to hope this helps http://download.cnet.com/%7Bvalue=http://www.download.com/asus-agp-v7100-deluxe/3000-2108_4-68331.html
ASUS AGP-V7100 Deluxe Combo v44.03:The ASUS AGP-V7100 Series graphics cards were created to provide mainstream PC users with the radical 3D/2D graphics and video performance of the GeForce2 MX, the 2nd generation GPU from NVIDIA. With the AGP-7100 Series and its support for the TwinView architecture, ASUS has made available the most variety of models to support several dual display output combinations using RGB monitor, TV, or digital flat panel
hope this helps
May 28, 2011 | PNY Technologies VCG84512SPEB GeForce...
Hello! Please help me! What are the video card supported for asus m2v mx se. I have processor amd athlon 64x2 (dual core 4800 2,4khz), 2 gb ram and windows 7 32 bit. Thank you very much and good luck!
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 01, 2011 | ASUS M2V-MX Motherboard
My inno GeForce 9600 GT gives a blank screen when used with my Asus M2V Motherboard. Is there a fix?
Simple test: try to boot in the BIOS - if you can't then the defect is hardware, either the video card or the motherboard have failed.
Another simple test to find out which: take out the GeForce , connect the monitor directly to the motherboard and try to go into the BIOS: if you can it's the video card, if you can't it's the motherboard.
Dec 02, 2010 | ASUS M2V-MX Motherboard
Asus M2V motherboard has started locking up no apparent reason
Why don't you try these free programs first. Download the free program called CCleaner; http://www.piriform.com/ccleaner
Run the cleaner than run the registry cleaner. See if you're system stops locking up.
Still no help? Download Defraggler and run it. Lastly on the same site download Speccy and check if there is a heat problem within the system.
If you feel its the MB you can replace it preform a simple google search; http://www.google.com/products?hl=en&q=ASUS+M2V&um=1&ie=UTF-8&ei=L-XtS7CMDYH-8Ablxtj9Cg&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CDAQrQQwAg
Check for warrantys. You should find one that comes with a 1 year warranty.
http://www.newegg.com/product/product.aspx?item=N82E16813131024
Mike
May 14, 2010 | ASUS M2V Motherboard
NO AUDIO , ASUS M2V-MX SE MOTHER BOARD. WEB SITE FOR FREE DOWN LOAD OF DRIVERS
Go here:
and enter "M2V-MX SE" in the search box on the top left corner. You will be asked your OS (XP, Vista, Linux, etc.) and brought to the appropriate download page.
You will find all drivers there - LAN, Video, Audio, BIOS, etc. Let me know how it worked out...
Apr 16, 2010 | ASUS M2V-MX Motherboard
Does this motherboard supports nvidia 8400GS 512MB graphic card or not?
Yes it is.
Nvidia 8400GS 512MB is PCI-E Card Ready for and 100% Compatible with this Motherboard.
Aug 25, 2009 | ASUS P5GZ-MX Motherboard
Vga driver of m2v-mx se
Windows XP VGA driver - http://dlsvr04.asus.com/pub/ASUS/misc/vga/VIAS3G_VGA_V6141071.zip
Vista Driver - http://dlsvr04.asus.com/pub/ASUS/misc/vga/VIAChrome9_VGA_V7141060_vista32.zip
May 06, 2009 | ASUS M2V-MX Motherboard
Addinga card reader to an ASUS M2V m/board
Install a PCI usb card to give you the USB connectors.
Feb 16, 2009 | ASUS M2V Motherboard
ASUS M2V Motherboard Logo
119 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
