Water leakage model =YLSR5233EQ1. Serial CG2004700. it is leacking inside, where the hot and cold water lines go. I don't know how to get the back off. I took out 2screws on bottom, two near the top. can you help me get the back off? please. thanks Jerry
  • 145 Answers
You don't take the back off. Take the two screws out of the control panel. Unplug it first. The unsnap the two clips on the side and the whole shell comes off the front.
Posted on Apr 23, 2008
What does code f 20 mean
usually it's the water valve needs to be replaced,best thing is to remove the bottom panel,look for the diagnostics paper and put it back for future repairs,either taped to the bottom inside panel or look around inside cabinet usually on right hand side taped to right wall,it will tell you what the code is and look up how to put into diagnostics,if hot and cold water are coming in to slow or no water on hot or cold shut it down,unplug it,shut the water valve off going to washer,remove the water lines going to washer and mark them so hot goes back to hot and cold back to cold on the washer water valve.when you have the hoses off turn the house valve back on to make sure water is coming through both lines,the problem could be the house valve so you want to eliminate that.if good look into the washer valve,if you see alot of sedement in the screens change out the washer water valve,if all looks good on some machines there is a flow meter that could cause this code to come up,if water is coming in strong and screens look clean on water valve i would change the flow meter.go here and see your parts
one is valve 4 is flow meter hope this helps
Aug 22, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have a magic chef 10.1 kg super capacity heavy duty washer model W224lgv serial 10569997sf with hot water problem. only cold water goes in , pump allows to cold water to go in
(pre-typed for hot AND cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 08, 2011 | Magic Chef Washing Machines
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
Water is leaking inside the freezer and collecting at the bottom of the freezer. It eventually freezes down at the bottom of the freezer.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
If this was helpful please rate me.
Don't forget to check the icemaker for leakage, also
Leo Ponder
Jul 26, 2011 | Kenmore Side by Side Refrigerator
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The cold water stopped while filling the washer. Will not come back on. I washed one load fine and then it quit. Model # 417.98702891, serial # XE04601499. Please help!
try and change the water temp selector switch.if the hot water is working.make sure to also check the cold water supply and make sure it is not may need to replace the water can also swap the water lines and try to fill the unit if cold water is selected then you will get hot water if you do not then replace the fill valve.
Oct 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Model 70 clothes washer, cold water comes in extremely slowly, I need a diagram to show me where/how to clean the entry filter, please. I don't have a manuel for this old but very good machine. Thanks
Shut off cold water supply to machine.On the back of your machine where the cold water inlet line connects the machine. Remove the cold water hose (I recomend doing both hot and cold to ensure the the hot is clear while you are there). look inside the threaded hose connection on the machine water inlets on the back where you removed the hose(s). There are small screnes inside the fitting and can be removed with a small screwdriver. Simply rinse them out and reinstall them. Some hoses have a screne in the ends. I recomend removing your drain hose (the discharge) from the sewer and open the water fauscett and flush the homes lines and inlet hoses into the drain pipe (no mess or water on the floor). This also insures good water flow to your machine. reinstall hoses... Should fixya!
Aug 05, 2009 | Kenmore Washing Machines
Cold water just stopped flowing in,hot works
There are two electronically controlled valves in the back of the machine; one for hot water and the other for cold. It sounds like your cold valve is stuck closed or not getting the electronic signal to open. I recommend going to the following web site or calling 1-800-344-1274 for help from Maytag. They will want to know your model number and serial number so try to have that information handy when you call.
May 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Ty for being here. I have a kenmore stack washer
Inside the machine you have a valve called inlet.
The inlet water valve will collect the cold and hot water lines, and open alternatively one or the other during cycle.
To access the inlet valve you need to take apart the machine, and that is not an easy task.
If you DIY remember to unplug power, there is high voltage running inside your appliance.
Below the inlet valve for your model:
Mar 05, 2009 | Kenmore Washing Machines
I get a washer machine Whirlpool, Serial: CJ0640303, Model: LSR8200EQO, HEAVY DUTY ULTIMATE CARE. Problem: Cold water doesn't come out when the machine is working.It looks only hot water come out during...
Make sure the screen is clean.. Turn water suply off . Remove the hose from the back of your washer.look inside the blue plastic pice the line conects to there should be a screen to filter lime and dirt. Make sure it is clean.
Jul 24, 2008 | Whirlpool Washing Machines
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
