Question about GE GBS22HBP Bottom Freezer Refrigerator
My GE fridge is not cold the freezer is but not the fridge i have a bottom freezer there are 2 vents on the bottom shelf of the fridge they appear to be closed is there a way i can fix this myself?
5 Suggested Answers
SOURCE: FREEZER COLD, FRIDGE NOT
yes,don't call sears???????????????????? ,look in your phone book for a local appliance part store,let me know how it turns out-mike
Posted on Sep 23, 2008
  • 531 Answers
SOURCE: fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Posted on Apr 03, 2009
heatman101
  • 43501 Answers
SOURCE: top shelf of freezer and ice maker not cold and
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 17, 2010
markfreedman
  • 312 Answers
SOURCE: GE side by side. Top shelf in fridge warm. bottom
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Posted on Dec 29, 2010
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | GE Refrigerators
Fridge looses temperature
Make sure the two vents from the top of the fridge that run into the freezer are not blocked or obstructed in anyway, that's what the problem was in ours. Also do not allow ice to build up on the vents in the freezer.
Jan 03, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge is freezing items on bottom
restrict lower airflow from freezer vents to refrigerator is their a damper air flow control ... try blocking off vent halfway for a day or two next to bottom shelf or drawer how cold is the top shelf of refrigerator refrigerator should never be colder than 37 degrees f"otherwise bad temperature controle or the thermistor
Jan 28, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Top shelf of freezer and ice maker not cold and top shelf of fridge not cold. everything else on bottom shelves is frozen and cold .GE model GSS22JEMA
heatman101
Sep 17, 2010 | GE GSS22JEM Side by Side Refrigerator
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Apr 07, 2009 | GE Refrigerators
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE GBS22HBP Bottom Freezer Refrigerator Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
